查看: 7759|回复: 11
[求助] 一个电容退化结构发大器的传递函数
发表于 2016-3-1 15:36:26 | 显示全部楼层 |阅读模式
电路结构如图所示 QQ截图20160301153540.jpg ,看论文给出的传递函数为 QQ截图20160301153614.jpg 。小弟很不解,这个电路该如何分析?希望哪路大神给点提示。
发表于 2016-3-1 18:48:59 | 显示全部楼层
带通?
发表于 2016-3-1 21:52:38 | 显示全部楼层
haonannana
发表于 2016-3-2 01:12:28 | 显示全部楼层
Peaking?
发表于 2016-3-2 07:07:11 | 显示全部楼层
Since this is a perfectly symmetrical circuit, you can cut it to half and apply the small signal model resulting in a circuit like this:
- Vin at the gate, Vs at the source, Vout at the drain
- Rs/2 in parallel with 2Cs from Vs to ground
- gm(Vin-Vs) current source in parallel with RD from Vout to Vs
- RL in parallel with CL from Vout to ground
You can then write the two nodes equations at Vs and Vout. Cancelling out Vs, you should be able to get the transfer function Vout/Vin. It seems the transistor inherent capacitances (Cgs etc) are all ignored otherwise the equation would be even more complicated.
This is a low-pass filter from the equation. Without going through any equation: the transistors convert input voltage into output current, which is then injected into RL//CL to create output voltage -- at low frequency, RL dominates so you get some voltage; at high frequency, CL dominated so the voltage is small (the higher frequency, the smaller voltage) ==> low pass.
 楼主| 发表于 2016-3-2 09:20:03 | 显示全部楼层
回复 2# semico_ljj
一个补偿高频衰减的peak,应该可以看作为一个带通滤波器。
 楼主| 发表于 2016-3-2 09:21:41 | 显示全部楼层
回复 4# iamshuang2013
en
 楼主| 发表于 2016-3-2 09:31:21 | 显示全部楼层
回复 5# laizhiguo
Your reply is useful to me.Thx!
发表于 2016-3-2 09:52:45 | 显示全部楼层
xuexi
xuexi
发表于 2016-3-2 12:46:36 | 显示全部楼层
CMOS VGA.pdf (284.42 KB , 下载次数: 64 )
本来想好好把推导过程写一下,发现了这篇文章,完全一样的电路,感兴趣的同学自己照着这篇文章推导一下就好了。
对了,楼主原来的公式里面的omega_p2应该是1/(RL*CL),不是1/(RD*CL)。
回复 支持 2 反对 0
GMT+8, 2025-12-16 02:52 , Processed in 0.026470 second(s), 6 queries , Gzip On, Redis On.
