楼主: enchanter
[资料] 有Questasim 10.5 Linux 64bit 的破解吗?
发表于 2016-8-24 17:17:59 | 显示全部楼层
回复 9# johnsonzhxun
   Can you give instructions for cracking questa 10.5 or 10.4?
   Which crack did you use for linux?
发表于 2016-9-19 11:11:44 | 显示全部楼层
破解10.5可用破解10.2的工具和方法, 唯一的区别在于run sfk时,请用
./sfk rep -yes -pat -bin /5589E557565381ECD00000008B5508/31C0C357565381ECD00000008B5508/ -bin /5589E557565381ECD8000000E8000000005B81C3/33C0C357565381ECD8000000E8000000005B81C3/ -bin /41574989FF415641554154554889CD534489C3/33C0C389FF415641554154554889CD534489C3/ -dir .
发表于 2016-9-23 18:07:12 | 显示全部楼层
回复 12# johnsonzhxun
   Thank you johnsonzhxun, I will try it and report the result.
发表于 2016-9-25 20:09:38 | 显示全部楼层
回复 12# johnsonzhxun
   I can confirm that the crack provided by johnsonzhxun is working on Questasim 10.5, running on Linux Mint 64-bit.
   Thank you very much johnsonzhxun, I have been searching for a long time and you solved my problem.
发表于 2016-10-2 16:15:26 | 显示全部楼层
license is not a problem... Can you please upload last release?
发表于 2016-11-29 23:21:39 | 显示全部楼层
Hello Johnsonzhxun,
Could you please explain step by step how to crack Questa 10.5 in Linux?
Thanks.
发表于 2017-5-20 20:06:00 | 显示全部楼层
还是没有人肯分享一下 10.5 吗?
发表于 2017-5-23 09:49:17 | 显示全部楼层
研究一下
发表于 2017-6-19 03:02:56 | 显示全部楼层
回复 16# rdemirci
Linux instructions:
   http://bbs.eetop.cn/viewthread.php?tid=612232&rpid=9262007&ordertype=0&page=2#pid9262007
发表于 2017-8-29 21:09:02 | 显示全部楼层
有嗎??
GMT+8, 2025-12-20 17:37 , Processed in 0.019676 second(s), 4 queries , Gzip On, Redis On.
