查看: 3349|回复: 0
[求助] Design compiler DV界面
发表于 2016-2-29 17:01:37 | 显示全部楼层 |阅读模式
verilog程序调用只有Warning, 但是综合的时候出错了。错误如下:Error: The register 'sar_reg_reg[8]' is not mapped  because ofa lack of compatible library cells with correct clock/enable phase. (OPT-1217)
Error: Register 'sar_reg_reg[7]' could not be mapped because sequential output inversion is disabled or the exact_map option is used. (OPT-1218)
还有许多WARNING,怎么解决啊
GMT+8, 2025-12-29 09:05 , Processed in 0.018425 second(s), 7 queries , Gzip On, Redis On.
