查看: 2688|回复: 1
[原创] Help Me << Galaxy common Galaxy ICC not enabled>>
发表于 2016-1-28 10:59:45 | 显示全部楼层 |阅读模式
Hi Friends,
I installed Synopsys ICC in 'Linux Mint 15 cinnamon' version (Not Debian version).
Used SCL 10.9.3 and ICC 2010.12 (AMD 64 & Common.tar files).
Generated valid license using EFA LicGen .4b.
my lmhrd report is below
22:15:46 (lmgrd) -----------------------------------------------
22:15:46 (lmgrd)   Please Note:
22:15:46 (lmgrd)
22:15:46 (lmgrd)   This log is intended for debug purposes only.
22:15:46 (lmgrd)   In order to capture accurate license
22:15:46 (lmgrd)   usage data into an organized repository,
22:15:46 (lmgrd)   please enable report logging. Use Macrovision's
22:15:46 (lmgrd)   software license administration  solution,
22:15:46 (lmgrd)   FLEXnet Manager, to  readily gain visibility
22:15:46 (lmgrd)   into license usage data and to create
22:15:46 (lmgrd)   insightful reports on critical information like
22:15:46 (lmgrd)   license availability and usage. FLEXnet Manager
22:15:46 (lmgrd)   can be fully automated to run these reports on
22:15:46 (lmgrd)   schedule and can be used to track license
22:15:46 (lmgrd)   servers and usage across a heterogeneous
22:15:46 (lmgrd)   network of servers including Windows NT, Linux
22:15:46 (lmgrd)   and UNIX. Contact Macrovision at
22:15:46 (lmgrd)   www.macrovision.com for more details on how to
22:15:46 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
22:15:46 (lmgrd)   for your enterprise.
22:15:46 (lmgrd)
22:15:46 (lmgrd)
22:15:46 (lmgrd)
22:15:46 (lmgrd) FLEXnet Licensing (v10.8.5.0 build 31891 i86_re3) started on jithin-vm (linux) (1/27/2016)
22:15:46 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
22:15:46 (lmgrd) US Patents 5,390,297 and 5,671,412.
22:15:46 (lmgrd) World Wide Web:  http://www.macrovision.com
22:15:46 (lmgrd) License file(s): /usr/synopsys/synopsys.dat
22:15:46 (lmgrd) lmgrd tcp-port 27000
22:15:46 (lmgrd) Starting vendor daemons ...
22:15:46 (lmgrd) Started snpslmd (internet tcp_port 45297 pid 2789)
22:15:46 (snpslmd) FLEXnet Licensing version v10.8.5.3 build 59306 i86_re3
22:15:59 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_10.9.3
22:16:00 (snpslmd) Server started on jithin-vm for:        SSS
22:16:00 (snpslmd) nanochar        hspice_pack        cosmos_other
22:16:00 (snpslmd) cxp                Synopsys_VCS_cmv Design-Expert
22:16:00 (snpslmd) him_mm_pi        CXp_GUI                CXp_Analysis
22:16:00 (snpslmd) CXp_CircuitEnvironment COSMOS_SCOPE        CmMonitor
22:16:00 (snpslmd) VCSiRuntimeLimited_Node VCSiRuntimeLimited_Net VMCCompiler_Node
22:16:00 (snpslmd) VMCRuntime_Node VMCEvaluation_Node VMCGeneratorUnlocked_Node
22:16:00 (snpslmd) VMCExpress_Compiler_Node VMCCompiler_Net VMCRuntime_Net
22:16:00 (snpslmd) VMCEvaluation_Net VMCGeneratorUnlocked_Net VMCExpress_Compiler_Net
22:16:00 (snpslmd) LMCSwift_Node        SNPS-Assertions VT_SystemVerilog
22:16:00 (snpslmd) VCSMXRunTime_Net VCSMXiRunTime_Net Magellan-Sim
22:16:00 (snpslmd) VT_SVAssertions VT_SVTestbench        VT_NativeTestbench
22:16:00 (snpslmd) VT_DVE                VT_UCLI                VT_LCA_Testbench
22:16:00 (snpslmd) PVCSCompiler_Net PVCSRuntime_Net VT_VCS_Power_Management
22:16:00 (snpslmd) VT_VCS_Checker        VT_VCS_Echo        RMAN_RUN
22:16:00 (snpslmd) VT_VCS_NTBE        XVVCDebugger        VT_UnifiedCoverage
22:16:00 (snpslmd) VT_64Bit        VT_OtherTechnology VT_NativeTBDebuggerGui
22:16:00 (snpslmd) VT_CBUG                VT_SVAssertionCompiler VT_SDebug
22:16:00 (snpslmd) VT_DVENTB        VT_Pioneer        VT_SYSTEMC21
22:16:00 (snpslmd) VT_LCA_Coverage VT_LCA_DEBUG        VT_LCA_Assertions
22:16:00 (snpslmd) VT_LCA_MixedSignal VT_DVE_COV        VT_VCS_Advanced_Features
22:16:00 (snpslmd) VT_VCS_BETA_Program VT_PVCSCompiler_Net DesignWare-ETHERNET
22:16:00 (snpslmd) Primepower        Primepower_gui        fpc_foundation
22:16:00 (snpslmd) fpc_pna                fpc_utils        fpc_special1
22:16:00 (snpslmd) fpc_special2        fpc_special3        Test-Validate
22:16:00 (snpslmd) Test-Accelerate-Max chiparch_migrate planet_migrate
22:16:00 (snpslmd) DesignWare-ARMCORES-tlm DesignWare-AMBA-tlm Test-LBIST-Integration
22:16:00 (snpslmd) VHDL-Compiler-Presto primepower_vcd        Test-Beta-7
22:16:00 (snpslmd) Test-Beta-8        Test-Beta-9        Test-STDVR
22:16:00 (snpslmd) Test-MBIST-Integration HDL-Compiler-SystemVerilog primepower_beta
22:16:00 (snpslmd) MV-Opt                PhysOpt-VH        Formality-TX
22:16:00 (snpslmd) Formality-Distributed PhysOpt-Integration PhysOpt-Beta-Milkyway
22:16:00 (snpslmd) PhysOpt-Beta-SI PhysOpt-Beta-CTS PhysOpt-Beta-Route
22:16:00 (snpslmd) Test-Fault-Max        PAW                PsynGui-ChipMap
22:16:00 (snpslmd) Formality-ESP        PhysOpt-XG        PsynGui-AARender
22:16:00 (snpslmd) Test-Compression-ATPG Test-Compression-Synthesis HDL-Compiler-Old
22:16:00 (snpslmd) VHDL-Compiler-Old Test-Mbist-Program Test-Mbist-Bitstream
22:16:00 (snpslmd) Galileo                Galileo-PSYN        Galileo-PnR
22:16:00 (snpslmd) Galileo-GUI        NanoTime        NanoTime-PathMill-Shared
22:16:00 (snpslmd) Galileo-Internal-Only PhysOpt-MV        Astro-MV
22:16:00 (snpslmd) Galaxy-GUI-PSYN Galaxy-GUI-PNR        Galaxy-Beta
22:16:00 (snpslmd) Galaxy-Internal-Only PrimeTime-New-Technology PrimeRail
22:16:00 (snpslmd) Power-Optimization-Beta1 Power-Optimization-Beta2 Formality-Beta1
22:16:00 (snpslmd) Formality-Beta2 Galaxy-MCMM        PrimeTime-PX
22:16:00 (snpslmd) DB-Mode                DC-Topographical snps_fs_nwave
22:16:00 (snpslmd) Pathmill-migrate Pathmill-plus-migrate NanoTime-ultra
22:16:00 (snpslmd) Galaxy-CCS        Galaxy_FP_Beta        Galaxy_MultiRoute4
22:16:00 (snpslmd) Galaxy_MultiRoute8 PrimeTime-VX        Galaxy-AdvRules
22:16:00 (snpslmd) Galaxy-FlipChip Galaxy-FP-Hier        Test-SDD-Timing
22:16:00 (snpslmd) Galaxy-AdvOpt        Galaxy-CTMesh        Galaxy-Zroute
22:16:00 (snpslmd) Test-Power        Test-Physical        DCT-Congestion
22:16:00 (snpslmd) DCT-GUI                DC-Extension        Galaxy-FP-MV
22:16:00 (snpslmd) Galaxy-FP-AdvCTS Galaxy-FP-AdvTech NCX
22:16:00 (snpslmd) Galaxy-SPG        PrimeTime-PX-Statistical PrimeTime-PX-New-Technology
22:16:00 (snpslmd) PrimeRail-New-Technology PrimeRail-static PrimeRail-adv
