set_pin_physical_constraints -pin_name {ARADDR} -layers {metal3} -width 0.05 -depth 0.05 -side 3 -order 1上面这个命令中,-depth是什么意思?是金属层厚度吗?这个值怎么定呢?
没看懂man说的:
-depth pin_depth
Specifies the depth in microns. If the depth constraint specified is smaller than minLength defined in the tech file, then the value of minLength will be honored. If minArea is also defined in the tech file, then the value of pin depth times pin width should also honor minArea. The default is 0. |
