查看: 32681|回复: 40
[求助] 求助synopsis 破解license
发表于 2016-1-25 11:20:02 | 显示全部楼层 |阅读模式
虚拟机centos7 里面安装完synopsys软件破解的时候老是不行。求帮助。。。。
验证license
[LiBz@Layout004 bin]$ sssverify /exapp/synopsys/license/synopsys.dat
Integrity check report for license file "/exapp/synopsys/license/synopsys.dat".
Report generated on 25-Jan-2016 (SCL_11.9)
Checking the integrity of the license file...
No SSS or SSST features were found in the license file.
All revenue keys ("SN=RK:..." on feature line) have been excluded.
Siteid: <No Site Id>, Server Hostid: 080027622146, Issued on: N/A
License file integrity check FAILED!
This is an INVALID license file. You SHOULD NOT use this license file.
Please use the license file as received from Synopsys, Inc.
我的license开头
SERVER localhost.localdomain 080027622146  27000
DAEMON snpslmd /exapp/synopsys/scl/amd64/bin/snpslmd
USE_SERVER
INCREMENT SSS snpslmd 1.0 31-dec-2020 uncounted 5EB523336969F6B5A73B \
        VENDOR_STRING="4632b b746a 85d97 583cb e754c 615b8 32c90 1ff55 \
        e6b1e 102" HOSTID=080027622146 ISSUER="Synopsys Inc. [12/28/2012 \
        10:00:00 19688]" NOTICE="Licensed to mammoth//ZWT 2006 [PLEASE DO \
        NOT DELETE THIS SSS KEY]" SN=RK:0:0:1 START=1-jan-2006
PACKAGE EFA_Synopsys_1 snpslmd 2019.12 50A0405169FA0249B11C COMPONENTS="A3200DX A42MX A500K A54SX \
        A54SXA A7 AIM_DEBUG AIM_DEBUG_MEMSSE AIM_DECRYPT AIM_DEVELOPER AIM_DEVELOPER_MEMSSE \
        AIM_ENCRYPT ALTGEN1 ALTGEN2 AN-Impl3D AN-Impl3D_all AN-Impl3D_ise AN-Impl3D_ise_all APACM \
        APATD APCS APDP APEX20K APEX20KC APEX20KE APEXII APGA4AP APGACS APGADP APGAHPO APGASolar \
虚拟机的hostid
lmhostid - Copyright (c) 1989-2014 Flexera Software LLC. All Rights Reserved.
The FlexNet host ID of this machine is ""080027d0f1f4 080027622146""
Only use ONE from the list of hostids.
自己生成了好几遍的license都不行。。。被卡了好几天啊!!求破~~~
还有我打开installer3.2或者3.0的时候,终端都会弹出一句
ypcat: can't get local yp domain: Local domain name not set
会不会是这个问题引起的??
试了http://bbs.eetop.cn/thread-465161-1-1.html他的licese也不行。。
 楼主| 发表于 2016-1-25 11:23:21 | 显示全部楼层
我已经试过改端口,改 localhost.localdomain,重装等等。。
 楼主| 发表于 2016-1-25 11:50:39 | 显示全部楼层
重新生成了一下licese
SSS or SSST features可以找到了
但是还是通不过,提示:
····(省略)
7ff298bd0000-7ff298dd0000 ---p 0000c000 08:02 131117                     /lib64/libnss_files-2.12.so
7ff298dd0000-7ff298dd1000 r--p 0000c000 08:02 131117                     /lib64/libnss_files-2.12.so
7ff298dd1000-7ff298dd2000 rw-p 0000d000 08:02 131117                     /lib64/libnss_files-2.12.so
7ff298de3000-7ff298de9000 rw-p 00000000 00:00 0
7ff298df7000-7ff298dfb000 rw-p 00000000 00:00 0
7fffc0fe4000-7fffc0ffa000 rw-p 00000000 00:00 0                          [stack]
7fffc0ffc000-7fffc0ffd000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
Aborted (core dumped)
发表于 2016-1-31 22:36:46 | 显示全部楼层
我给你一个license把
 楼主| 发表于 2016-2-1 17:13:04 | 显示全部楼层
回复 4# davisleey