22:16:00 (snpslmd) Test-CompressionPlus-Syn Test-CompressionPlus-ATPG NCX-addon
22:16:00 (snpslmd) DC-FPGA-Add-On-to-DC DESIGNWARE-AMBA-VIP DESIGNWARE-I2C-VIP
22:16:00 (snpslmd) DESIGNWARE-REGRESSION DESIGNWARE-SIO-VIP DESIGNWARE-VERIFICATION
22:16:00 (snpslmd) DWC-AHB-ICTL-Source DWC-AHB-Source        DWC-AMBA-Fabric-Source
22:16:00 (snpslmd) DWC-APB-Advanced-Source DWC-APB-ICTL-Source DWC-APB-Periph-Source
22:16:00 (snpslmd) DWC-DMA-Controller-Source DWC-DMAC-Source DWC-GPIO-Source
22:16:00 (snpslmd) DWC-I2C-Source        DWC-INTC-CNTL-Source DWC-MEMCTL-Source
22:16:00 (snpslmd) DWC-RAP-Source        DWC-RTC-Source        DWC-SSI-Source
22:16:00 (snpslmd) DWC-TIMERS-Source DWC-UART-SRC        DWC-UART-Source
22:16:00 (snpslmd) DWC-WDT-Source        DesignWare-MEMCTL-Source JupiterXT_VF
22:16:00 (snpslmd) SABER_GUIDE        VT_LCA_Language VT_NTB
22:16:00 (snpslmd) VT_SVDesign        aPrv                sharp
22:16:00 (snpslmd) simif                VHDLAMS_TAURILI VHDLAMS_TAURI
22:16:00 (snpslmd) MODPEX_AWB        MODPEX_CTC        MODPEX_ELDO
22:16:00 (snpslmd) MODPEX_MARELLI        MODPEX_NOPOWER        MODPEX_PTFT
22:16:00 (snpslmd) MODPEX_SABER        MODPEX_STATIS        MODPEX_TVS
22:16:00 (snpslmd) MONTE_CARLO        MONTE_CARLO_MEMSSE MOS_TOOL
22:16:00 (snpslmd) MOS_TOOL_MEMSSE MOTOR_DCPM_TOOL MOTOR_DCPM_TOOL_MEMSSE
22:16:00 (snpslmd) OPT_TEMPLATE_LIB_MEMSSE PLACEHOLDER        PNET_LIBRARY
22:16:00 (snpslmd) PNEUM_HYD_PRG1        PNEU_HYD_LIBRARY POLARIS_SCOPE
22:16:00 (snpslmd) POLARIS_X        POWER_EXPRESS        SABER_SKETCH_NETLISTER
22:16:00 (snpslmd) SABER_SKETCH_NETLISTER_MEMSSE SABER_TSP        SABER_VERILOG_MM
22:16:00 (snpslmd) SABER_VERILOG_MM_MEMSSE SABER_VHDLAMS        SABER_VHDLAMS_MEMSSE
22:16:00 (snpslmd) SABER_VIEWSIM_MM SABER_VIEWSIM_MM_MEMSSE SCAN_TOOL
22:16:00 (snpslmd) SCAN_TOOL_MEMSSE SENSITIVITY        SENSITIVITY_MEMSSE
22:16:00 (snpslmd) SJCL_LIBRARY        SPECTRAL        SPECTRAL_MEMSSE
22:16:00 (snpslmd) STATEBENCH        STRESS                STRESS_MEMSSE
22:16:00 (snpslmd) SYMLIB                SYMLIB_JAPANESE SYMLIB_JAPANESE_MEMSSE
22:16:00 (snpslmd) SYMLIB_MEMSSE        SYMLIB_PLUS        SYMLIB_PLUS_MEMSSE
22:16:00 (snpslmd) SABERRT_ADI        SABERRT_ADI_MEMSSE SABERRT_AP2633
22:16:00 (snpslmd) SABERRT_FE        SABERRT_FE_MEMSSE SABERRT_HIL
22:16:00 (snpslmd) SABERRT_HIL_MEMSSE SABER_DEV_MM        SABER_GUIDE_MEMSSE
22:16:00 (snpslmd) SABER_INTERFACE_MEMSSE SABER_LEAPFROG_MM SABER_MODELSIM_MM
22:16:00 (snpslmd) SABER_MODELSIM_MM_MEMSSE SABER_MODELSIM_PLUS_MM SABER_MODELSIM_PLUS_MM_MEMSSE
22:16:00 (snpslmd) SABER_MODELSIM_VHDL_MM SABER_MODELSIM_VHDL_MM_MEMSSE SABER_MODELSIM_VLOG_MM
22:16:00 (snpslmd) SABER_PLUGNSIM_MM SABER_QSIM_MM        SABER_QVSPRO_MM
22:16:00 (snpslmd) SABER_RT_MM        SABER_RT_MM_MEMSSE SABER_RUNTIME
22:16:00 (snpslmd) SABER_SCOPE_MEMSSE SABER_SIMMATRIX_MM SABER_SIMULATOR_MEMSSE
22:16:00 (snpslmd) SABER_SKETCH_MEMSSE SYMLIB_POWER        SYMLIB_POWER_MEMSSE
22:16:00 (snpslmd) TESTIFY                TESTIFY_MEMSSE        TESTIFY_NETLISTER_MEMSSE
22:16:00 (snpslmd) THERM_TOOL        THERM_TOOL_MEMSSE TLU_TOOL
22:16:00 (snpslmd) TLU_TOOL_MEMSSE TR_ANALYSIS        TR_ANALYSIS_MEMSSE
22:16:00 (snpslmd) VEHICLE_ELECTRIC_LIB_MEMSSE VENDOR_LIBRARY        VENDOR_LIBRARY_MEMSSE
22:16:00 (snpslmd) VERIAS_HSPICE_COMPILER VERIAS_SIMULATOR VIEWLOGIC_FRAMEWAY
22:16:00 (snpslmd) VIEWLOGIC_FRAMEWAY_MEMSSE VIEWLOGIC_NET_MEMSSE WF_API_HSPICE
22:16:00 (snpslmd) WF_API_HSPICE_MEMSSE WF_API_MEMSSE        WF_API_STARSIM
22:16:00 (snpslmd) WF_API_STARSIM_MEMSSE EDIF_NETLISTER        EDIF_NETLISTER_MEMSSE
22:16:00 (snpslmd) EXPT_EDITOR        MAST_COMPILER        MEASURE
22:16:00 (snpslmd) MEASURE_MEMSSE        MEMS                MENTOR_FRAMEWAY
22:16:00 (snpslmd) MENTOR_FRAMEWAY_MEMSSE MENTOR_NETLISTER MENTOR_NETLISTER_MEMSSE
22:16:00 (snpslmd) MICROCOSM_LIB        MICROCOSM_LIB2        MICROCOSM_LIB2_MEMSSE
22:16:00 (snpslmd) MICROCOSM_LIB3        MICROCOSM_LIB3_MEMSSE MICROCOSM_LIB4
22:16:00 (snpslmd) MICROCOSM_LIB4_MEMSSE MICROCOSM_LIB5        MICROCOSM_LIB5_MEMSSE
22:16:00 (snpslmd) MICROCOSM_LIB6        MICROCOSM_LIB6_MEMSSE MICROCOSM_LIB7
22:16:00 (snpslmd) MICROCOSM_LIB7_MEMSSE MICROCOSM_LIB_MEMSSE MODEL_ARCHITECT
22:16:00 (snpslmd) MODEL_ENCRYPTION_MEMSSE MODEL_SYNTHESIS_MEMSSE MODPEX
22:16:00 (snpslmd) MODPEX_AQUEDUCT MODPEX_ASIM        MODPEX_ATFT
22:16:00 (snpslmd) HARNESS_CATIA        HARNESS_MCADREAD HARNESS_PROCABLE
22:16:00 (snpslmd) HARNESS_UNIGRAPHICS HSPICE_MODEL_LIBRARY_MEMSSE IC_DESIGN_LIB
22:16:00 (snpslmd) IMECH_LIBRARY        IQBUS_AUTHOR_MEMSSE IQBUS_DESIGNER
22:16:00 (snpslmd) IQBUS_LIB_MEMSSE LINK_MATLAB        LINK_MATLAB_MEMSSE
22:16:00 (snpslmd) LINK_XMATH        LOAD_TOOL        LOAD_TOOL_MEMSSE
22:16:00 (snpslmd) LSA_MEMSSE        LSA                LTX_LIBRARY
22:16:00 (snpslmd) COVENTOR_LIB10        COVENTOR_LIB10_MEMSSE COVENTOR_LIB11
22:16:00 (snpslmd) COVENTOR_LIB11_MEMSSE COVENTOR_LIB12        COVENTOR_LIB12_MEMSSE
22:16:00 (snpslmd) COVENTOR_LIB13        COVENTOR_LIB13_MEMSSE COVENTOR_LIB14
22:16:00 (snpslmd) COVENTOR_LIB14_MEMSSE COVENTOR_LIB15        COVENTOR_LIB15_MEMSSE
22:16:00 (snpslmd) COVENTOR_LIB8        COVENTOR_LIB8_MEMSSE COVENTOR_LIB9
22:16:00 (snpslmd) COVENTOR_LIB9_MEMSSE DESIGNSTAR        DESIGNSTAR_NET
22:16:00 (snpslmd) DIODE_TOOL        DIODE_TOOL_MEMSSE DRCYCLE_TOOL
22:16:00 (snpslmd) DRCYCLE_TOOL_MEMSSE ABB_CHCRC_LIBRARY AIM_DEBUG_MEMSSE
22:16:00 (snpslmd) AIM_DEVELOPER_MEMSSE AUT_NUMBER_MAJOR_PACKAGES BASIC_ANALYSES
22:16:00 (snpslmd) BASIC_ANALYSES_MEMSSE BATCH_MEASURE        BATCH_MEASURE_MEMSSE
22:16:00 (snpslmd) BATT_TOOL        BATT_TOOL_MEMSSE BETA_LIBRARY
22:16:00 (snpslmd) BUILD_DATE        BUILD_NUMBER        BUNDLE_MCAD_PROJECTION
22:16:00 (snpslmd) CADENCE_DIVA_NETLISTER CADENCE_FRAMEWAY CADENCE_FRAMEWAY_MEMSSE
22:16:00 (snpslmd) CADENCE_NETLISTER CADENCE_NETLISTER_MEMSSE COMPONENT_LIBRARY_MEMSSE
22:16:00 (snpslmd) CONCEPT_FRAMEWAY CONCEPT_NETLISTER CORENL_CHAR
22:16:00 (snpslmd) CORENL_CHAR_MEMSSE COSMOS_GUIDE        COSMOS_SKETCH
22:16:00 (snpslmd) COSMOS_SKETCH_BACK_ANN COSMOS_SKETCH_NETLISTER EXPT_EDITOR_MEMSSE
22:16:00 (snpslmd) EXPT_EDITOR_PLUS EXPT_EDITOR_PLUS_MEMSSE FAILURE_MODE
