查看: 9213|回复: 12
[求助] 后端encounter MINCUT violation
发表于 2015-9-21 20:02:21 | 显示全部楼层 |阅读模式
各位大侠:
我在做Add power stripe和Power routing的时候,有以下警告:
Stripe generation is complete; vias are now being generated.
Multi-CPU acceleration using 20 CPU(s).
**WARN: ViaGen Warning: MINCUT rule violation, no via created:
layer V4 at (3884.95, 2914.33) (3885.14, 2926.33)
**WARN: ViaGen Warning: MINAREA rule violation, no via created:
layer M5 at (3887.60, 4639.00) (3887.60, 4651.00)
layer M5 at (1757.60, 348.04) (1757.60, 360.04)
layer M5 at (1757.60, 1742.79) (1757.60, 1754.79)
layer M4 at (1754.10, 3244.25) (1754.10, 3256.25)
layer M5 at (1757.60, 4639.00) (1757.60, 4651.00)
layer M5 at (1770.60, 1755.79) (1770.60, 1767.79)
layer M5 at (1770.60, 3231.25) (1770.60, 3243.25)
我在做Power routing的时候,有以下警告:
sroute post-processing starts at Mon Sep 21 19:53:17 2015
The viaGen is rebuilding shadow vias for net VSS.
layer V2 at (485.60, 360.24) (497.60, 360.46)
layer V2 at (485.60, 461.57) (497.60, 461.84)
layer V2 at (485.60, 451.45) (497.60, 451.76)
layer V2 at (485.60, 441.33) (497.60, 441.68)
layer V2 at (485.60, 502.05) (497.60, 502.16)
layer V2 at (485.60, 491.93) (497.60, 492.08)
layer V2 at (485.60, 481.81) (497.60, 482.00)
layer V2 at (485.60, 471.69) (497.60, 471.92)
layer V2 at (824.43, 360.24) (836.43, 360.46)
layer V2 at (824.43, 461.57) (836.43, 461.84)
请问这个MINCUT是在哪里定义的呢?大部分都是与内部IP block相交时出现的这个警告,请问要怎么让encounter自动连接上,不然后面会报open的问题?由于这个原因,导致上百条都是open的线,手动连接又不方便,谢谢各位大侠!
发表于 2015-9-22 10:55:17 | 显示全部楼层
tech lef里面有的,  你是IP 连什么power? 不行的话手拉(addwire) , sroute只能做较为简单的power route,warning太多自己也看不清的
 楼主| 发表于 2015-9-22 17:01:35 | 显示全部楼层
回复 2# icfbicfb
IP连接core power 1.8V,IP用M3和M4作为power ring,宽度是12um。工艺是M6层的,lef定义的CUT大小如下:
LAYER V1
  TYPE CUT ;
  SPACING 0.26 ;
  AntennaAreaRatio  20 ;
  AntennaDiffAreaRatio PWL ( ( 0 20 ) ( 0.203 20 ) ( 0.204 92.0 ) ( 1 158.33 ) ) ;
END V1
LAYER V2
  TYPE CUT ;
  SPACING 0.26 ;
END V2
LAYER V3
  TYPE CUT ;
  SPACING 0.26 ;
END V3
LAYER V4
  TYPE CUT ;
  SPACING 0.26 ;
END V4
LAYER V5
  TYPE CUT ;
  SPACING 0.35 ;
END V5
发表于 2015-9-23 10:22:40 | 显示全部楼层
有坐标的,去看看,十九是要打via的地方是不完全搭上的情况,最小的via搭不上,具体情况具体对待,可能搭不上也没关系,
发表于 2015-9-23 16:00:59 | 显示全部楼层
在layer 定义里面,如
  MINIMUMCUT 2 WIDTH 1.40 ;
这种语句规定了的, IP连接core pg用手连就好了, sroute控制的不好
 楼主| 发表于 2015-10-8 11:39:45 | 显示全部楼层
回复 4# 王不动
    只要DRC的时候不报error,就不用管它是吗?
 楼主| 发表于 2015-10-8 11:53:09 | 显示全部楼层
回复 5# icfbicfb
我的lef文件里面,有layer 和via的定义,但是没有MINIMUMCUT,只有CUT在via里面有定义。
“IP连接core pg用手连就好了, sroute控制的不好”,你是说在sroute之前对IP block放置size/place/routing blockage,再做sroute,之后手动将IP pg连接到power ring pg上面吗?谢谢!
发表于 2015-10-8 13:56:42 | 显示全部楼层
手工帮ip 做power route的时候 也就取代了部分sroute的功能, sroute包括各种pg route,
比如对macro的,对pad的,对stdcell的, 最实用的也就是followpin连接了,
 楼主| 发表于 2015-10-8 18:56:05 | 显示全部楼层
回复 8# icfbicfb
"手工帮ip 做power route的时候 也就取代了部分sroute的功能, sroute包括各种pg route,
比如对macro的,对pad的,对stdcell的, 最实用的也就是followpin连接了"
如果要手工帮IP做power route的话,是不是在sroute对话框里面进行修改?我把那个blockPin去掉了,还是不行,如下图所示。请问具体是怎么把sroute对IP的power route功能去掉呢?谢谢!
发表于 2015-10-9 09:51:47 | 显示全部楼层
手工就是用editwire ( 按e)来连接的
如果是sroute,你可以一个一个按钮试试,多了什么,比如followpins,pad pins,floating stripes等
GMT+8, 2025-12-21 11:11 , Processed in 0.029501 second(s), 7 queries , Gzip On, Redis On.
