查看: 4656|回复: 1
[求助] ov7670摄像头初始化程序看不懂,求大神相助
发表于 2014-12-10 16:51:43 | 显示全部楼层 |阅读模式
ov7670摄像头初始化程序看不懂,求大神相助/*-------------------------------------------------------------------------
This confidential and proprietary software may be only used as authorized
by a licensing agreement from CrazyBingo.www.cnblogs.com/crazybingo
(C) COPYRIGHT 2012 CrazyBingo. ALL RIGHTS RESERVED
Filename
led_matrix_display.v
Author
CrazyBingo
Data
2012-01-18
Version
1.0
Description
I2C Configure Data of OV7670.
Modification History
Data
By
Version
Change Description
12/05/11
CrazyBingo
1.0
Original
12/05/13
CrazyBingo
1.1
Modification
12/06/01
CrazyBingo
1.4
Modification
12/06/05
CrazyBingo
1.5
Modification
`timescale 1ns/1ns
module
I2C_OV7670_Config
input
[7:0]
LUT_INDEX,
output
reg
[15:0]
LUT_DATA
parameter
Read_DATA
0;
//Read data LUT Address
parameter
SET_OV7670
2;
//SET_OV LUT Adderss
Config Data LUT
always@(*)
begin
case(LUT_INDEX)
//Audio Config Data
//Read Data Index
Read_DATA + 0 :
LUT_DATA
{8'h0A, 8'h76};
//PID
厂商高位识别号 (只读)
Read_DATA + 1 :
LUT_DATA
{8'h0B, 8'h73};
//VER
厂商低位识别号 (只读)
Read_DATA + 0 :
LUT_DATA
{8'h1C, 8'h7F};
//MIDH
厂商识别字节-高(只读)
Read_DATA + 1 :
LUT_DATA
{8'h1D, 8'hA2};
//MIDL
厂商识别字节-低(只读)
OV7670 : VGA RGB565
SET_OV7670 + 0
LUT_DATA
16'h3a04;
//00:YUYV, 01:YVYU, 10:UYVY, 11:VYUY(CbYCrY)
SET_OV7670 + 1
LUT_DATA
16'h40d0;
//RGB565, 00-FF, RGB565(YUV下要改)
SET_OV7670 + 2
LUT_DATA
16'h1204;
//复位,VGA,RGB565 (80:YUV无彩条,82:YUV彩条,84:RGB无彩条,86:RGB彩条)
SET_OV7670 + 3
LUT_DATA
16'h32b6;
//HREF 控制(80)
SET_OV7670 + 4
LUT_DATA
16'h1713;
//HSTART 输出格式-行频开始高8位(11)
SET_OV7670 + 5
LUT_DATA
16'h1801;
//HSTOP  输出格式-行频结束高8位(61)
SET_OV7670 + 6
LUT_DATA
16'h1902;
//VSTART 输出格式-场频开始高8位(03)
SET_OV7670 + 7
LUT_DATA
16'h1a7a;
//VSTOP  输出格式-场频结束高8位(7b)
SET_OV7670 + 8
LUT_DATA
16'h030a;
//VREF
帧竖直方向控制(00)
SET_OV7670 + 9
LUT_DATA
16'h0c00;
//DCW使能 禁止(00)
SET_OV7670 + 10 :
LUT_DATA
16'h3e00;
//PCLK分频00 Normal,10(1分频),11(2分频),12(4分频),13(8分频)14(16分频)
SET_OV7670 + 11 :
LUT_DATA
16'h7000;
//00:Normal, 80:移位1, 00:彩条, 80:渐变彩条
SET_OV7670 + 12 :