22:16:00 (snpslmd) FAILURE_MODE_MEMSSE FASTPARTS        FUSE_CHAR
22:16:00 (snpslmd) FUSE_CHAR_MEMSSE XC4000E                XC4000EX
22:16:00 (snpslmd) XC4000L                XC4000XL        XC4000XLA
22:16:00 (snpslmd) XC4000XV        XC5200                XC9500
22:16:00 (snpslmd) XC9500XL        XC9500XV        xp
22:16:00 (snpslmd) XVCSDebugger        XVCSiDebugger        VSS-CompiledSim
22:16:00 (snpslmd) VSS-Debugger        VSS-Falcon-Interface VSS-GateSim
22:16:00 (snpslmd) VSS-LAI-Models        VSS-Lib-Tools        VSS-LMSI
22:16:00 (snpslmd) VSS-Model-Developer VSS-NEC-Tran        VSS-SDF-Interface
22:16:00 (snpslmd) VSS-SGE-Tool        VSS-Simulator        VSS-SmartModels
22:16:00 (snpslmd) VSS-SPC                VSS-Tran        VSS-Utilities
22:16:00 (snpslmd) VSS-Verilog-PLI VSS-VIP-Interface VSS-Wave-Display
22:16:00 (snpslmd) VSS-XP-Accelerator VT_AssertionIP        VT_Assertions
22:16:00 (snpslmd) VT_AssertionsRuntime VT_Coverage        VT_CoverageRuntime
22:16:00 (snpslmd) VT_CoverageURG        VT_Testbench        VT_TestbenchRuntime
22:16:00 (snpslmd) VT_VCS_BETA_Features VT_VCS_LCA_Features VT_Visual
22:16:00 (snpslmd) vtran                WhatIfAnalysis        WRITE
22:16:00 (snpslmd) XC3000                XC4000                VIRTEXE
22:16:00 (snpslmd) VIRTEXEA        Vivace-Code-Generator Vivace-Core
22:16:00 (snpslmd) Vivace-Debug        Vivace-Elaborator Vivace-Expert
22:16:00 (snpslmd) Vivace-Express        Vivace-GUI        Vivace-HDL-Analyzer
22:16:00 (snpslmd) Vivace-Model-Compiler Vivace-Pro        Vivace-Simulator
22:16:00 (snpslmd) Vivace-VHDL-Analyzer vlog_epic_pif        vlog2e
22:16:00 (snpslmd) vlsi2000        vlsi500                VMCCompiler
22:16:00 (snpslmd) VMCCore                VMCEvaluation        VMCExpress_Compiler
22:16:00 (snpslmd) VMCGeneratorUnlocked VMCRuntime        VPC
22:16:00 (snpslmd) vsea-calib_all        VSP_DRIVER        VSS-Analyzer
22:16:00 (snpslmd) VSS-Backplane        VSS-Cadence-Interface VSS-CLI
22:16:00 (snpslmd) vera_comp        vera_debug        vera_ip
22:16:00 (snpslmd) vera_rtime        Verdi                Verification-Token
22:16:00 (snpslmd) Verilog                verilog_writer        Verilog-Netlist-Writer
22:16:00 (snpslmd) Verilog-Parser        Verilog-To-BE        Verilog-VirSim
22:16:00 (snpslmd) vertue                vhdl_compiler        VHDL-Analyzer
22:16:00 (snpslmd) VHDL-Compiler        VHDL-Cycle-Sim        VHDL-Elaborator
22:16:00 (snpslmd) VHDL-Event-Sim        VHDLi-Elaborator VHDLi-Event-Sim
22:16:00 (snpslmd) VHDL-Netlist-Writer VHDL-ScSim        VHDL-To-BE
22:16:00 (snpslmd) VHDL-Tools        VHDL-VirSim        VHMC-Eval
22:16:00 (snpslmd) VHMC-GenUnlocked VHMC-Runtime        viewlogic
22:16:00 (snpslmd) viewlogic_epic        VIEWLOGIC_NET        VirSim
22:16:00 (snpslmd) VIRTEX                VIRTEX2                VIRTEX2P
22:16:00 (snpslmd) VCSNativeCode        VCSNativeCode_Net VCSNativeCode_Node
22:16:00 (snpslmd) VCSOldPostProcDebugger_Net VCSOldPostProcDebugger_Node VCSParallelCompiler
22:16:00 (snpslmd) VCSParallelCompiler_Net VCSParallelCompiler_Node VCSParallelRuntime
22:16:00 (snpslmd) VCSParallelRuntime_Net VCSParallelRuntime_Node VCSParallelThread
22:16:00 (snpslmd) VCSParallelThread_Net VCSParallelThread_Node VCSPostProcDebugger
22:16:00 (snpslmd) VCSPostProcDebugger_Net VCSPostProcDebugger_Node VCSRuntime
22:16:00 (snpslmd) VCSRuntime_Net        VCSRuntime_Node VCSRuntimeLimited
22:16:00 (snpslmd) VCSRuntimeLimited_Net VCSRuntimeLimited_Node VCSStd
22:16:00 (snpslmd) VCSStd_Net        VCSStd_Node        VCSTools
22:16:00 (snpslmd) VCSTools_Net        VCSTools_Node        VDesktop-Debug
22:16:00 (snpslmd) VDesktop-GUI        VDesktop-VCDTrans VDesktop-Verilog
22:16:00 (snpslmd) VDesktop-VHDL        VEHICLE_ELECTRIC_LIB Vera
22:16:00 (snpslmd) Ultra37000        VANTIS                vcd2e
22:16:00 (snpslmd) vcsace                VCSAMSCompiler        VCSAMSCompiler_Net
22:16:00 (snpslmd) VCSAMSRuntime        VCSAMSRuntime_Net VCSCompile
22:16:00 (snpslmd) VCSCompile_Net        VCSCompile_Node VCSCompiler
22:16:00 (snpslmd) VCSCompiler_Net VCSCompiler_Node VCSDebugger
22:16:00 (snpslmd) VCSDebugger_Net VCSDebugger_Node VCS-Express-Compile
22:16:00 (snpslmd) VCS-Express-Runtime VCSiCompile        VCSiCompile_Net
22:16:00 (snpslmd) VCSiCompile_Node VCSiCompiler        VCSiCompiler_Net
22:16:00 (snpslmd) VCSiCompiler_Node VCSiDebugger        VCSiDebugger_Net
22:16:00 (snpslmd) VCSiDebugger_Node VCSiRuntime        VCSiRuntime_Net
22:16:00 (snpslmd) VCSiRuntime_Net(3) VCSiRuntime_Node VCSiRuntimeLimited
22:16:00 (snpslmd) VCSlm_Hm        VCSlm_Hm_Net        VCSlm_Hm_Node
22:16:00 (snpslmd) Test-Mbist-Algorithm Test-Mbist-CAM        Test-Mbist-Diagnosis
22:16:00 (snpslmd) Test-Mbist-DRAM Test-Mbist-FLASH Test-Mbist-Multiport
22:16:00 (snpslmd) Test-PR-1        Test-PR-2        Test-PR-3
22:16:00 (snpslmd) Test-PR-4        Test-RTL-Check        Test-RTL-Tristate
22:16:00 (snpslmd) Test-ScanRoute        TestSim                TestVE
22:16:00 (snpslmd) tfm                timemill        timemill/ace
22:16:00 (snpslmd) timemill/av        timemill/bcx        timemill/bdc
22:16:00 (snpslmd) timemill/beta_status timemill/btm        timemill/csx
22:16:00 (snpslmd) timemill/internal_use timemill/msx        timemill/nsaddon
22:16:00 (snpslmd) TimingAnalysis        TLM_Synthesis        TRUE
22:16:00 (snpslmd) tSchema                turboSchema        turboState
22:16:00 (snpslmd) turboTracer        TurboWave        turbowave_epic
22:16:00 (snpslmd) Test-BIST        Test-BSDL        Test-CA
22:16:00 (snpslmd) Test-CA-2        Test-CA-3        Test-CA-4
22:16:00 (snpslmd) Test-Compile        Test-Compile-Max Test-Compiler
22:16:00 (snpslmd) Test-Compile-Remodel Test-Compiler-Plus Test-Compiler-Remodel
22:16:00 (snpslmd) Test-Compile-Share Test-Core-Integration Test-Core-Wrapper
22:16:00 (snpslmd) Test-CTL-Model        Test-Custom-Protocols Test-Delay
22:16:00 (snpslmd) TestDesignCorrelation Test-DFTC-TMAX        Test-DFT-Top
22:16:00 (snpslmd) Test-Diagnosis        Test-Eval        Test-Faultsim
22:16:00 (snpslmd) Test-Faultsim-8L Test-Format        Test-IDDQ
22:16:00 (snpslmd) Test-IEEE-Std-1149-1 TESTIFY_NETLISTER testing
22:16:00 (snpslmd) Test-LBIST-ATPG Test-LBIST-Synthesis Test-Library
