查看: 1881|回复: 1
[求助] ICC 中PNS的问题
发表于 2015-3-24 16:22:44 | 显示全部楼层 |阅读模式
再ICC中用PNS做power strap和power ring ,做完之后preroute instance显示 failed to make a connection for the following pins, preroute instance的时候显示 there is a short between the following objects,这些问题该怎么处理呢?求大神指导啊
发表于 2015-3-25 07:07:45 | 显示全部楼层
没关系的,很多这种情况
GMT+8, 2025-12-15 02:33 , Processed in 0.017365 second(s), 6 queries , Gzip On, Redis On.
