查看: 24015|回复: 26
[求助] 请教synopsys dc 安装的几个问题
发表于 2014-10-15 22:19:40 | 显示全部楼层 |阅读模式
我安装的是syn_vH-2013.03,vcs-mx_vH-2013.06,scl_v11.7
其中启动时出现问题:$ dv&
[1] 8699
Warning:  Site Information is not available ... Have you run install_site?
Fatal: Internal system error, cannot recover.
Release = 'H-2013.03-SP1'  Architecture = 'linux'  Program = 'dc_shell'
Exec = '/eda/synopsys/dc/linux/syn/bin/common_shell_exec'
'134614556 289814279 289816862 289813916 -143641600 288668006 287988533 287982326 11758393'
Stack trace for crashing thread
SNPSee_72fe6ee5e6adf88ac107a01d196ffb8ed40842348ffb0f8b+51
SNPSee_f1ee00d2049be34bc9fa2aabd0709c661b77ea09a2cd7785+357
SNPSee_b0111077a1564ec2f03c23d0bb102089+295
SNPSee_616b6e047c741ff1baf571efe85d35363e185f8b96f20be8+430
SNPSee_b5b74bb29e23928e271a046254d5c62e+92
unknown+92
SNPSee_108e0bd44901fe5458f9fb7a4d36bf275eef74c6c52bfdf168c0ac47088dc4332b5784bdf203bb8983ce7bac24323028+66
SNPSee_77cfbcc6f25d56ca95afcdc29dbaf22d+38
SNPSee_e6178c5878797e7a723de6cb1a220a8f+21
SNPSee_108e0bd44901fe542e292606fa1ae91ca3cd036ffc7b66b67eb68470c8c8dc1fc9d9f22ed54700c6c50b6ca0c3a58991d261ff0501830e10+38
start_thread+201
clone+94
A snapshot of runtime data has been captured in /home/gj/crte_8699.txt
还有lmgrd的syn_lic.log中出现
21:35:21 (snpslmd)
21:35:21 (snpslmd) EXTERNAL FILTERS are OFF
21:35:21 (lmgrd) snpslmd using TCP-port 44677
21:35:21 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  archprod  avantd  CADABRA  chrysalisd  cowared  EPIC  eved  everest  extremed  hscd  innologd  ISE-TCADd  knights  la_dmon  leda  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  riod  saber_dmn  sandwork  sclmgrd  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  TAVEREN  TE_CATS  tmald  vastlmd  vcsd
10/15/2014 21:35:22 (snpslmd) ------------------------------------------------------------------
10/15/2014 21:35:22 (snpslmd) Checking the integrity of the license file....
10/15/2014 21:35:22 (snpslmd) Valid SSS feature found.
10/15/2014 21:35:22 (snpslmd) The feature is needed to enable the other keys in your license file.
10/15/2014 21:35:22 (snpslmd) Licensed to mammoth//ZWT 2006
10/15/2014 21:35:22 (snpslmd) Siteid: <No Site Id>, Server Hostid: **********, Issued on: N/A
22:10:00 (snpslmd) TCP_NODELAY NOT enabled
lmstat的内容为
lmstat - Copyright (c) 1989-2011 Flexera Software, Inc. All Rights Reserved.
Flexible License Manager status on Wed 10/15/2014 21:32
License server status: 27000@*****
    License file(s) on *****: /eda/synopsys/synopsys.dat:
lmgrd is not running: Cannot connect to license server system. (-15,570:115 "Operation now in progress")
sssverify的内容为
Integrity check report for license file "/eda/synopsys/synopsys.dat".
Report generated on 15-Oct-2014 (SCL_11.7)
Siteid: <No Site Id>, Server Hostid: *********, Issued on: N/A
License file integrity check PASSED!
You may now USE this license file to start your license server.
