用的是vivado2014.1,直接调用ip核例化rom,也导入了coe文件,在vivado里仿真的时候rom都好好的,可以读出数据,但是烧到板子里的时候就读不出数据来,请大侠帮忙一下,哪里出问题了?
i3/addr_lut1是给查找表lut1ROM的地址 ;i3/en_lut1_i是给查找表lut1ROM的使能 ;i3/add_out1是查找表lut1ROM的输出 ;
i3/addr_lut2是给查找表lut2ROM的地址; i3/en_lut2_i是给查找表lut2ROM的使能 ;i3/add_out2是查找表lut2ROM的输出 ;
rom都是给54M时钟
module unfold(
rst,
clk_g,//54M
clk_100M,
add_out1,
add_out2,
is_count
//----------------------------------------------------port declare
input rst;
input clk_g;
input clk_100M;
input is_count;
output [16:0] add_out1;
output [16:0] add_out2;
//-------------------------------------------------------------add for lut
(*mark_debug = "true"*) reg [16:0] cnt_lut; //(*mark_debug = "true"*)
(*mark_debug = "true"*) reg [17:0] cnt_lut_all; // (*mark_debug = "true"*)
(*mark_debug = "true"*) reg en_lut1_i; // (*mark_debug = "true"*)
(*mark_debug = "true"*) reg en_lut2_i; //(*mark_debug = "true"*)
always @(posedge clk_g or negedge rst)
begin if (!rst) cnt_lut <= 17'b0;
else if (cnt_lut == 17'd103679) cnt_lut <= 17'b0;
else if (is_count) cnt_lut <= cnt_lut + 1'b1;
end
begin if (!rst) cnt_lut_all <= 18'b0;
else if (cnt_lut_all == 18'd207359) cnt_lut_all <= 18'b0;
else if (is_count) cnt_lut_all <= cnt_lut_all +1'b1;
end
//-------------------------------------------------------------------assign lut en
always @(posedge clk_100M or negedge rst)
begin if (!rst) begin en_lut1_i <= 1'b0; en_lut2_i <= 1'b0; end
else if(cnt_lut_all < 18'd103679)
begin en_lut1_i <= 1'b1; en_lut2_i <= 1'b0;end //flag1 <= 1'b1;flag2 <= 1'b0;
else if(cnt_lut_all>18'd103679 && cnt_lut_all<=18'd207359)
begin en_lut1_i <= 1'b0;en_lut2_i <= 1'b1;end
else if (!is_count) begin en_lut1_i <= 1'b0; en_lut2_i <= 1'b0; end
end
wire en_lut2;
wire en_lut1;
assign en_lut1 = en_lut1_i;
assign en_lut2 = en_lut2_i;
//----------------------------------------------------------------- assign lut addr
(*mark_debug = "true"*) wire [16:0] addr_lut2; //(*mark_debug = "true"*)
(*mark_debug = "true"*) wire [16:0] addr_lut1;// (*mark_debug = "true"*)
assign addr_lut1=(en_lut1_i)?cnt_lut:17'b0;
assign addr_lut2=(en_lut2_i)?cnt_lut:17'b0;
//----------------------------------------------------------------- assign add and en to odd img rom or even img rom
//------------------------------------------------------------lut1
wire clk_lut1 = clk_g;
(*mark_debug = "true"*) wire [16:0] dout_lut1;
lut1 check1 (
.clka(clk_lut1),
.ena(en_lut1),
.addra(addr_lut1),
.douta(dout_lut1)
//------------------------------------------------------------lut2
wire clk_lut2 = clk_g; //(*mark_debug = "true"*)
(*mark_debug = "true"*) wire [16:0] dout_lut2;
lut2 check2 (
.clka(clk_lut2),
.ena(en_lut2),
.addra(addr_lut2),
.douta(dout_lut2)
reg [16:0] add_out_i1;
reg [16:0] add_out_i2;
always @(posedge clk_100M or negedge rst )
begin if (!rst) begin add_out_i1 <= 17'b0;add_out_i2 <= 17'b0;end
else if (en_lut1_i && !en_lut2_i) //rst &&
add_out_i1 = dout_lut1;
else if (!en_lut1_i&& en_lut2_i)
add_out_i2 = dout_lut2;
end
(*mark_debug = "true"*) wire [16:0]add_out1;
(*mark_debug = "true"*) wire [16:0]add_out2;
assign add_out1 = (en_lut1_i)?add_out_i1:17'b0;
assign add_out2 = (en_lut2_i)?add_out_i2:17'b0;
endmodule
