查看: 3956|回复: 2
[求助] vivado的一个implementation warning
发表于 2015-10-13 10:30:42 | 显示全部楼层 |阅读模式
工具用的vivado,所有的输入差分信号实现时都报了类似如下的错误:
[Drc 23-20] Rule violation (PORTPROP-2) selectio_diff_term - The port sys_clk_n[0:0] has an invalid DIFF_TERM property value. For the target architecture, IOSTANDARD value DIFF_SSTL15 does not support on-chip input differential termination. The DIFF_TERM property value will be ignored.
[Drc 23-20] Rule violation (PORTPROP-2) selectio_diff_term - The port sys_clk_p[0:0] has an invalid DIFF_TERM property value. For the target architecture, IOSTANDARD value DIFF_SSTL15 does not support on-chip input differential termination. The DIFF_TERM property value will be ignored.
不知道到底是什么原因,要怎样修改?
发表于 2015-10-13 23:38:42 | 显示全部楼层
字面意思理解,应该是输入的差分时钟使用了输入匹配电阻。建议检查一下差分模块例化参数和约束文件
 楼主| 发表于 2015-10-14 09:23:48 | 显示全部楼层
回复 2# zhangweizhuang
找到了,我之前对于IBUFGDS的例化里有DIFF_TERM这个参数:
IBUFGDS #(
.DIFF_TERM("TRUE"),
.IBUF_LOW_PWR("TRUE")
) IBUFGDS_inst2 (
.O(clk_in_buf),
.I(clk_p_dram),
.IB(clk_n_dram)
.DIFF_TERM("TRUE")改成"FALSE"后就不报错了。
谢谢!
GMT+8, 2025-12-29 11:00 , Processed in 0.014116 second(s), 6 queries , Gzip On, Redis On.
