查看: 1938|回复: 0
[招聘] 招聘验证工程师
发表于 2015-10-12 10:01:40 | 显示全部楼层 |阅读模式
本公司(外企-设计服务)急招验证工程师,待遇丰厚。感兴趣可发送简历至cissy_pq@163.com (工作地点:上海)
Senior Verification Engineer
Common:
1)
Familiar with system Verilog and UVM methodology
2)
Familiar with UNIX/Linux shell
3)
Familiar with Perl script
4)
Provide test plan basing on the design spec
5)
Setup the module level and chip level DV environment
6)
RTL simulation and netlist with timing simulation
7)
Implement the test cases basing test plan, and provide the test coverage
8)
Work with design team to repeat the failure case and find out root cause
GMT+8, 2025-12-14 18:54 , Processed in 0.016733 second(s), 6 queries , Gzip On, Redis On.