谢谢啊,我已经解决了。
感谢你的热心帮助。
发表于 2016-2-24 21:35:54 | 显示全部楼层
楼主 你的问题是怎么解决的?我也遇到了同样的问题
 楼主| 发表于 2016-2-25 09:06:07 | 显示全部楼层
1
1:curse:
 楼主| 发表于 2016-2-25 09:07:48 | 显示全部楼层
回复 6# nxl_sdu
    bashrc
# .bashrc
# Source global definitions
if [ -f /etc/bashrc ]; then
    . /etc/bashrc
fi
# User specific aliases and functions
############### IC5141
CDS_DIR=/usr/local/ic5141/IC5141USR5
CDS_ROOT=$CDS_DIR
CDS_INST_DIR=$CDS_DIR
CDS_INSTALL_DIR=$CDS_DIR/tools/dfII
export CDS_LIC_FILE=$CDS_ROOT/share/license/license.dat
export PATH=$PATHCDS_INST_DIR/tools/binCDS_INST_DIR/tools/dfII/binCDS_INST_DIR/tools/spectre/bin:$CDS_INST_DIR/tools/plot/bin:$CDS_INST_DIR/tools/dracula/bin
export CDS_Netlisting_Mode=Analog
export LD_ASSUME_KERNEL=2.6.32
############### ius92
IUS_HOME=/usr/local/ius92/IUS92
export PATH=$PATH:$IUS_HOME/tools/verilog/bin:$IUS_HOME/tools/bin:$IUS_HOME/tools/dfII/bin:$IUS_HOME/tools/spectre/bin
export LD_LIBRARY_PATH=$CDS_ROOT/tools/lib:$CDS_ROOT/tools/dfII/lib:$CDS_ROOT/tools/tcltk/tcl8.0/lib:$CDS_ROOT/tcltk/tk8.0/lib:$IUS_HOME/tools/verilog/lib:$IUS_HOME/tools/lib:$LD_LIBRARY_PATH
export LM_LICENSE_FILE=$IUS_HOME/license/license.dat
############## calibre
export MGC_HOME=/usr/local/mentor/ixl_cal_2011.2_34.26
export CALIBRE_HOME=$MGC_HOME
export MGLS_LICENSE_FILE=$MGC_HOME/lic/license.dat
export PATH=$CALIBRE_HOME/bin:$PATH
############## synopsys
# lmstat & lmrgd
export PATH="/usr/local/synopsys/scl/scl11.7/amd64/bin:"$PATH
alias lmli2="lmstat -c /usr/local/synopsys/license/synopsys.dat"
alias lmli1="lmgrd -c /usr/local/synopsys/license/synopsys.dat -l /usr/local/synopsys/license/lmgrd.log"
export VCS_ARCH_OVERRIDE=linux
export DISPLAY=unix:0
# dc & icc & pt & hspice & simif
export PATH="/usr/local/synopsys/dc/dc2013/bin:"$PATH
export PATH="/usr/local/synopsys/icc/icc2013/bin:"$PATH
export PATH="/usr/local/synopsys/pt/pt2013/bin:"$PATH
export PATH="/usr/local/synopsys/hspice/hspice2013/hspice/bin:"$PATH
export PATH="/usr/local/synopsys/simif/simif2013/bin:"$PATH
#set home directory
export SYNOPSYS="/usr/local/synopsys"
export DC_HOME="/usr/local/synopsys/dc/dc2013"
export ICC_HOME="/usr/local/synopsys/icc/icc2013"
export PT_HOME="/usr/local/synopsys/pt/pt2013"
export CDS_LOAD_ENV=CSF
export HSP_HOME="/usr/local/synopsys/hspice/hspice2013/hspice"
export SIMIF_HOME="/usr/local/synopsys/simif/simif2013"
# license_file
export SNPSLMD_LICENSE_FILE=27005@Dell7720
export LM_LICENSE_FILE=/usr/local/synopsys/license/synopsys.dat
# alias
alias dc="dc_shell&"
alias dv="design_vision&"
alias icc="icc_shell -gui&"
alias pt="primetime&"
alias hspice="hspice64&"
alias simif="simif64&"
 楼主| 发表于 2016-2-25 09:17:12 | 显示全部楼层
回复 6# nxl_sdu
    本来打算上次license和bashrc的。。。居然需要审核。
发表于 2016-2-25 11:17:51 | 显示全部楼层
楼主求助啊。。。和你一样的问题,你最后是怎么解决的哈,能讲一下关键吗,谢谢
GMT+8, 2025-12-24 18:34 , Processed in 0.026761 second(s), 5 queries , Gzip On, Redis On.
