查看: 2200|回复: 0
[求助] TK pipeline insertion
发表于 2014-11-22 15:21:02 | 显示全部楼层 |阅读模式
TK这工具用什么命令可以在channel input/ouput和edt之间插入pipeline stage
我在insert edt 这个step用下面命令
set_edt_pins input 1     dsp_channels_in1 -pipeline_stages 1
set_edt_pins output 1    dsp_channels_out1 -pipeline_stages 1
但是最后生成的netlist里面是没有pipeline stage的,log里面说只有在atpg step有效
//  Warning: The defined channel pipeline stages are not included in the generated RTL. They are only used for DRC and pattern generation in the Pattern Generation Phase.
各位高手,急求答案啊,先在此谢谢。
GMT+8, 2025-12-26 08:49 , Processed in 0.010070 second(s), 3 queries , Gzip On, Redis On.
