我用hspice2010和2014跑demo文件夹里的示例,resistor和opamp都试了,失败。
以下是部分信息:
Parsing 'aa.va'
Parsing include file '/home/zhangzimou/software/Hspice/synopsys/hspice2014/hspice/include/disciplines.vams'
End of pVA compiling on Thu Oct 22 20:34:07 2015 GTM/In-use: 0.5000/0.4590 MB
End of build pVA DB on Thu Oct 22 20:34:07 2015 GTM/In-use: 1.3750/1.3227 MB
*pvaI* Module (aa): 2 unexpanded port, 0 init, 1 behav, 1 contrib, 11/0 expr(s)
*pvaI* No DIS, 0/0 afCount, 0 MT, dlg
*pvaI* 1 const-G and 0 const-C, No switchBranch, 22 bypassOpt
*pvaI* generated 0 flow node(s) during compilation.
**error** Failed to read Verilog-A file, see 'aa.valog' file for details.
**error** (aa.sp:2) difficulty in reading input
***** job aborted
以下是valog里的部分信息:
*pvaE* pVA created an intermeidate Bad C code from Verilog-A module
*pvaE* Bad C code detected by gcc
*pvaE* See details in aa.pvadir/pvaRTL.log,
*pvaE* 1. Contact system admin to install /usr/lib/crti.o
*pvaE* If error message '/usr/bin/ld: crti.o: No such file or directory'
*pvaE* collect2: ld returned 1 exit status in pvaRTL.log
*pvaE* 2. Run 64-bit platform or contact system admin to install /usr/include/gnu/stubs-32.h
*pvaE* If error message '/usr/include/gnu/stubs.h:7:27:'
*pvaE* fatal error: gnu/stubs-32.h: No such file or directory compilation terminated.
*pvaE* make: *** [all] Error 1
*pvaE* 3. Rerun with 'setenv PVA_GCC_FLAGS_O0 1 or setenv PVA_GCC_FLAGS_G 1'
*pvaE* If error message 'gcc: Internal error: Segmentation fault (program cc1)', or
*pvaE* 'gcc: Internal error: CPU time limit exceeded (program cc1)'
*pvaE* If error messages do not show, please contact Synopsys, Inc. technical support center.
请问是哪里出错了?我查了好多资料,都没有解决这个问题。 |
