查看: 3423|回复: 6
[求助] edi bufferTreeSynthesis cmd problem
发表于 2015-6-8 13:27:29 | 显示全部楼层 |阅读模式
encouent auto created bts_spec file
i use this cmd to buf a hign fanout net of PWDD , whis is a net connected to 200+ number of ISO cells iso pin , but  encounter failed to do it , no buffer insered in this net , I dont know the reason , who can tell me why ?
 楼主| 发表于 2015-6-8 14:42:11 | 显示全部楼层
it report there has no lef pin matched U_ISO_UNITS/U_ISO_CSI_TESTDOUT5/ISO , that is to say , all the listed pin can not been found , but they are at there , why report can not been found in the design ?
 楼主| 发表于 2015-6-9 07:09:45 | 显示全部楼层
没人理我啊??
发表于 2015-6-9 07:15:05 | 显示全部楼层
一般buffer tree是自动 产生的,根据需要
而有可能你这个是power domain引起的,比如dont touch属性等,
 楼主| 发表于 2015-6-10 06:48:03 | 显示全部楼层
回复 4# icfbicfb
    是的,bts_spec.tcl 是自动产生的,但是没有插入buffer形成tree, 那么是net 的dont_touch 还是cell 的dont_touch 造成的呢,或者是module 的dont_touch 属性造成的?
发表于 2015-8-21 14:10:57 | 显示全部楼层
是不是LeafPorts啊,用get_ports试试看看
 楼主| 发表于 2015-8-21 15:47:02 | 显示全部楼层
GMT+8, 2025-12-26 23:56 , Processed in 0.026592 second(s), 8 queries , Gzip On, Redis On.
