查看: 2469|回复: 0
[求助] 求大神帮忙看看程序问题出在哪?modelsim仿真后输出数据一直为红线U
发表于 2015-5-21 15:59:17 | 显示全部楼层 |阅读模式
大神帮忙看看吧~感激不尽。以下为testbench程序:library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_textio.all;
use ieee.numeric_std.all;
use std.textio.all;
entity tb_med is
end tb_med;
architecture beh_tb of tb_med is
file input_file: text open read_mode is "input4tb.dat";
file output_file: text open write_mode is "output_tb.dat";
  component med_filter is
  port (
        clk: in std_logic;
        reset: in std_logic;
        data_in: in std_logic_vector(7 downto 0);
        data_out: out std_logic_vector(7 downto 0)
  end component med_filter;
  signal data_in: std_logic_vector(7 downto 0);
  signal data_out: std_logic_vector(7 downto 0);
signal clk: std_logic := '0' ;
  signal reset: std_logic := '1';
  --signal data_valid: std_logic := '0';
  begin
    duv: med_filter
    port map (data_in => data_in,
              clk     => clk,
              reset   => reset,
              data_out => data_out
    reset_gen: process
    begin
        for n in 0 to 3 loop
           wait until falling_edge(clk);
        end loop;
        reset <= '0' ;
    end process reset_gen;
    clock: process
      constant half_clock_period: time := 10 ns;  -- for 100MHz
    begin
      clk <= '1';
      wait for half_clock_period;
      clk <= '0';
    end process clock;
process
variable inline, outline : line;
variable input : std_logic_vector(7 downto 0);
variable output : std_logic_vector(7 downto 0);
begin
  while not endfile(input_file) loop
if (reset = '1') then
data_in <= (others => '0');
else
readline(input_file, inline);
read(inline, input);
data_in <= input;
--data_valid <= '1';
output := data_out;
      write(outline, output);
      writeline(output_file, outline);
end if;
  wait until clk = '1';
  end loop;
  --if rising_edge(clk) then
  --end if;
end process;
end beh_tb;
GMT+8, 2025-12-17 09:19 , Processed in 0.017970 second(s), 7 queries , Gzip On, Redis On.
