查看: 10037|回复: 3
请您解释一下altera lpm_fifo_dc0中 wrusedw和rdusedw信号的含义
发表于 2007-4-11 16:39:01 | 显示全部楼层 |阅读模式
请您解释一下altera lpm_fifo_dc0中 wrusedw和rdusedw信号的含义!
发表于 2011-2-20 22:16:00 | 显示全部楼层
SAME QUESTIOIN
发表于 2011-2-23 23:24:06 | 显示全部楼层
回复 1# Jermaine618
# FIFO:  write-port -> (data-in) -> [buffer] -> (data-out) -> read-port
# lpm_fifo_dc: it is dual-clock FIFO, that is, one clock input for read-port,
and another clock input for write-port.
# wrusedw: it shows total used word in FIFO from view point of write-port
# rdusedw: it shows total used word in FIFO from view point of read-port
# So, why it needs two separated "used word" indications for write-port and read-port?
(ANS)
Because there are two seperated clock inputs for write-port and read-port.
These clocks may not be the same (this is the key feature of dual-clock FIFO)
So wrusedw is sync with clock of write-port, rdusedw is sync with clock of read-port.
回复 支持 2 反对 0
发表于 2020-5-14 13:35:10 | 显示全部楼层
kaku817 发表于 2011-2-23 23:24
回复 1# Jermaine618
# FIFO:  write-port -> (data-in) ->  -> (data-out) -> read-port
thanks!!!
GMT+8, 2025-12-24 18:52 , Processed in 0.025678 second(s), 7 queries , Gzip On, Redis On.
