查看: 5943|回复: 4
[求助] 【急!求助】ISE impact下载程序,出现Can not find cable
发表于 2016-7-26 13:36:47 | 显示全部楼层 |阅读模式
电脑重启之后,突然发现impact下不了程序了,将ISE重装过几次也没有用
// *** BATCH CMD : setCable -port auto
AutoDetecting cable. Please wait.
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
Driver file xusb_xlp.sys found.
Driver version: src=1029, dest=1029.
Driver windrvr6.sys version = 11.7.0.0. WinDriver v11.7.0 Jungo Connectivity (c) 1997 - 2014 Build Date: Oct 26 2014 X86 32bit SYS 09:05:06, version = 1170.
Invalid device driver license.
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
PROGRESS_END - End Operation.
Elapsed time =      2 sec.
Cable autodetection failed.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
发表于 2016-7-26 17:14:52 | 显示全部楼层
换下载器?
硬件是否供电正常?
 楼主| 发表于 2016-7-27 11:56:01 | 显示全部楼层
下载器换过也不行,硬件板在其他同学的电脑上试过能下载
发表于 2016-7-27 13:29:30 | 显示全部楼层
貌似电脑驱动出问题了吧
 楼主| 发表于 2016-7-28 11:01:24 | 显示全部楼层
非常感谢,问题已解决,确实是驱动出问题
GMT+8, 2025-12-29 07:29 , Processed in 0.017723 second(s), 6 queries , Gzip On, Redis On.