22:16:00 (snpslmd) TestManager        Test-Map        Test-Mbist
22:16:00 (snpslmd) SynLib-Seq        SynLib-VerilogSimMdl SynLib-VHDLSimMdl
22:16:00 (snpslmd) Synopsys        Synopsys-Queue        Synopsys-Release
22:16:00 (snpslmd) TBM-Manager-UI        TBM-VSS-Check        TBS
22:16:00 (snpslmd) TC-Beta                TDL-Interface        TDL-Reader
22:16:00 (snpslmd) TDL-Writer        Tdx_all                techviewer
22:16:00 (snpslmd) Tecplot_all        TecplotSmall_all Ted_all
22:16:00 (snpslmd) TedSmall_all        Test-Accelerator Test-Analysis
22:16:00 (snpslmd) Test-Analysis-GUI Test-Analysis-RTL Test-ATPG
22:16:00 (snpslmd) Test-ATPG-30        Test-ATPG-Limited Test-ATPG-Max
22:16:00 (snpslmd) Test-ATPG-PRO        Test-ATPG-Ultra Test-ATPG-XP
22:16:00 (snpslmd) Test-Beta        Test-Beta-2        Test-Beta-3
22:16:00 (snpslmd) Test-Beta-4        Test-Beta-5        Test-Beta-6
22:16:00 (snpslmd) stars_aryred        stars_cmi        stars_csdf
22:16:00 (snpslmd) stars_hsplnk        stars_ish        stars_linred
22:16:00 (snpslmd) stars_mr        stars_wsf        starsim
22:16:00 (snpslmd) starsimxt        STAR-SYN2STAR        start_aed
22:16:00 (snpslmd) start_analysis        start_bin        STAR-TCAD
22:16:00 (snpslmd) startime        STAR-XREF        StarXtract
22:16:00 (snpslmd) sup2lig_all        swb_all                swb-advanced_all
22:16:00 (snpslmd) sx_cdslink        sx_chip                sx_daiclink
22:16:00 (snpslmd) sx_drc                sx_wva                Sxtract_all
22:16:00 (snpslmd) SYNARIO                SynLib-AdvMath        SynLib-ALU
22:16:00 (snpslmd) SynLib-Control        SynLib-DSPFIR        SynLib-Eval
22:16:00 (snpslmd) SynLib-FltTol        SynLib-PCIbasic Syn-Library-Compiler
22:16:00 (snpslmd) sprocessmpp_all sprocess-parallel_all sprocess-parallel4_all
22:16:00 (snpslmd) sptopography2d_all ST_LIBRARY        Stamp-Compiler
22:16:00 (snpslmd) STAR-ASCII        STAR-CR                STAR-DC
22:16:00 (snpslmd) STAR-EX                STAR-EX_ERC        STAR-FILTER
22:16:00 (snpslmd) STAR-GAZER        STAR-LD2LTL        STAR-R
22:16:00 (snpslmd) STAR-RC                STAR-RC2        STAR-RC2_MANAGER
22:16:00 (snpslmd) STAR-RC2-AEO        STAR-RC2-ANAL        STAR-RC2-ASCII
22:16:00 (snpslmd) STAR-RC2-CLOCK        STAR-RC2-DB        STAR-RC2-DISTRIB10
22:16:00 (snpslmd) STAR-RC2-GUI        STAR-RC2-NETLIST STAR-RC2-PROBER
22:16:00 (snpslmd) STAR-RC2-TCAD        STAR-RC2-VIEWER STAR-RC2-XSTOR1
22:16:00 (snpslmd) STAR-RC2-XSTOR2 STAR-RC2-XTRACT STAR-RC2-XTR-AEO
22:16:00 (snpslmd) STAR-RC-GUI        STAR-R-GUI        stars_analog
22:16:00 (snpslmd) SGE-Tool        SGE-Verilog-Interface SGE-VHDL-Interface
22:16:00 (snpslmd) ShortCut-DC-Expert ShortCut-DC-Pro Shortcut-FPGA
22:16:00 (snpslmd) Siloti                Siloti_fe        Siloti_o2
22:16:00 (snpslmd) SilVE                SimVE                simwave
22:16:00 (snpslmd) simwave_epic        SKDB_Import        SNPS-CSL
22:16:00 (snpslmd) SNPS-Keygen        SNPS-MOTIVE        SolarGAII
22:16:00 (snpslmd) SolarII                sparallel_all        SPARTAN
22:16:00 (snpslmd) SPARTAN2        SPARTAN2E        SPARTANXL
22:16:00 (snpslmd) spcmcalib_all        spcmstd_all        spice_explorer
22:16:00 (snpslmd) spice_parser        sprocess_all        sprocess2d_all
22:16:00 (snpslmd) sprocess2dmc_all sprocess3d_all        sprocess3dmc_all
22:16:00 (snpslmd) sprocess-an-imp3d_all sprocesskmc_all sprocessmc_all
22:16:00 (snpslmd) SC-HLS                scratch                SC-RTL
22:16:00 (snpslmd) sda                sde_all                sde3d_all
22:16:00 (snpslmd) sdevcie-laser_all sdevice_all        sdevice-3d_all
22:16:00 (snpslmd) sdevice-densitygrad_all sdevice-ferro_all sdevice-floatinggate_all
22:16:00 (snpslmd) sdevice-gateleakage_all sdevice-hetero_all sdevice-hydro_all
22:16:00 (snpslmd) sdevice-kpgain_all sdevice-laser_all sdevice-led_all
22:16:00 (snpslmd) sdevice-mixedmode_all sdevicemonosemicond_all sdevice-montecarlo_all
22:16:00 (snpslmd) sdevice-noise_all sdevice-optic_all sdevice-parallel_all
22:16:00 (snpslmd) sdevice-parallel4_all sdevice-pmi_all sdevice-radiation_all
22:16:00 (snpslmd) sdevice-reliability_all sdevice-schroedinger_all sdevice-sige_all
22:16:00 (snpslmd) sdevice-thermo_all sdevice-traps_all sdevice-vectoroptic_all
22:16:00 (snpslmd) SEU                SGE-DC-Interface SGE-EDIF-Interface
22:16:00 (snpslmd) railmill/gbx        railmill/internal_use railmill/msx
22:16:00 (snpslmd) railmill/power        railmill/rvfp        railmill/snx
22:16:00 (snpslmd) railmill/spnx        railmill/ssnx        RCXTEO
22:16:00 (snpslmd) Reusner                rm_eee                route66
22:16:00 (snpslmd) RouteCompiler        rslv3d                rslv3dviewer
22:16:00 (snpslmd) RT54SXS                RTL-Analyzer        RTL-Analyzer-DAP
22:16:00 (snpslmd) RTL-Analyzer-Shell RTL-Analyzer-Shell-DAP RtlGateCorrelation
22:16:00 (snpslmd) RTL-Power-Analysis SABER_BUNDLE        SABER_DEV_MMP
22:16:00 (snpslmd) SABER_HARNESS        SABER_HARNESS_NETLISTER SABER_IF
22:16:00 (snpslmd) SABER_INTERFACE SABER_SCOPE        SABER_SCOPE_NETLIST
22:16:00 (snpslmd) SABER_SIMULATOR SABER_SKETCH        SABER_SKETCH_NETLIST
22:16:00 (snpslmd) SC-BC                SC-COSIM        SC-FPGA
22:16:00 (snpslmd) PPPRT                PrimeTime        PrimeTime_gui
22:16:00 (snpslmd) PrimeTime-Plus        PrimeTime-SI        prmspx_visual_all
22:16:00 (snpslmd) Prolyt_all        ProMA-L1        ProMA-L2
22:16:00 (snpslmd) ProMA-LD        ProMA-P1        ProMA-P2
22:16:00 (snpslmd) ProMA-PD        Protocol-Compiler-Analysis Protocol-Compiler-COutput
22:16:00 (snpslmd) Protocol-Compiler-FML Protocol-Compiler-Synth Protocol-Compiler-UI
22:16:00 (snpslmd) provhdl_checker PS_CTS                PS_Extraction
22:16:00 (snpslmd) PS_Noise_Optimization psf                PSG-SDE
22:16:00 (snpslmd) pwga                QLOGIC                Quantum38k
22:16:00 (snpslmd) rad                RailMacro        railmill
22:16:00 (snpslmd) railmill/ace        railmill/av        railmill/bcx
22:16:00 (snpslmd) railmill/beta_status PhysOpt-Extraction PhysOpt-GUI
22:16:00 (snpslmd) PhysOpt-Hierarchy PhysOpt-Onroute PhysOpt-Parallel
