查看: 4039|回复: 2
[求助] driver与sequencer连接求助
发表于 2015-5-7 10:16:50 | 显示全部楼层 |阅读模式
我搭了一个平台,报错如下:     formal and actual do not have assignment compatible data types(expecting datatype compatible with ’class uvm_pkg::uvm_port_base#(.IF(class uvm_pkg::uvm_sqr_if_base#(.T1(class si_agent_pkg::si_seq_item,.T2(class si_agent_pkg::si_seq_item))))' but found 'clas uvm_pkg::uvm_seq_item_pull_imp#(.REQ(class uvm_pkg::uvm_sequence_item), .RSP(class uvm_pkg::uvm_sequence_item),.IMP(class uvm_pkg::uvm_sequencer#(.REQ(class uvm_pkg::uvm_esquence_item),.RSP(class uvm_pkg::uvm_sequence_item))))' instead).
报错行的代码如下:
    m_si_driver.seq_item_port.connect(m_sequencer.seq_item_export);
在线等,谢谢
发表于 2015-5-7 11:01:10 | 显示全部楼层
都说了,实参和形参类型不同。。。
 楼主| 发表于 2015-5-7 11:14:21 | 显示全部楼层
回复 2# A1985
   谢谢了,问题解决了。原来我的sequencer忘记传递参数了
GMT+8, 2025-12-27 00:26 , Processed in 0.023874 second(s), 6 queries , Gzip On, Redis On.
