查看: 2256|回复: 1
[求助] 如何在EDI中给时钟树加shielding
发表于 2014-11-17 10:56:04 | 显示全部楼层 |阅读模式
下面是我的cts脚本,已设定Shielding为VSS,但布线后看到没有给时钟加VSS,请高人指点。=====
RouteTypeName CK1
NonDefaultRule W3S3
PreferredExtraSpace 0
TopPreferredLayer 4
BottomPreferredLayer 3
Shielding VSS
此外,从log文件只看到以下的warning,是不是这个问题引起的,该如何解决?
#WARNING (NRDB-2005) SPECIAL_NET VDD has special wires but no definition for instance-pin connection. This will cause routability problems later.
#WARNING (NRDB-2005) SPECIAL_NET VSS has special wires but no definition for instance-pin connection. This will cause routability problems later.
发表于 2014-11-18 23:36:28 | 显示全部楼层
回复 1# zqlv
setCTSMode -routeShielding VSS -routeLeafShielding VSS
这个设置了么?
GMT+8, 2025-12-18 20:26 , Processed in 0.041378 second(s), 5 queries , Gzip On, Redis On.