LUT_DATA
16'h7100;
//00:Normal, 00:移位1, 80:彩条, 80:渐变彩条
SET_OV7670 + 13 :
LUT_DATA
16'h7211;
//默认 水平,垂直8抽样(11)
SET_OV7670 + 14 :
LUT_DATA
16'h7300;
//DSP缩放时钟分频00 Normal,10(1分频),11(2分频),12(4分频),13(8分频)14(16分频)
SET_OV7670 + 15 :
LUT_DATA
16'ha202;
//默认 像素始终延迟
(02)
SET_OV7670 + 16 :
LUT_DATA
16'h1180;
//内部工作时钟设置,直接使用外部时钟源(80)
SET_OV7670 + 17 :
LUT_DATA
16'h7a20;
SET_OV7670 + 18 :
LUT_DATA
16'h7b1c;
SET_OV7670 + 19 :
LUT_DATA
16'h7c28;
SET_OV7670 + 20 :
LUT_DATA
16'h7d3c;
SET_OV7670 + 21 :
LUT_DATA
16'h7e55;
SET_OV7670 + 22 :
LUT_DATA
16'h7f68;
SET_OV7670 + 23 :
LUT_DATA
16'h8076;
SET_OV7670 + 24 :
LUT_DATA
16'h8180;
SET_OV7670 + 25 :
LUT_DATA
16'h8288;
SET_OV7670 + 26 :
LUT_DATA
16'h838f;
SET_OV7670 + 27 :
LUT_DATA
16'h8496;
SET_OV7670 + 28 :
LUT_DATA
16'h85a3;
SET_OV7670 + 29 :
LUT_DATA
16'h86af;
SET_OV7670 + 30 :
LUT_DATA
16'h87c4;
SET_OV7670 + 31 :
LUT_DATA
16'h88d7;
SET_OV7670 + 32 :
LUT_DATA
16'h89e8;
SET_OV7670 + 33 :
LUT_DATA
16'h13e0;
SET_OV7670 + 34 :
LUT_DATA
16'h0000;
SET_OV7670 + 35 :
LUT_DATA
16'h1000;
SET_OV7670 + 36 :
LUT_DATA
16'h0d00;
SET_OV7670 + 37 :
LUT_DATA
16'h1428;
SET_OV7670 + 38 :
LUT_DATA
16'ha505;
SET_OV7670 + 39 :
LUT_DATA
16'hab07;
SET_OV7670 + 40 :
LUT_DATA
16'h2475;
SET_OV7670 + 41 :
LUT_DATA
16'h2563;
SET_OV7670 + 42 :
LUT_DATA
16'h26a5;
SET_OV7670 + 43 :
LUT_DATA
16'h9f78;
SET_OV7670 + 44 :
LUT_DATA
16'ha068;
SET_OV7670 + 45 :
LUT_DATA
16'ha103;
SET_OV7670 + 46 :
LUT_DATA
16'ha6df;
SET_OV7670 + 47 :
LUT_DATA
16'ha7df;
SET_OV7670 + 48 :
LUT_DATA
16'ha8f0;
SET_OV7670 + 49 :
LUT_DATA
16'ha990;
SET_OV7670 + 50 :
LUT_DATA
16'haa94;
SET_OV7670 + 51 :
LUT_DATA
16'h13ef;
SET_OV7670 + 52 :
LUT_DATA
16'h0e61;
SET_OV7670 + 53 :
LUT_DATA
16'h0f4b;
SET_OV7670 + 54 :
LUT_DATA
16'h1602;
SET_OV7670 + 55 :
LUT_DATA
16'h1e20;
//默认01,Bit[5]水平镜像,Bit[4]竖直镜像
SET_OV7670 + 56 :
LUT_DATA
16'h2102;
SET_OV7670 + 57 :
LUT_DATA
16'h2291;
SET_OV7670 + 58 :
LUT_DATA
16'h2907;
SET_OV7670 + 59 :
LUT_DATA
16'h330b;
SET_OV7670 + 60 :
LUT_DATA
16'h350b;
SET_OV7670 + 61 :
LUT_DATA
16'h371d;
SET_OV7670 + 62 :
LUT_DATA
