查看: 4378|回复: 3
[求助] 读进rtl代码后,warning,重要吗??
发表于 2014-10-16 11:31:29 | 显示全部楼层 |阅读模式
Warning: In design 'aes_ASIC', input port 'PAD_wb_clk_i' drives wired logic;
(the port direction may have been specified incorrectly). (LINT-6)
Warning: In design 'aes_ASIC', input port 'PAD_wb_rst_i' drives wired logic;
Warning: In design 'aes_ASIC', input port 'PAD_wb_cyc_i' drives wired logic;
Warning: In design 'aes_ASIC', input port 'PAD_wb_adr_i[5]' drives wired logic;
Warning: In design 'aes_ASIC', input port 'PAD_wb_adr_i[4]' drives wired logic;
Warning: In design 'aes_ASIC', input port 'PAD_wb_adr_i[3]' drives wired logic;
Warning: In design 'aes_ASIC', input port 'PAD_wb_adr_i[2]' drives wired logic;
Warning: In design 'aes_ASIC', input port 'PAD_wb_adr_i[1]' drives wired logic;
Warning: In design 'aes_ASIC', input port 'PAD_wb_adr_i[0]' drives wired logic;
Warning: In design 'aes_ASIC', input port 'PAD_wb_dat_i[31]
 楼主| 发表于 2014-10-16 12:24:38 | 显示全部楼层
顶啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊啊
 楼主| 发表于 2014-10-16 14:54:51 | 显示全部楼层
warning求助
发表于 2014-10-16 16:44:45 | 显示全部楼层
回复 1# W13675308408
我个人认为不重要吧,因为可配置双向IO内部结构的原因。
GMT+8, 2025-10-4 10:37 , Processed in 0.014864 second(s), 5 queries , Gzip On, Redis On.