Please don't edit or manipulate the contents of this license file.
bashrc参照了http://bbs.eetop.cn/thread-412008-1-1.html的方法
synopsys.dat的制作参照了http://bbs.eetop.cn/thread-410223-1-1.html的工具和方法
#dve
export PATH="/eda/synopsys/vcs/gui/dve/bin:"$PATH
#VCS
export PATH="/eda/synopsys/vcs/bin:"$PATH
#Design Compiler
export PATH="/eda/synopsys/dc/bin:"$PATH
#pts
#export PATH="/usr/synopsys/pt/pt_2011/bin:"$PATH
#lmgrd
export PATH="/eda/synopsys/scl/linux/bin:"$PATH
#start synopsys license using lmgrd
#alias lmli2="lmgrd -c /eda/synopsys/synopsys.dat -l ~/syn_lic.log"
export SYNOPSYS="/eda/synopsys/dc"
export SNPSLMD_LICENSE_FILE="27000@guojing"
export LM_LICENSE_FILE="/eda/synopsys/synopsys.dat"
export VCS_HOME="/eda/synopsys/vcs"
export DEV_HOME="/eda/synopsys/vcs/gui/dve"
#export PT_HOME=
alias dc="dc_shell"
alias dv="design_vision"
alias vcs="vcs"
alias dev="dev"
#alias pt="primetime"
 楼主| 发表于 2014-10-16 08:25:48 | 显示全部楼层
我安装的系统是CentOS6.5 64位
 楼主| 发表于 2014-10-16 12:53:38 | 显示全部楼层
解决问题了,以后有与我相同问题的请素素明天的博客http://qing.blog.sina.com.cn/2814090524/a7bb9d1c33004kpo.html
在博客的最后,检查了/etc/sysconfig/network-scripts 里面的ifcfg-eth0,ONBOOT=yes就OK了
发表于 2015-3-19 23:18:32 | 显示全部楼层
兄弟,如何解决的,我的同样问题,求救!
发表于 2015-4-21 10:56:35 | 显示全部楼层
亲,你的博客打不开,这帖子的没法跟。。。
赶紧回来一趟,指教下,我也碰到了同样的问题,有点棘手!如下:
输入lmgrd运行正常,然后输入:dv&
[1] 7938
root@ubuntu:/usr/synopsys/scl/linux/bin#
Unable to obtain feature 'Design-Vision ' because:
Error: Can't communicate with the license server. (SEC-12)
Unable to obtain feature 'Design-Analyzer ' because:
Fatal: At least one of the following must be enabled : Design-Vision, Design-Analyzer. (DCSH-10)
[1]+  Exit 255                design_vision
求各种指教
 楼主| 发表于 2015-6-8 10:43:11 | 显示全部楼层
回复 5# qasdf2010
那个新浪上的博客不是我写的,是我在网上搜到的。我也是菜鸟,这方面也是自己瞎搞,方法不一定适用,但可以一试。5# qasdf2010 还有4# htliu007的朋友,请仔细检查制作lisence的步骤,我安装的时候问题一方面是lisence没有sssverify正确,后面正确之后发现还是搞不定,就在前面提到的博客中试了一下,DC打开成功你们可以试一试,/etc/sysconfig/network-scripts目录下修改一下。
发表于 2015-11-2 15:19:43 | 显示全部楼层
回复 1# gtj
我在redhat 64 位操作系统上安装dc,我也是按照网上的一些教程安装的,想要安装64位的DC,前面的安装步骤还算顺利,license也在电脑上验证通过了,在启动dc、dv时却没启动成功,报错 common_shell_exec:error while loadingshared libaraies:libncurses.so.5:wrong ELF class:ELFCLASS64 不知道是什么原因,查了下资料好像是在64 位操作系统上安装32系统时,需要安装一个库文件ia32-libs,但网上的ia32-libs都是针对ubuntu、centos的,没找到针对redhat系统的,请问您遇到过这种情况吗?该如何解决?
发表于 2015-11-27 11:10:36 | 显示全部楼层
没有遇到过
 楼主| 发表于 2016-2-28 22:10:42 | 显示全部楼层
回复 7# huashuokey
我也没有遇到过这类问题,centos就是redhat重新编译的系统啊
发表于 2016-3-10 13:02:00 | 显示全部楼层
同样的问题
GMT+8, 2025-12-30 22:39 , Processed in 0.028277 second(s), 6 queries , Gzip On, Redis On.
