查看: 3110|回复: 3
[讨论] 读入.ddc文件时遇到几个warning
发表于 2015-6-1 11:13:02 | 显示全部楼层 |阅读模式
请问各位牛人,我今天遇到了这两个warning,这是路径没有指对还是其他问题?
warning:the XX cell in XXX technology library is being marked as dont_use
warning:the XX cell in XXX technology library does not have corresponding physical cell description.
warning:the XX cell in XXX technology library does not have corresponding logical cell description.
发表于 2015-6-1 18:04:46 | 显示全部楼层
你同样需要设置link_path ,search_path的,在read_ddc之前
发表于 2015-6-1 18:22:48 | 显示全部楼层
第二个和第三个需要注意
发表于 2021-6-7 09:35:42 | 显示全部楼层
路径设置都没问题,我在设置operating_condition的时候也这样报错
GMT+8, 2025-10-18 05:53 , Processed in 0.019457 second(s), 6 queries , Gzip On, Redis On.