16'h3871;
SET_OV7670 + 63 :
LUT_DATA
16'h392a;
SET_OV7670 + 64 :
LUT_DATA
16'h3c78;
SET_OV7670 + 65 :
LUT_DATA
16'h4d40;
SET_OV7670 + 66 :
LUT_DATA
16'h4e20;
SET_OV7670 + 67 :
LUT_DATA
16'h6900;
SET_OV7670 + 68 :
LUT_DATA
16'h6b00;
//旁路PLL倍频;0x0A:关闭内部LDO;0x00:打开LDO
SET_OV7670 + 69 :
LUT_DATA
16'h7419;
SET_OV7670 + 70 :
LUT_DATA
16'h8d4f;
SET_OV7670 + 71 :
LUT_DATA
16'h8e00;
SET_OV7670 + 72 :
LUT_DATA
16'h8f00;
SET_OV7670 + 73 :
LUT_DATA
16'h9000;
SET_OV7670 + 74 :
LUT_DATA
16'h9100;
SET_OV7670 + 75 :
LUT_DATA
16'h9200;
SET_OV7670 + 76 :
LUT_DATA
16'h9600;
SET_OV7670 + 77 :
LUT_DATA
16'h9a80;
SET_OV7670 + 78 :
LUT_DATA
16'hb084;
SET_OV7670 + 79 :
LUT_DATA
16'hb10c;
SET_OV7670 + 80 :
LUT_DATA
16'hb20e;
SET_OV7670 + 81 :
LUT_DATA
16'hb382;
SET_OV7670 + 82 :
LUT_DATA
16'hb80a;
SET_OV7670 + 83  :
LUT_DATA
16'h4314;
SET_OV7670 + 84  :
LUT_DATA
16'h44f0;
SET_OV7670 + 85  :
LUT_DATA
16'h4534;
SET_OV7670 + 86  :
LUT_DATA
16'h4658;
SET_OV7670 + 87  :
LUT_DATA
16'h4728;
SET_OV7670 + 88  :
LUT_DATA
16'h483a;
SET_OV7670 + 89  :
LUT_DATA
16'h5988;
SET_OV7670 + 90  :
LUT_DATA
16'h5a88;
SET_OV7670 + 91  :
LUT_DATA
16'h5b44;
SET_OV7670 + 92  :
LUT_DATA
16'h5c67;
SET_OV7670 + 93  :
LUT_DATA
16'h5d49;
SET_OV7670 + 94  :
LUT_DATA
16'h5e0e;
SET_OV7670 + 95  :
LUT_DATA
16'h6404;
SET_OV7670 + 96  :
LUT_DATA
16'h6520;
SET_OV7670 + 97  :
LUT_DATA
16'h6605;
SET_OV7670 + 98  :
LUT_DATA
16'h9404;
SET_OV7670 + 99  :
LUT_DATA
16'h9508;
SET_OV7670 + 100 :
LUT_DATA
16'h6c0a;
SET_OV7670 + 101 :
LUT_DATA
16'h6d55;
SET_OV7670 + 102 :
LUT_DATA
16'h6e11;
SET_OV7670 + 103 :
LUT_DATA
16'h6f9f;
SET_OV7670 + 104 :
LUT_DATA
16'h6a40;
SET_OV7670 + 105 :
LUT_DATA
16'h0140;
SET_OV7670 + 106 :
LUT_DATA
16'h0240;
SET_OV7670 + 107 :
LUT_DATA
16'h13e7;
SET_OV7670 + 108 :
LUT_DATA
16'h1500;
SET_OV7670 + 109 :
LUT_DATA
16'h4f80;
SET_OV7670 + 110 :
LUT_DATA
16'h5080;
SET_OV7670 + 111 :
LUT_DATA
16'h5100;
SET_OV7670 + 112 :
LUT_DATA
16'h5222;
SET_OV7670 + 113 :
LUT_DATA
16'h535e;
SET_OV7670 + 114 :
LUT_DATA
16'h5480;
SET_OV7670 + 115 :
LUT_DATA
16'h589e;