22:16:00 (snpslmd) PhysOpt-Route        PhysOpt-Route-TD PhysOpt-Routing
22:16:00 (snpslmd) PhysOpt-SI        PhysOpt-Ultra        PlanetPL
22:16:00 (snpslmd) PlanetRTL        pmga                polaris-cbs
22:16:00 (snpslmd) polaris-com        polaris-int        polaris-mt
22:16:00 (snpslmd) polaris-signalscan Power-Analysis        powerarc
22:16:00 (snpslmd) powergate        Power-Optimization Power-Optimization-Upgrade
22:16:00 (snpslmd) primerail_hsim        powrmill        powrmill/ace
22:16:00 (snpslmd) powrmill/av        powrmill/bcx        powrmill/beta_status
22:16:00 (snpslmd) powrmill/btm        powrmill/csx        powrmill/internal_use
22:16:00 (snpslmd) powrmill/msx        powrmill/nsaddon powrmill/power
22:16:00 (snpslmd) powrmill/svcz        powrmill/vlog_a nProp
22:16:00 (snpslmd) nSC                nSchema                nSchemaOnly
22:16:00 (snpslmd) nState                nTE                nTiming
22:16:00 (snpslmd) nTrace                nTree                nTX
22:16:00 (snpslmd) nWave                OPT_TEMPLATE_LIB OptimISE-DOE_all
22:16:00 (snpslmd) OptimISE-Iterative_all OptimISE-RSMOpt_all OptimISE-Statistical_all
22:16:00 (snpslmd) ORCA2A                ORCA2TB                ORCA3C
22:16:00 (snpslmd) ORCA3FPSC        ORCA3L                ORCA4E
22:16:00 (snpslmd) ParDiSo_all        Parse-Tree-Translator pathfinder
22:16:00 (snpslmd) pathmill        pathmill/cso        pathmill/ctx
22:16:00 (snpslmd) pathmill/dsx        pathmill/pfx        pathmill/sfx
22:16:00 (snpslmd) pathmill_plus        PC-Expert        PhysOpt
22:16:00 (snpslmd) PhysOpt-Beta        PhysOpt-ClockTree MVerilog
22:16:00 (snpslmd) MWAPIaccess        MWAPIdev        nAnalyzer
22:16:00 (snpslmd) nanosim                nanosim/ace        nanosim/ace_cosim
22:16:00 (snpslmd) nanosim/av        nanosim/bcx        nanosim/bdc
22:16:00 (snpslmd) nanosim/beta_status nanosim/btm        nanosim/gui
22:16:00 (snpslmd) nanosim/internal_use nanosim/msx        nanosim/postlayout_har
22:16:00 (snpslmd) nanosim/power        nanosim/vlog_a        nBench
22:16:00 (snpslmd) nClock                nCompare        nECO
22:16:00 (snpslmd) nESL                NET-TRAN        nlcc
22:16:00 (snpslmd) nLint                nLint_either        nLint_mixed
22:16:00 (snpslmd) nLint_sv        nLint_verilog        nLint_vhdl
22:16:00 (snpslmd) nMonitor        Noffset-2D_all        Noffset-3D_all
22:16:00 (snpslmd) Nova-ExploreRTL-Verilog npi                MC-Pro-RP
22:16:00 (snpslmd) MC-Retime        MDataCheck        MDataPrep
22:16:00 (snpslmd) MDynLink        MEMPRO                MEMPRO-LIB
22:16:00 (snpslmd) mentor/f        Mentor-Interface MERCURY
22:16:00 (snpslmd) Mesh1D_all        Mesh2D_all        Mesh3D_all
22:16:00 (snpslmd) metaencrypt3des metawaves        metawaveswin
22:16:00 (snpslmd) mg_falcon_epic        MIF-Reader        MIF-Writer
22:16:00 (snpslmd) Milkyway        Milkyway-Interface Millennium-ATPG-EE
22:16:00 (snpslmd) Millennium-ATPG-STD Millennium-Beta Millennium-DRC
22:16:00 (snpslmd) Millennium-Eval Millennium-FS        milltools
22:16:00 (snpslmd) misc                Mixed-Language        Mixed-Paradigm
22:16:00 (snpslmd) MODEL_ENCRYPTION MODEL_SYNTHESIS MOTIVE-PrimeTime
22:16:00 (snpslmd) mti_epic        MV-Astro-Opt        LigamentFE_all
22:16:00 (snpslmd) LINYE                LMCSwift        LMCSwift_Net
22:16:00 (snpslmd) LSI-Interface        lsim_parser        LSS4E
22:16:00 (snpslmd) LTL-100                LTL-100_CIF        LTL-100_GDS
22:16:00 (snpslmd) LTL-100_NDW        MACH1                MACH2
22:16:00 (snpslmd) MACH4                MACH5                MAdv
22:16:00 (snpslmd) Mars                MAX3000A        MAX7000
22:16:00 (snpslmd) MAX7000A        MAX7000AE        MAX7000B
22:16:00 (snpslmd) MAX7000E        MAX7000S        MAX9000
22:16:00 (snpslmd) MCD                MCE                MCE-Base
22:16:00 (snpslmd) MCE-Eval        MCE-Lib-ALU        MCE-Lib-Arith1
22:16:00 (snpslmd) MCE-Lib-Arith2        MCE-Lib-Arith3        MCE-Lib-Logic
22:16:00 (snpslmd) MC-Pro                ispLSI5K        ispLSI6K
22:16:00 (snpslmd) ispLSI8K        ispMACH4000        JUAdvOptA
22:16:00 (snpslmd) JUAdvOptB        JUAOPAS                JUAPlan
22:16:00 (snpslmd) JUATime                JUAUD                JUClock
22:16:00 (snpslmd) JUDP                JUOPAS                Jupiter
22:16:00 (snpslmd) JupiterXT        JUPlan                JUTime
22:16:00 (snpslmd) JUUD                JUVS                Key-Generator
22:16:00 (snpslmd) Laker_AMS        Laker_iDRC        Laker_iLVS
22:16:00 (snpslmd) Laker_L1        Laker_L2        Laker_L3
22:16:00 (snpslmd) Laker_T1        Laker_T1_LE        Laker_Viewer
22:16:00 (snpslmd) Leakage-Power        leda_checker        leda_mx
22:16:00 (snpslmd) leda-mx                libarc                Library-Compiler
22:16:00 (snpslmd) Ligament_all        HLS-FPGA-SystemC HLS-SystemC
22:16:00 (snpslmd) hsim                hsim-cosim        hsim-xl
22:16:00 (snpslmd) hspice                hspice_adv        hspice_cosim
22:16:00 (snpslmd) hspice_gui        HSPICE_MODEL_LIBRARY hspice_mt
22:16:00 (snpslmd) hspice_rf        hspice_rf_char        hspice3des
22:16:00 (snpslmd) hspicecmidev        hspicecmirt        hspicemt
22:16:00 (snpslmd) hspicerf        hspiceva        hspicewin
22:16:00 (snpslmd) hspice-XO        hspicext        hsptest
22:16:00 (snpslmd) hspui                Hsp-vacomp        ICInteractive
22:16:00 (snpslmd) Inspect_all        Interface-Shell Interfise_all
22:16:00 (snpslmd) IQBUS_AUTHOR        IQBUS_LIB        IROI
22:16:00 (snpslmd) ISExtract_all        ispLSI1K        ispLSI2K
22:16:00 (snpslmd) ispLSI2KE        ispLSI3K        ispLSI5000S
22:16:00 (snpslmd) ispLSI5000SE        HERCULES_HLVS        HERCULES_HLVS-DEBUG
22:16:00 (snpslmd) HERCULES_HLVS-HTML HERCULES_LVS        HERCULES_MANAGER
22:16:00 (snpslmd) HERCULES_MASK        HERCULES_RCE        HERCULES_VUE
22:16:00 (snpslmd) HERCULES-CRYPT_XREF_DATA HERCULES-DISTRIBUTED HERCULES-DISTRIBUTED-2
22:16:00 (snpslmd) HERCULES-DISTRIBUTED-24 HERCULES-DISTRIBUTED-24/2000.4 HERCULES-DISTRIBUTED-4
22:16:00 (snpslmd) HERCULES-DP_MT        HERCULES-EXPLORER_DRC HERCULES-EXPLORER_FILTERS
22:16:00 (snpslmd) HERCULES-EXPLORER_LVS HERCULES-FINDSHORT HERCULES-NETLIST
