查看: 4178|回复: 5
[求助] 如何在EDI中给时钟树加shielding
发表于 2014-11-17 11:06:03 | 显示全部楼层 |阅读模式
cts的部分脚本如下所示,布线后没有看到给时钟树加shielding,请高人指点。=====
RouteTypeName CK1
NonDefaultRule W3S3
PreferredExtraSpace 0
TopPreferredLayer 4
BottomPreferredLayer 3
Shielding VSS
End
此外,从log文件只看到如下warning,不知是不是这个问题引起的,该如何解决?
#WARNING (NRDB-2005) SPECIAL_NET VDD has special wires but no definition for instance-pin connection. This will cause routability problems later.
#WARNING (NRDB-2005) SPECIAL_NET VSS has special wires but no definition for instance-pin connection. This will cause routability problems later.
发表于 2014-11-17 12:48:01 | 显示全部楼层
spec里面相应的clock里面设置RouteType CK1 没?
log里面的问题是你没有globalConnect VDD
 楼主| 发表于 2014-11-17 12:57:25 | 显示全部楼层
回复 2# Hondy
下面是我设置情况
AutoCTSRootPin clk
MaxDelay 3000ps
MinDelay 1000ps
Buffer CLKBUFX2 CLKBUFX3 CLKBUFX4 CLKBUFX6 CLKBUFX8 CLKBUFX12 CLKBUFX16 CLKBUFX20 CLKINVX1 CLKINVX2 CLKINVX3 CLKINVX4 CLKINVX6 CLKINVX8 CLKINVX12 CLKINVX16 CLKINVX20
MaxSkew 10ps
SinkMaxTran 100ps
BufMaxTran 100ps
MaxDepth 20
UseCTSRouteGuide YES
RouteClkNet YES
RouteType CK1
#LeafRouteType specialRoute
End
发表于 2014-11-17 13:28:45 | 显示全部楼层
后面用setAttribute 看看 ,  -shield
 楼主| 发表于 2014-11-17 20:09:31 | 显示全部楼层
回复 4# icfbicfb
版主,我是对一个block进行布局布线,没有IO的那种。加上“setAttribute -net {clk} -shield_net VSS”后,还是没有得到shielding,通过reportShield看到如下警告,该如何解决?
#WARNING (NRDB-976) The step 0.460000 for preferred direction tracks is smaller than the pitch 0.490000 for LAYER METAL6. This will cause routability problems for NanoRoute.
#Merging special wires...
Shielding Summary
#average ratio              : 0.187
#number of nets no shielding: 3
 楼主| 发表于 2014-11-17 22:53:42 | 显示全部楼层
问题已解决,就是没有设globalNetConnect的问题,谢谢两位的关注!
GMT+8, 2025-12-21 05:42 , Processed in 0.021024 second(s), 7 queries , Gzip On, Redis On.
