查看: 3774|回复: 2
[原创] Assura配置问题
发表于 2015-2-21 19:12:29 | 显示全部楼层 |阅读模式
/root/cadence/installs/ASSURA41/tools.lnx86/assura/bin/32bit/avview: /root/cadence/installs/ASSURA41/tools.lnx86/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /root/cadence/installs/IC615/oa_v22.41.022/lib/linux_rhel40_gcc44x_32/opt/liboaPlugIn.so)
/root/cadence/installs/ASSURA41/tools.lnx86/assura/bin/32bit/avview: /root/cadence/installs/ASSURA41/tools.lnx86/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /root/cadence/installs/IC615/oa_v22.41.022/lib/linux_rhel40_gcc44x_32/opt/liboaCommon.so)
发表于 2015-2-21 21:20:51 | 显示全部楼层
谢谢分享
发表于 2017-5-25 13:40:09 | 显示全部楼层
楼主问题解决了没有?
GMT+8, 2025-12-18 04:31 , Processed in 0.016920 second(s), 8 queries , Gzip On, Redis On.
