楼主: lbz053273
[求助] 求助synopsis 破解license
发表于 2016-2-25 11:50:50 | 显示全部楼层
只求bashrc和license。。。如果可以的话,能麻烦传到网盘吗,谢谢
 楼主| 发表于 2016-2-25 14:29:02 | 显示全部楼层
回复 11# 802.11
############### IC5141
CDS_DIR=/usr/local/ic5141/IC5141USR5
CDS_ROOT=$CDS_DIR
CDS_INST_DIR=$CDS_DIR
CDS_INSTALL_DIR=$CDS_DIR/tools/dfII
export CDS_LIC_FILE=$CDS_ROOT/share/license/license.dat
export PATH=$PATHCDS_INST_DIR/tools/binCDS_INST_DIR/tools/dfII/binCDS_INST_DIR/tools/spectre/bin:$CDS_INST_DIR/tools/plot/bin:$CDS_INST_DIR/tools/dracula/bin
export CDS_Netlisting_Mode=Analog
export LD_ASSUME_KERNEL=2.6.32
############### ius92
IUS_HOME=/usr/local/ius92/IUS92
export PATH=$PATH:$IUS_HOME/tools/verilog/bin:$IUS_HOME/tools/bin:$IUS_HOME/tools/dfII/bin:$IUS_HOME/tools/spectre/bin
export LD_LIBRARY_PATH=$CDS_ROOT/tools/lib:$CDS_ROOT/tools/dfII/lib:$CDS_ROOT/tools/tcltk/tcl8.0/lib:$CDS_ROOT/tcltk/tk8.0/lib:$IUS_HOME/tools/verilog/lib:$IUS_HOME/tools/lib:$LD_LIBRARY_PATH
export LM_LICENSE_FILE=$IUS_HOME/license/license.dat
############## calibre
export MGC_HOME=/usr/local/mentor/ixl_cal_2011.2_34.26
export CALIBRE_HOME=$MGC_HOME
export MGLS_LICENSE_FILE=$MGC_HOME/lic/license.dat
export PATH=$CALIBRE_HOME/bin:$PATH
############## synopsys
# lmstat & lmrgd
export PATH="/usr/local/synopsys/scl/scl11.7/amd64/bin:"$PATH
alias lmli2="lmstat -c /usr/local/synopsys/license/synopsys.dat"
alias lmli1="lmgrd -c /usr/local/synopsys/license/synopsys.dat -l /usr/local/synopsys/license/lmgrd.log"
export VCS_ARCH_OVERRIDE=linux
export DISPLAY=unix:0
# dc & icc & pt & hspice & simif
export PATH="/usr/local/synopsys/dc/dc2013/bin:"$PATH
export PATH="/usr/local/synopsys/icc/icc2013/bin:"$PATH
export PATH="/usr/local/synopsys/pt/pt2013/bin:"$PATH
export PATH="/usr/local/synopsys/hspice/hspice2013/hspice/bin:"$PATH
export PATH="/usr/local/synopsys/simif/simif2013/bin:"$PATH
#set home directory
export SYNOPSYS="/usr/local/synopsys"
export DC_HOME="/usr/local/synopsys/dc/dc2013"
export ICC_HOME="/usr/local/synopsys/icc/icc2013"
export PT_HOME="/usr/local/synopsys/pt/pt2013"
export CDS_LOAD_ENV=CSF
export HSP_HOME="/usr/local/synopsys/hspice/hspice2013/hspice"
export SIMIF_HOME="/usr/local/synopsys/simif/simif2013"
# license_file
export SNPSLMD_LICENSE_FILE=27005@Dell7720
export LM_LICENSE_FILE=/usr/local/synopsys/license/synopsys.dat
# alias
alias dc="dc_shell&"
alias dv="design_vision&"
alias icc="icc_shell -gui&"
alias pt="primetime&"
alias hspice="hspice64&"
alias simif="simif64&"
 楼主| 发表于 2016-2-25 14:35:47 | 显示全部楼层
回复 11# 802.11
    http://pan.baidu.com/s/1pKpPPpD
tdyt
 楼主| 发表于 2016-2-25 14:36:34 | 显示全部楼层
回复 11# 802.11
    木有办法了,连发个网盘地址都要审核。
 楼主| 发表于 2016-2-25 14:37:53 | 显示全部楼层
回复 11# 802.11
    http:【试试】//【试试】pan.baidu.com/s/【试试】1pKpPPpD
【试试】tdyt【试试】
 楼主| 发表于 2016-2-25 14:38:51 | 显示全部楼层
回复 6# nxl_sdu
【试试】tdyt【试试】
去掉【试试】。
发表于 2016-2-25 15:07:04 | 显示全部楼层
谢谢!
发表于 2016-3-25 10:52:31 | 显示全部楼层
楼主,我的也不行哈, sss能查到,但是  check failed redhat6.5 64
发表于 2016-4-19 18:58:20 | 显示全部楼层
楼主 我的也遇到相同问题 但你发的网盘已经 不存在 能再发一次吗 谢谢
发表于 2016-4-27 21:34:10 | 显示全部楼层
回复 4# davisleey
求分享下license啊
GMT+8, 2025-12-30 16:15 , Processed in 0.020315 second(s), 5 queries , Gzip On, Redis On.
