查看: 6068|回复: 3
新手求助一个关于VHDL编程的问题
发表于 2007-4-17 10:46:39 | 显示全部楼层 |阅读模式
我编写了下列程序,想实现在dataout信号的下降沿时对信号a复值,但这些信号都是在时钟的上升沿采样的。但出现了下列的错误提示,应该怎样写呢?
process(clock)
   begin
   if clock'event and clock='1' then
      if dataout'event and dataout='0' then
        a<='1';
         else
            a<=b;
      end if;
end if;
end process p1;
Error: VHDL error at wc.vhd(23): can't infer register for signal "a" because signal does not hold its value outside clock edge
发表于 2007-4-17 11:12:05 | 显示全部楼层
原帖由 txmfxf 于 2007-4-17 10:46 发表
一个进程里不可以有2个沿触发的描述
process(clock)
   begin
   if clock'event and clock='1' t ...
architecture behav of your_design is
signal tmp: std_logic;存储dataout的副本
signal dataout_rise: std_logic; dataout的下降沿脉冲
begin
process(clock)
   begin
      if (dataout_rise='1') then
        a<='1';
       else
            a<=b;
      end if;
end if;
end process p1;
process(clock)
  begin
        tmp <=dataout;
     end if;
end process;
dataout_rise<='1' when (dataout='0' and tmp='1') else
              '0';
end behav;
 楼主| 发表于 2007-4-17 12:21:50 | 显示全部楼层
谢谢版主!
发表于 2007-4-17 12:46:54 | 显示全部楼层
真的很好哈,很巧妙!~~~
GMT+8, 2025-12-20 01:47 , Processed in 0.020346 second(s), 5 queries , Gzip On, Redis On.