SET_OV7670 + 116 :
LUT_DATA
16'h4108;
SET_OV7670 + 117 :
LUT_DATA
16'h3f00;
SET_OV7670 + 118 :
LUT_DATA
16'h7505;
SET_OV7670 + 119 :
LUT_DATA
16'h76e1;
SET_OV7670 + 120 :
LUT_DATA
16'h4c00;
SET_OV7670 + 121 :
LUT_DATA
16'h7701;
SET_OV7670 + 122 :
LUT_DATA
16'h3dc2;
SET_OV7670 + 123 :
LUT_DATA
16'h4b09;
SET_OV7670 + 124 :
LUT_DATA
16'hc960;
SET_OV7670 + 125 :
LUT_DATA
16'h4138;
SET_OV7670 + 126 :
LUT_DATA
16'h5640;
SET_OV7670 + 127 :
LUT_DATA
16'h3411;
SET_OV7670 + 128 :
LUT_DATA
16'h3b02;
SET_OV7670 + 129 :
LUT_DATA
16'ha489;
SET_OV7670 + 130 :
LUT_DATA
16'h9600;
SET_OV7670 + 131 :
LUT_DATA
16'h9730;
SET_OV7670 + 132 :
LUT_DATA
16'h9820;
SET_OV7670 + 133 :
LUT_DATA
16'h9930;
SET_OV7670 + 134 :
LUT_DATA
16'h9a84;
SET_OV7670 + 135 :
LUT_DATA
16'h9b29;
SET_OV7670 + 136 :
LUT_DATA
16'h9c03;
SET_OV7670 + 137 :
LUT_DATA
16'h9d4c;
SET_OV7670 + 138 :
LUT_DATA
16'h9e3f;
SET_OV7670 + 139 :
LUT_DATA
16'h7804;
SET_OV7670 + 140 :
LUT_DATA
16'h7901;
SET_OV7670 + 141 :
LUT_DATA
16'hc8f0;
SET_OV7670 + 142 :
LUT_DATA
16'h790f;
SET_OV7670 + 143 :
LUT_DATA
16'hc800;
SET_OV7670 + 144 :
LUT_DATA
16'h7910;
SET_OV7670 + 145 :
LUT_DATA
16'hc87e;
SET_OV7670 + 146 :
LUT_DATA
16'h790a;
SET_OV7670 + 147 :
LUT_DATA
16'hc880;
SET_OV7670 + 148 :
LUT_DATA
16'h790b;
SET_OV7670 + 149 :
LUT_DATA
16'hc801;
SET_OV7670 + 150 :
LUT_DATA
16'h790c;
SET_OV7670 + 151 :
LUT_DATA
16'hc80f;
SET_OV7670 + 152 :
LUT_DATA
16'h790d;
SET_OV7670 + 153 :
LUT_DATA
16'hc820;
SET_OV7670 + 154 :
LUT_DATA
16'h7909;
SET_OV7670 + 155 :
LUT_DATA
16'hc880;
SET_OV7670 + 156 :
LUT_DATA
16'h7902;
SET_OV7670 + 157 :
LUT_DATA
16'hc8c0;
SET_OV7670 + 158 :
LUT_DATA
16'h7903;
SET_OV7670 + 159 :
LUT_DATA
16'hc840;
SET_OV7670 + 160 :
LUT_DATA
16'h7905;
SET_OV7670 + 161 :
LUT_DATA
16'hc830;
SET_OV7670 + 162 :
LUT_DATA
16'h7926;
SET_OV7670 + 163 :
LUT_DATA
16'h0903;
SET_OV7670 + 164 :
LUT_DATA
16'h3b42;
default
LUT_DATA
0;
endcase
end
endmodule
发表于 2016-5-28 06:22:34 | 显示全部楼层
lz这个代码是什么器件的?cpld,还是fpga?
GMT+8, 2025-12-26 07:29 , Processed in 0.026165 second(s), 7 queries , Gzip On, Redis On.
