查看: 7286|回复: 6
icc_shell -gui 启动的问题
发表于 2015-1-20 17:10:17 | 显示全部楼层 |阅读模式
有个问题: icc_shell -gui会Exit IC Compiler,check synopsys.log没看到更新的话,就应该是.cshrc的问题? 下面是我的.cshrc文件
#.cshrc
unsetenv LM_LICENSE_FILE
unsetenv LD_LIBRARY_PATH
setenv   DISPLAY unix:0
umask 006
# sets certain useful terminal I/O options for the device
if ( $?prompt ) then   # this part is required.
        if (-e /usr/spool/mail) then
            set prompt = "<`hostname` `whoami`> "
            set mail = ( /usr/spool/mail/$home:t )
        else
            set prompt = "<`uname -n` `whoami`> "
            set mail = ( /usr/mail/$home:t )
        endif
        stty erase ^H kill ^U intr ^C
        set erasechar="^H"
        (echo "stty erase $erasechar kill ^U intr ^C " > /dev/null) >& /dev/tty
        unset erasechar
        set history = 200
        set savehist = 100
endif
set SHELL = /bin/csh
set prompt='[%n@%m %c]# '
# User specific aliases and functions
alias icc "icc_shell -gui"
alias g "gvim"
# Set Parameters Here
setenv          EDA_TOOLS                /home/user0/data
setenv          EDA_Synopsys                /home/user0/data/synopsys
#### LicenseFile
# <---- Cadence   LicFile
setenv    CDS_LIC_FILE              27010@RedHat
# <---- Synopsys / Novas LicFile
setenv    SNPSLMD_LICENSE_FILE  27000@RedHat
setenv    LM_LICENSE_FILE          27000@RedHat:27030@RedHat:27040@RedHat:27050@RedHat
setenv    CDS_Netlisting_Mode   Analog
#set for RedHat 64-bit
setenv    CDS_AUTO_64BIT        ALL
setenv    cdslmd_ENH_RECORDS    1
set path = (./ /etc /usr/etc /usr/bin /usr/sbin /usr/local/bin \
/lib64 /usr/lib64 /usr/X11R6/bin $GCC_HOME \
$EDA_Synopsys/installer_v3.2 \
/home/user0/data/synopsys/Synopsys_11.9/amd64/bin \
$SYNOPSYS/bin  $SYNOPSYS/amd64/syn/bin \
$EDA_Synopsys/icc/bin \
$path)
发表于 2015-5-3 03:11:14 | 显示全部楼层
Thank you so much... start_gui got fixed ... nice share...!!
发表于 2018-5-21 13:43:16 | 显示全部楼层
thanks so much
发表于 2018-12-3 14:40:48 | 显示全部楼层
回复 1# chineselboy
感谢楼主的心情辅助
发表于 2018-12-11 00:46:36 | 显示全部楼层
THANK YOU SO MUCH FOR SHARING FOR THIS VALUEBLE INFORAMTION
发表于 2018-12-11 00:47:13 | 显示全部楼层
发表于 2021-10-20 15:49:39 | 显示全部楼层
你没有定义icc的路径呀
GMT+8, 2025-12-26 12:21 , Processed in 0.019043 second(s), 3 queries , Gzip On, Redis On.
