楼主: joemool
[讨论] (纯水)大家有什么想问的?问啥都行。
发表于 2015-4-29 16:15:29 | 显示全部楼层
为什么hold是同沿检查?一直只知道这个,却不明白原理
 楼主| 发表于 2015-5-5 16:43:53 | 显示全部楼层
回复 21# ljjbunny
    Hold Timing Check
A hold timing check ensures that a flip-flop output value that is changing
does not pass through to a capture flip-flop and overwrite its output before
the flip-flop has had a chance to capture its original value. This check is
based on the hold requirement of a flip-flop. The hold specification of a
flip-flop requires that the data being latched should be held stable for a
specified amount of time after the active edge of the clock.
Just like the setup check, a hold timing check is between the launch flipflop
- the flip-flop that launches the data, and the capture flip-flop - the
flip-flop that captures the data and whose hold time must be satisfied. The
clocks to these two flip-flops can be the same or can be different. The hold
check is from one active edge of the clock in the launch flip-flop to the
same clock edge at the capture flip-flop. Thus, a hold check is independent
of the clock period. The hold check is carried out on each active edge of the
clock of the capture flip-flop.
发表于 2015-5-6 13:58:17 | 显示全部楼层
回复 22# joemool
    谢谢!
    是不是这么理解:本周期数据到达之前,要采到上一周期送来的数据,也就是第一级寄存器输出的数据在到达第二级寄存器之前,第二级寄存器要采到之前的数据,而第一级输出数据和第二级才到数据是同一个时钟沿,所以是同沿检查。
发表于 2015-5-6 16:12:25 | 显示全部楼层
用abs 抽取的lef 和foundry提供的lef 为啥差别那么大??
它提供的lef 有很多 相对位置关系, 这个抽取的里面很少啊
 楼主| 发表于 2015-5-6 16:44:37 | 显示全部楼层
回复 23# ljjbunny
    想通了就行了。
发表于 2015-5-13 15:15:53 | 显示全部楼层
回复 18# zhanggd
这两条command针对的都是clock path(即capture path),相对应的还有一个capture clock path。
发表于 2015-5-14 08:32:37 | 显示全部楼层
回复 26# 南武水寿
    我明白了,EDI里面的说的latching clock path 就是平常大家说的capture path,是说的同一个意思,clock path前面加了个latching确实挺让人迷惑的.EDI的man显然没有ICC的man更让人清晰明了.
发表于 2015-5-22 13:21:11 | 显示全部楼层
本科毕业生做后端设计,工作好找吗?
发表于 2015-5-23 16:54:55 | 显示全部楼层
版主你好,我在做calibre DRC的时候遇到了iofiller上的错误。错误类型是"ME1.slotAdditional { @ If using the wide metal defined as being > 35um,the metal slot must be placed for releasing stress
    SIZE NPDME1 BY 17.5 UNDEROVER
}"。意思应该说的是iofiller连成的电源环宽度超过35um(io filler由几段组成,其中的两段长度约为50和70um,连成电源环后,由于长度约为170um,所以filler中的这两段就变成了ME1的宽度),就需要开槽。于是我把图片放大,发现filler上面已经有contact了。难倒contact不算slot吗?
发表于 2015-5-25 16:00:17 | 显示全部楼层
请教下,小项目,数字后端外包给人做,是个不规则的凸字形,规划的是1700umx400um。结果出来,居然插了10%左右的没用的电容。还把宽度拉宽了50。我的问题是这样的利用率是不是太低了。还是形状奇怪,导致没法提高利用率?有什么好办法提高数字版图的利用率?
GMT+8, 2025-9-17 05:17 , Processed in 0.030595 second(s), 6 queries , Gzip On, Redis On.