22:16:00 (snpslmd) HERCULES-RUN_TRAN hicdr_test        hicdr_test/test1
22:16:00 (snpslmd) hicdr_test/test2 hicdr_test/test3 hicdr_test/test4
22:16:00 (snpslmd) hicdr_test/test5 hicdr_test/test6 hicdr_test/test7
22:16:00 (snpslmd) hicdr_test/test8 HighLevel-Power-Analysis HighLevel-Power-Optimization
22:16:00 (snpslmd) him_mb                him_mb_dsml        him_mod
22:16:00 (snpslmd) him_sml                Gsim_framework_basic Gsim_snapshot
22:16:00 (snpslmd) Gsim_wave        GuidedTraceAnalysis hd_foundation
22:16:00 (snpslmd) hd_pna                hd_special1        hd_special2
22:16:00 (snpslmd) hd_special3        hd_utils        HDL
22:16:00 (snpslmd) HDL2SC_mixed        HDL2SC_verilog        HDL2SC_vhdl
22:16:00 (snpslmd) HDL-Advisor        HDL-Advisor-Estimator HDL-Advisor-Estimator-Package
22:16:00 (snpslmd) HDL-Advisor-Package HDL-Advisor-Shell HDL-Advisor-Shell-Estimator
22:16:00 (snpslmd) HDL-Advisor-Shell-Estm-Package HDL-Advisor-Shell-Package HDL-Compiler
22:16:00 (snpslmd) hdlin                hdlin_mixed        hdlin_verilog
22:16:00 (snpslmd) hdlin_vhdl        HERCULES_DEBUGGER HERCULES_DEVICE
22:16:00 (snpslmd) HERCULES_DRC        HERCULES_ERC        HERCULES_HDRC
22:16:00 (snpslmd) HERCULES_HDRC-HTML HERCULES_HERC-ADV HERCULES_HERC-BASIC
22:16:00 (snpslmd) HERCULES_HLPE        FPGA-Library-Compiler FPGA-Option
22:16:00 (snpslmd) FPGA-VHDL-Bundle FPPRT                FPTA
22:16:00 (snpslmd) FPTime                Fridge-GUI        Fridge-Interpolator
22:16:00 (snpslmd) Fridge-Simulation FSM-Reader        FSM-Writer
22:16:00 (snpslmd) FusionVantageLmcInterface Gaia                Galaxy-AdvCTS
22:16:00 (snpslmd) Galaxy-AdvTech        Galaxy-Common        Galaxy-DFT
22:16:00 (snpslmd) Galaxy-DFY        Galaxy-FP        Galaxy-ICC
22:16:00 (snpslmd) Galaxy-IU        Galaxy-MV        Galaxy-PNR
22:16:00 (snpslmd) Galaxy-Power        Galaxy-Prototype Galaxy-PSYN
22:16:00 (snpslmd) Gate2LayoutCorrelation Gate2RTLCorrelation gemini_hspice
22:16:00 (snpslmd) GENERICVSP        GENESISe_all        gentech
22:16:00 (snpslmd) GRAPHICS_INTERFACE Gsim_dump_advance Gsim_dump_basic
22:16:00 (snpslmd) Gsim_framework_advance FPGA-Express-A42MX-Optimizer FPGA-Express-A54SX-Optimizer
22:16:00 (snpslmd) FPGA-Express-APEX2-Optimizer FPGA-Express-APROA-Optimizer FPGA-Express-Constraint-Mgr
22:16:00 (snpslmd) FPGA-Express-EP20k-Optimizer FPGA-Express-EPF10k-Optimizer FPGA-Express-EPF6k-Optimizer
22:16:00 (snpslmd) FPGA-Express-EPF8k-Optimizer FPGA-Express-EPM7k-Optimizer FPGA-Express-EPM9k-Optimizer
22:16:00 (snpslmd) FPGA-Express-GAT FPGA-Express-isp1K-Optimizer FPGA-Express-isp2K-Optimizer
22:16:00 (snpslmd) FPGA-Express-isp3K-Optimizer FPGA-Express-ISP4000-Optimizer FPGA-Express-isp4K-Optimizer
22:16:00 (snpslmd) FPGA-Express-ISP5000-Optimizer FPGA-Express-isp5K-Optimizer FPGA-Express-isp6K-Optimizer
22:16:00 (snpslmd) FPGA-Express-isp7K-Optimizer FPGA-Express-isp8K-Optimizer FPGA-Express-MERCURY-Optimizer
22:16:00 (snpslmd) FPGA-Express-Open-Optimizer FPGA-Express-ORCA2-Optimizer FPGA-Express-ORCA3-Optimizer
22:16:00 (snpslmd) FPGA-Express-Synario-Optimizer FPGA-Express-VHDL-Base FPGA-Express-VHDL-Training
22:16:00 (snpslmd) FPGA-Express-VIRTEX-Optimizer FPGA-Express-VLOG-Base FPGA-Express-XC3k-Optimizer
22:16:00 (snpslmd) FPGA-Express-XC4k-Optimizer FPGA-Express-XC5k-Optimizer FPGA-Express-XC9k-Optimizer
22:16:00 (snpslmd) FPGA-HDL-Bundle ficdr_test/tio        FL_cosim_run
22:16:00 (snpslmd) FL_ice_run        FL_multichip_partition FL_recalc
22:16:00 (snpslmd) Flash370i        FLE_main        FLEX10K
22:16:00 (snpslmd) FLEX10KA        FLEX10KB        FLEX10KE
22:16:00 (snpslmd) FLEX6000        FLEX8000        Floops-1D_all
22:16:00 (snpslmd) Floops-1D-MC_all Floops-2D_all        Floops-2D-MC_all
22:16:00 (snpslmd) Floops-3D_all        Floops-3D-MC_all Floops-Parallel_all
22:16:00 (snpslmd) Floops-Parallel4_all Floorplan-Management Formality
22:16:00 (snpslmd) Formality-DV        Formality-E1        Formality-TransForm
22:16:00 (snpslmd) Formality-Transit FPABP                FPDP
22:16:00 (snpslmd) FPGA_Express-APROA-Optimizer FPGA-Compiler        FPGA-Express
22:16:00 (snpslmd) FPGA-Express-32OODx-Optimizer FPGA-Express-A1200XL-Optimizer FPGA-Express-A1400-Optimizer
22:16:00 (snpslmd) FPGA-Express-A3200DX-Optimizer emw-uniform-2d_all emw-uniform-3d_all
22:16:00 (snpslmd) ENACE                ENACS                encore
22:16:00 (snpslmd) encrypt                Enterprise        Enterprise_VO
22:16:00 (snpslmd) Equation-Reader Equation-Writer Espresso-Reader
22:16:00 (snpslmd) Espresso-Writer EssentialSignalAnalysis Estm-HDL-Advisor
22:16:00 (snpslmd) Estm-HDL-Advisor-Package etran                EV-ACCESS
22:16:00 (snpslmd) EV-ACCESS_UTIL        Eview                eX
22:16:00 (snpslmd) example_feature EXCALIBUR_ARM        EXCALIBUR_MIPS
22:16:00 (snpslmd) Extraction        FCII-Altera-Edition FCO
22:16:00 (snpslmd) features        ficdr_test        ficdr_test/gds
22:16:00 (snpslmd) ficdr_test/goa        ficdr_test/io        ficdr_test/nc
22:16:00 (snpslmd) ficdr_test/poly ficdr_test/size ficdr_test/sizeOr
22:16:00 (snpslmd) ficdr_test/stmp DW-IP-Consultant DW-IP-DEBUG
22:16:00 (snpslmd) DW-IP-Developer E5                E502
22:16:00 (snpslmd) E505                E520                Early-Access-Technology
22:16:00 (snpslmd) ECL-Compiler        ECO-Compiler        edif2e
22:16:00 (snpslmd) EDIF-Netlist-Read-DC EDIF-Netlist-Write-DC EDIF-Netlist-Writer
22:16:00 (snpslmd) EDIF-Reader        EDIF-Schematic-Writer electromigration_drc
22:16:00 (snpslmd) ELGRECO_Davis        ELGRECO_DesignCenter ELGRECO_Simulator
22:16:00 (snpslmd) Emlab_all        Emlab-Dessis_all Emlab-Farfield_all
22:16:00 (snpslmd) Emlab-Nonuniform-2D_all Emlab-Nonuniform-3D_all Emlab-Static_all
22:16:00 (snpslmd) Emlab-Thermal_all Emlab-Uniform-2D_all Emlab-Uniform-3D_all
22:16:00 (snpslmd) emw_all                emw-farfield_all emw-nonuniform-2d_all
22:16:00 (snpslmd) emw-nonuniform-3d_all emw-sdevice_all emw-static_all
22:16:00 (snpslmd) emw-thermal_all Dessis-Optic_all Dessis-Parallel_all
22:16:00 (snpslmd) Dessis-Parallel4_all Dessis-PMI_all        Dessis-Radiation_all
22:16:00 (snpslmd) Dessis-Reliability_all Dessis-Schroedinger_all Dessis-SiGe_all
