查看: 4298|回复: 1
FPGA,xilinx,edk利用lwip协议实现以太网数据传输,xemac_add()处停止,没有报错
发表于 2016-1-11 09:23:13 | 显示全部楼层 |阅读模式
运行时老是停在xemac_add(echo_netif, &ipaddr, &netmask,&gw, mac_ethernet_address,PLATFORM_EMAC_BASEADDR)部分,在debug下调试,没有报错,也没有现象,求大神解救
  1. #include <stdio.h>
  2. #include "xparameters.h"
  3. #include "netif/xadapter.h"
  4. #include "platform.h"
  5. #include "platform_config.h"
  6. #ifdef __arm__
  7. #include "xil_printf.h"
  8. #endif
  9. /* defined by each RAW mode application */
  10. void print_app_header();
  11. int start_application();
  12. int transfer_data();
  13. /* missing declaration in lwIP */
  14. void lwip_init();
  15. static struct netif server_netif;
  16. struct netif *echo_netif;
  17. void
  18. print_ip(char *msg, struct ip_addr *ip)
  19. {
  20.         print(msg);
  21.         xil_printf("%d.%d.%d.%d\n\r", ip4_addr1(ip), ip4_addr2(ip),
  22.                         ip4_addr3(ip), ip4_addr4(ip));
  23. }
  24. void
  25. print_ip_settings(struct ip_addr *ip, struct ip_addr *mask, struct ip_addr *gw)
  26. {
  27.         print_ip("Board IP: ", ip);
  28.         print_ip("Netmask : ", mask);
  29.         print_ip("Gateway : ", gw);
  30. }
  31. int main()
  32. {
  33.         struct ip_addr ipaddr, netmask, gw;
  34.         /* the mac address of the board. this should be unique per board */
  35.         unsigned char mac_ethernet_address[] =
  36.         { 0x00, 0x0a, 0x35, 0x00, 0x01, 0x02 };
  37.         echo_netif = &server_netif;
  38.         init_platform();
  39.         /* initliaze IP addresses to be used */
  40.         IP4_ADDR(&ipaddr,  192, 168,   1, 10);
  41.         IP4_ADDR(&netmask, 255, 255, 255,  0);
  42.         IP4_ADDR(&gw,      192, 168,   1,  1);
  43.         print_app_header();
  44.         print_ip_settings(&ipaddr, &netmask, &gw);
  45.         lwip_init();
  46.           /* Add network interface to the netif_list, and set it as default */
  47.         if (!xemac_add(echo_netif, &ipaddr, &netmask,
  48.                                                 &gw, mac_ethernet_address,
  49.                                                 PLATFORM_EMAC_BASEADDR)) {
  50.                 xil_printf("Error adding N/W interface\n\r");
  51.                 return -1;
  52.         }
  53.         netif_set_default(echo_netif);
  54.         /* Create a new DHCP client for this interface.
  55.          * Note: you must call dhcp_fine_tmr() and dhcp_coarse_tmr() at
  56.          * the predefined regular intervals after starting the client.
  57.          */
  58.         /* dhcp_start(echo_netif); */
  59.         /* now enable interrupts */
  60.         platform_enable_interrupts();
  61.         /* specify that the network if is up */
  62.         netif_set_up(echo_netif);
  63.         /* start the application (web server, rxtest, txtest, etc..) */
  64.         start_application();
  65.         /* receive and process packets */
  66.         while (1) {
  67.                 xemacif_input(echo_netif);
  68.                 transfer_data();
  69.         }
  70.
  71.         /* never reached */
  72.         cleanup_platform();
  73.         return 0;
  74. }
  75.
    复制代码
发表于 2016-9-27 16:37:02 | 显示全部楼层
最近正在做这个,不知道你的问题解决了吗?
GMT+8, 2025-12-20 09:01 , Processed in 0.025369 second(s), 8 queries , Gzip On, Redis On.
