查看: 3392|回复: 4
[求助] 在综合的时候timing完好,在PR的时候出现很大问题,求解释
发表于 2014-8-22 15:36:30 | 显示全部楼层 |阅读模式
下面是EDI中report_timing给出的时须报告,怎么读懂这个报告,报告中的other是什么意思?
Path 1: VIOLATED Data To Data Setup Check with Pin MI5/X151_X3/Q_reg/RN
Endpoint:   MI5/X151_X3/Q_reg/S (v) checked with  leading edge of 'SPI_CLK'
Beginpoint: SPI_LE              (^) triggered by  leading edge of 'SPI_CLK'
Path Groups:  {in2reg}
Other End Arrival Time          0.959
- Data Check Setup              0.192
+ Phase Shift                   0.000
= Required Time                 0.767
- Arrival Time                  9.567
= Slack Time                   -8.800
     Clock Rise Edge                      0.000
     + Input Delay                        8.000
     + Drive Adjustment                   0.279
     = Beginpoint Arrival Time            8.279
     Timing Path:
     |              Instance               |     Arc     |    Cell     |  Slew | Delay | Arrival | Required |
     |                                     |             |             |       |       |  Time   |   Time   |
     |                                     | SPI_LE ^    |             | 0.676 |       |   8.279 |   -0.521 |
     | FE_OCP_RBC759_SPI_LE                | A ^ -> Z ^  | BUFFER_L    | 0.085 | 0.174 |   8.453 |   -0.346 |
     | u_CONTROL/FE_RC_1035_0              | D ^ -> Z ^  | OR4_J       | 0.216 | 0.241 |   8.694 |   -0.105 |
     | u_CONTROL/FE_OCP_RBC966_X428_Z      | A ^ -> Z v  | INVERT_N    | 0.235 | 0.153 |   8.847 |    0.048 |
     | MI26/MI117_X3/X162/M32              | A v -> Z v  | XNOR2_J     | 0.193 | 0.339 |   9.186 |    0.386 |
     | MI118/X1619_X3/U1                   | A v -> Z ^  | INVERTBAL_H | 0.082 | 0.062 |   9.248 |    0.449 |
     | MI3/X1620_X3/U1                     | A1 ^ -> Z v | AOI21_C     | 0.303 | 0.167 |   9.416 |    0.616 |
     | MI5/X151_X3/FE_OCP_RBC1343_BUS4_19_ | A v -> Z ^  | INVERTBAL_H | 0.112 | 0.079 |   9.494 |    0.695 |
     | MI5/X151_X3/U3                      | A ^ -> Z v  | NOR2_E      | 0.108 | 0.072 |   9.567 |    0.767 |
     | MI5/X151_X3/Q_reg                   | S v         | DFFSR_E     | 0.108 | 0.000 |   9.567 |    0.767 |
     = Beginpoint Arrival Time            0.000
     Other End Path:
     |                          | SPI_CLK ^    |             | 0.000 |       |   0.000 |    8.799 |
     | MI180/MI93_X3/X136/Q_reg | CLK ^ -> Q v | DFFR_K      | 0.129 | 0.362 |   0.362 |    9.162 |
     | MI26/MI117_X3/X162/M32   | B v -> Z ^   | XNOR2_J     | 0.222 | 0.360 |   0.723 |    9.522 |
     | MI118/X1619_X3/U1        | A ^ -> Z v   | INVERTBAL_H | 0.080 | 0.060 |   0.782 |    9.582 |
     | MI3/X1620_X3/U1          | A1 v -> Z ^  | AOI21_C     | 0.359 | 0.176 |   0.958 |    9.758 |
     | MI5/X151_X3/Q_reg        | RN ^         | DFFSR_E     | 0.359 | 0.000 |   0.959 |    9.758 |
下面图片是相对应路径的原理图
schematic
schematic
我在用DC综合的时候,没有任何timing违例,时序很好,可是到了EDI里面,却报告了上面的violation,而且所有violation都出现在触发器的SET和RESET端口上,请问这是怎么回事?为什么DC时候是好的,为什么PR的时候抱着个错误,该如何修正?谢谢大家帮忙了!
发表于 2014-8-22 16:00:04 | 显示全部楼层
樓主 DC 綜合時 set/reset 是不是有下 set_ideal_network, 後來 P&R 拿掉就錯了..
发表于 2014-8-22 16:04:21 | 显示全部楼层
data to data check你也看,我是服了,
 楼主| 发表于 2014-9-17 14:15:26 | 显示全部楼层
回复 3# icfbicfb
    直接忽略呢,还是也像DC似的有个set_false_path之类的命令来忽略该路径检查?
发表于 2014-9-19 10:20:45 | 显示全部楼层
false path掉,
GMT+8, 2025-11-2 05:39 , Processed in 0.015862 second(s), 4 queries , Gzip On, Redis On.