22:16:00 (snpslmd) Dessis-Thermo_all Dessis-Traps_all Dessis-VectorOptic_all
22:16:00 (snpslmd) Devise_all        Devise-3D_all        Dfisetools_all
22:16:00 (snpslmd) Dfisetools-Topo_all Dios_all        Dios-3D_all
22:16:00 (snpslmd) Dios-MC_all        Dios-PDEF_all        Dios-SDO_all
22:16:00 (snpslmd) DiosSmall_all        Dip_all                DIRECTMEM
22:16:00 (snpslmd) DS-Schem-Gen        DS-Schem-Gen-Estimator-Pa DS-Schem-Gen-Estimator-Package
22:16:00 (snpslmd) DS-Schem-Gen-Package DS-Verinet        DS-Verinet-Estimator-Pack
22:16:00 (snpslmd) DS-Verinet-Estimator-Package DS-Verinet-Package DS-Vhdlnet
22:16:00 (snpslmd) DS-Vhdlnet-Estimator-Pack DS-Vhdlnet-Estimator-Package DS-Vhdlnet-Package
22:16:00 (snpslmd) DW-Developer        DesignWare-MPEG2 DesignWare-MPEG2-Source
22:16:00 (snpslmd) DesignWare-MPEG2-VDEC DesignWare-MPEG2-VDEC-Source DesignWare-MPEG-Source
22:16:00 (snpslmd) DesignWare-Package DesignWare-PCI        DesignWare-PCIbasic
22:16:00 (snpslmd) DesignWare-PCI-Source DesignWare-PCI-X DesignWare-PCI-X-Source
22:16:00 (snpslmd) DesignWare-SystemIO DesignWare-SystemIO-Source DesignWare-TCA
22:16:00 (snpslmd) DesignWare-TCA-Source DesignWare-USB        DesignWare-USB2
22:16:00 (snpslmd) DesignWare-USB2-Source DesignWare-USB-Source DesignWare-VERA
22:16:00 (snpslmd) Dessis_all        Dessis-3D_all        Dessis-BONSIM_all
22:16:00 (snpslmd) Dessis-DensityGrad_all Dessis-Ferro_all Dessis-FloatingGate_all
22:16:00 (snpslmd) Dessis-GateLeakage_all Dessis-Hetero_all Dessis-Hydro_all
22:16:00 (snpslmd) Dessis-kpGain_all Dessis-Laser_all Dessis-LED_all
22:16:00 (snpslmd) Dessis-MixedMode_all Dessis-Mono-Semicond_all Dessis-MonteCarlo_all
22:16:00 (snpslmd) Dessis-Noise_all Design-Budgeting Design-Compiler
22:16:00 (snpslmd) Design-Estimator Design-Estimator-FPI DesignSource
22:16:00 (snpslmd) DesignSource-Estimator-Package DesignSource-Package DesignTime
22:16:00 (snpslmd) Design-Vision        DesignWare        DesignWare-1394
22:16:00 (snpslmd) DesignWare-1394-Source DesignWare-6811-Source DesignWare-8051
22:16:00 (snpslmd) DesignWare-8051MCU DesignWare-8051-Source Designware-Basic
22:16:00 (snpslmd) DesignWare-BIST DesignWare-BIST-Source DesignWare-Cardbus
22:16:00 (snpslmd) Designware-Developer DesignWare-Developer-MGI DesignWare-ETHERNET-Source
22:16:00 (snpslmd) DesignWare-FloatingPoint DesignWare-Foundation DesignWare-Foundation-Exp
22:16:00 (snpslmd) DesignWare-Foundation-Expert DesignWare-Foundation-Power DesignWare-Foundation-Ultra
22:16:00 (snpslmd) Designware-FPGA-Basic DesignWare-ISA-PnP DesignWare-MemoryBist
22:16:00 (snpslmd) DesignWare-MemoryBist-Source DesignWare-MGI        DesignWare-MPEG
22:16:00 (snpslmd) Cyclone-Elaborator Cyclone-GUI        Cyclone-HDL-Analyzer
22:16:00 (snpslmd) Cyclone-Simulator Cyclone-VHDL-Analyzer CYPRESS
22:16:00 (snpslmd) DataExpansion        DataExpansionCoverage DataExpansionSim
22:16:00 (snpslmd) DATAIO                DataReplay        DataReplaySim
22:16:00 (snpslmd) DC64                DC-Beta                DC-Cadence-Interface
22:16:00 (snpslmd) DC-Expert        DCExpert-PrimeTime DC-Falcon-Interface
22:16:00 (snpslmd) DC-FPGA-Accelerator DC-FPGA-Add-On        DC-FPGA-Features
22:16:00 (snpslmd) DC-Layout-Interface DCM-Delay-Calculation DC-Min-Area-Retime
22:16:00 (snpslmd) DC-SDF-Interface DC-Ultra        DC-Ultra-Features
22:16:00 (snpslmd) DC-Ultra-Opt        DC-XG                Debussy
22:16:00 (snpslmd) Debussy_shared        delaymill        Delta39k
22:16:00 (snpslmd) DEMO                Design-Analyzer Design-Analyzer-DAP
22:16:00 (snpslmd) COSSAP_matlab        COSSAP_mfd        COSSAP_mpeg2
22:16:00 (snpslmd) COSSAP_pdc        COSSAP_qed        COSSAP_sds
22:16:00 (snpslmd) COSSAP_srcfd        COSSAP_vcg_generic COSSAP_vcg_synopsys
22:16:00 (snpslmd) COSSAP_vcg_vantage COSSAP_vdefcg        COSSAP_vdefcg_vlgxl
22:16:00 (snpslmd) COSSAP_vsiccg        COSSAP_vsiccg_cyc COSSAP_vsiccg_mti
22:16:00 (snpslmd) COSSAP_vsiccg_mtivlg COSSAP_vsiccg_vcs COSSAP_vsiccg_vlgxl
22:16:00 (snpslmd) COSSAP_vsivcg        COSSAP_vsivcg_vlgxl COSSAP_xdcg
22:16:00 (snpslmd) COSSAP_xvcg        COSSAP_xvsi        CoverMeter
22:16:00 (snpslmd) CoverMeterOBC        CoverMeterOBCVCSAMSCompiler CPI-100
22:16:00 (snpslmd) CRS_COVERMETER        CRS_VCM                CRS_VCS
22:16:00 (snpslmd) CRS_VCSi        CTV-Interface        CUSTOM_LIB
22:16:00 (snpslmd) Cyclone-Code-Generator Cyclone-Core        Cyclone-cosim
22:16:00 (snpslmd) COSSAP_cw_filter_sds COSSAP_dab        COSSAP_dcg_ad21020
22:16:00 (snpslmd) COSSAP_dcg_ansic COSSAP_dcg_ariel32c COSSAP_dcg_fe
22:16:00 (snpslmd) COSSAP_dcg_gc        COSSAP_dcg_krc        COSSAP_dcg_lsic30s
22:16:00 (snpslmd) COSSAP_dcg_m96000 COSSAP_dcg_mp        COSSAP_ddk_arm
22:16:00 (snpslmd) COSSAP_ddk_devlp COSSAP_ddk_dsp16000 COSSAP_ddk_dsp1610
22:16:00 (snpslmd) COSSAP_ddk_hawk COSSAP_ddk_nec        COSSAP_ddk_oak
22:16:00 (snpslmd) COSSAP_ddk_pine COSSAP_ddk_ssp16xx COSSAP_ddk_tic5x
22:16:00 (snpslmd) COSSAP_ddk_tic5xx COSSAP_dect        COSSAP_dvb
22:16:00 (snpslmd) COSSAP_ecc        COSSAP_gsmdve        COSSAP_gsmdve_utils
22:16:00 (snpslmd) COSSAP_gsmefrsc COSSAP_gsmeq        COSSAP_gsmfrcc
22:16:00 (snpslmd) COSSAP_gsmfrsc        COSSAP_gsmhrcc        COSSAP_gsmhrsc
22:16:00 (snpslmd) COSSAP_gsmphy        COSSAP_is136        COSSAP_is95
22:16:00 (snpslmd) CoCentric-SYS-Davis CoCentric-SYS-DesignCenter CoCentric-SYS-HWflow
22:16:00 (snpslmd) CoCentric-SYS-HWSimIF CoCentric-SYS-RDK-adsl CoCentric-SYS-RDK-cdma2000
22:16:00 (snpslmd) CoCentric-SYS-RDK-docsis CoCentric-SYS-Simulator Columbia
22:16:00 (snpslmd) ColumbiaTE        COMPONENT_LIBRARY Constraint_Translation
22:16:00 (snpslmd) Converter        COOLRUNNER        COOLRUNNER2
22:16:00 (snpslmd) coreAssembler        coreBuilder        coreConsultant
22:16:00 (snpslmd) coremill        coreSynthesis        COSIM-LFG
22:16:00 (snpslmd) COSIM-MTI        COSIM-NCV        COSIM-SRO
22:16:00 (snpslmd) COSIM-VCS        COSIM-VXL        COSMOS_VO
22:16:00 (snpslmd) COSSAP_adpcm        COSSAP_adsl        COSSAP_amr
22:16:00 (snpslmd) COSSAP_arm        COSSAP_bde        COSSAP_celp
22:16:00 (snpslmd) COSSAP_chart        COSSAP_cw_filter_hdl CBA-Logical-MA
22:16:00 (snpslmd) CBA-Physical-DS CBA-Physical-MA CBA-Transport
