在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2211|回复: 2
[求助] 新手求助,用VHDL实现流水灯
发表于 2015-6-16 20:32:53 | 显示全部楼层 |阅读模式
用vhdl实现流水灯,但是只有固定一位在亮,代码如下,时钟50MHz
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity led_water is
        port(
                        clk                :        in                std_logic;
                        output        :        out        std_logic_vector(3 downto 0));
end led_water;
architecture arch_ledwater of led_water is
signal counter        :        std_logic_vector(25 downto 0);
signal buff                :        std_logic_vector(1 downto 0);
begin
        process(clk,buff)
        begin
                if clk'event and clk = '1' then
                counter <= counter+1;
                end if;
                if counter = "10111110101111000010000000" then
                buff <= buff+1;
                counter <= "00000000000000000000000000";
                end if;
                case buff is
                        when "00" => output <= "1110";
                        when "01" => output <= "1101";
                        when "10" => output <= "1011";
                        when "11" => output <= "0111";
                        when others => NULL;
                end case;
        end process;
end arch_ledwater;
发表于 2015-6-23 20:33:50 | 显示全部楼层
起码得有个复位信号吧, 复位后counter和buff都设为0
发表于 2015-6-27 17:06:38 | 显示全部楼层
原理上,实际运行时没有复位信号也是可以的
GMT+8, 2025-6-29 07:08 , Processed in 0.021129 second(s), 10 queries , Gzip On, MemCached On.