22:16:00 (snpslmd) CD-Compiled-Lib-Gen CD-Compiled-Sys-Gen CD-GDI
22:16:00 (snpslmd) CD-GDII-Link        CD-Model-Developer CD-MSSC-Cross-Probe
22:16:00 (snpslmd) CD-MSSC-Netlist CD-Present-Builder CD-Present-Layer-Gen
22:16:00 (snpslmd) CD-REX                cdsaavmx        cdsaawaves
22:16:00 (snpslmd) cdsmetalib        cdsnet                CD-Vhdlgen-Gen
22:16:00 (snpslmd) CD-Vhdlgen-GUI        chipviewer        cmod
22:16:00 (snpslmd) cmod/ax                cmod/cbx        cmod/drc
22:16:00 (snpslmd) cmod/gx                cmod/gxadv        cmod/hdrc
22:16:00 (snpslmd) cmod/hlvs        cmod/ipc        cmod/lvs
22:16:00 (snpslmd) cmod/viewer        CmView                CoCentric-FXD-GUI
22:16:00 (snpslmd) CoCentric-FXD-Interpolator CoCentric-FXD-Simulation avanwaveswin
22:16:00 (snpslmd) awe_rcr                BC-FPGA                BC-FPGA-HDL
22:16:00 (snpslmd) BC-FPGA-VHDL        BC-HDL                BC-Schedule
22:16:00 (snpslmd) BC-VHDL                Behavioral-Analyzer Behavioral-Compiler
22:16:00 (snpslmd) BOA-BRT                c_exe_ax        c_exe_cbx
22:16:00 (snpslmd) c_exe_drc        c_exe_gx        c_exe_ipc
22:16:00 (snpslmd) c_exe_lvs        CA-Chip-Edit        CA-CP-Advanced
22:16:00 (snpslmd) CA-CP-Basic        CA-CP-Standard        cadence
22:16:00 (snpslmd) cadence_epic        CA-Foundation        CA-Frame
22:16:00 (snpslmd) CA-Hier-Timer        CA-Optimization CA-Timer
22:16:00 (snpslmd) CA-Utils        CBA-ApolloGA-Interface CBA-Blk-Export
22:16:00 (snpslmd) CBA-Blk-Import        CBA-CadenceSE-Interface CBA-DS-Beta
22:16:00 (snpslmd) CBA-Frame        CBA-Logical-DS        arc/ppx
22:16:00 (snpslmd) arc/pro                arc/r3x                arc1
22:16:00 (snpslmd) arc2                arcexpert        arcfc
22:16:00 (snpslmd) arcviewer        arcviewer/raph        arcxl
22:16:00 (snpslmd) ARKOS-A                ARKOS-B                ARKOS-C
22:16:00 (snpslmd) ARKOS-D                ARKOS-E                ARKOS-Ice
22:16:00 (snpslmd) ARKOS-Mcomp        ARKOS-Rtlcomp        ARKOS-Scomp
22:16:00 (snpslmd) ARKOS-Simul        ARM7TDMI        Astro
22:16:00 (snpslmd) AstroBeta        AstroExp        Astro-Express
22:16:00 (snpslmd) AstroGA                AstroRail        Astro-Rail
22:16:00 (snpslmd) AstroRailSA        AstroSpecialBeta AstroXtalk
22:16:00 (snpslmd) Astro-Xtalk        ATMEL                ATMWB_ATMLAYER
22:16:00 (snpslmd) ATMWB_UTOPIA        avanwaves        APACM
22:16:00 (snpslmd) APATD                APCS                APDP
22:16:00 (snpslmd) APEX20K                APEX20KC        APEX20KE
22:16:00 (snpslmd) APEXII                APGA4AP                APGACS
22:16:00 (snpslmd) APGADP                APGAHPO                APGApwr
22:16:00 (snpslmd) APGASolar        APGASolarII        APGATime
22:16:00 (snpslmd) APHPO                Apollo                ApolloGA
22:16:00 (snpslmd) APPower                APpwr                APSolar
22:16:00 (snpslmd) APSolarII        APTime                APXtalk
22:16:00 (snpslmd) arc                arc/bcx                arc/c2x
22:16:00 (snpslmd) arc/c3x                arc/cns                arc/dnx
22:16:00 (snpslmd) arc/dpx                arc/gds2        arc/giper
22:16:00 (snpslmd) arc/lefdef        A3200DX                A42MX
22:16:00 (snpslmd) A500K                A54SX                A54SXA
22:16:00 (snpslmd) A7                AARKOS-A        ace_core
22:16:00 (snpslmd) acega                acehdl                acehdl/beta_status
22:16:00 (snpslmd) acehdl/internal_use acehdl_beta        acehdl_gui
22:16:00 (snpslmd) ACEX1K                ACS                ACT2-1200XL
22:16:00 (snpslmd) ACT3                AdvanceCalibration_all AdvancedCalibration_all
22:16:00 (snpslmd) AIM_DEBUG        AIM_DECRYPT        AIM_DEVELOPER
22:16:00 (snpslmd) AIM_ENCRYPT        aiu_foundation        alien2lig_all
22:16:00 (snpslmd) ALTGEN1                ALTGEN2                amat-calib_all
22:16:00 (snpslmd) amga                amps                amps/cso
22:16:00 (snpslmd) amps/pfx        amps/tr                AN-Impl3D_all
22:16:00 (snpslmd) any_technology
22:16:00 (snpslmd)
22:16:00 (snpslmd) Licenses are case sensitive for TE_CATS
22:16:00 (snpslmd)
22:16:00 (snpslmd) EXTERNAL FILTERS are OFF
22:16:00 (lmgrd) snpslmd using TCP-port 45297
22:16:00 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  archprod  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  sandwork  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9  ssilmd  synopsysd  tmald  vcsd
22:16:01 (snpslmd) ------------------------------------------------------------------
22:16:01 (snpslmd) Checking the integrity of the license file....
22:16:01 (snpslmd) Valid SSS feature found.
22:16:01 (snpslmd) The feature is needed to enable the other keys in your license file.
22:16:24 (snpslmd) TCP_NODELAY NOT enabled
my lmstat report is below
lmstat - Copyright (c) 1989-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
Flexible License Manager status on Wed 1/27/2016 22:16
License server status: 27000@jithin-vm
    License file(s) on jithin-vm: /usr/synopsys/synopsys.dat:
jithin-vm: license server UP (MASTER) v10.8
Vendor daemon status (on jithin-vm):
   snpslmd: UP v10.8
my .bashrc file is below
export SYNOPSYS=/usr/synopsys
export SNPSLMD_LICENSE_FILE=27000@jithin-vm
export LM_LICENSE_FILE=/usr/synopsys/synopsys.dat
export SCL_HOME=/usr/synopsys/10.9.3/linux
export PATH=$SCL_HOME/binPATH
export ICC_HOME=/usr/synopsys/E-2010.12
export PATH=$ICC_HOME/binPATH
alias lmli3="/usr/synopsys/10.9.3/linux/bin/lmgrd -c /usr/synopsys/synopsys.dat -l ou5.log"
alias lmst3="/usr/synopsys/10.9.3/linux/bin/lmstat -c /usr/synopsys/synopsys.dat"
alias dc="dc_shell &"
alias icc="icc_shell -gui &"
After sourcing .bashrc file I got below error when I type icc_shell.
Unable to obtain features 'Galaxy-Common Galaxy-ICC ' because:
Error: Cannot open key file '/usr/synopsys/E-2010.12/admin/license/key' or a licensing environment parameter has not been set correctly. (SEC-2)
Fatal: Galaxy-Common+Galaxy-ICC is not enabled. (DCSH-1)
Exit IC Compiler!
why this happens? Please help me
发表于 2021-8-24 12:46:33 | 显示全部楼层
thanks for all the files and sharing
GMT+8, 2025-12-26 03:36 , Processed in 0.030152 second(s), 5 queries , Gzip On, Redis On.
