查看: 10010|回复: 36
[资料] Development of Self-Calibrating A-D Converters
发表于 2014-7-14 10:31:35 | 显示全部楼层 |阅读模式
Spring 2014 issue of IEEE Solid-State Circuits Magazine
Author: H.-S. Lee
Title: Development of Self-Calibrating A-D Converters
Development of Self-Calibrating A_D Converters - H. Lee.pdf (1.35 MB , 下载次数: 317 )
Introduction
The data converters – analog-to-digital and digital-to-analog converters (ADC’s
and DAC’s respectively) – provide an important interface function between
analog and digital circuits in most electronic systems. As MOS integrated circuit technologies began
to replace bipolar technologies in the 1960s and 1970s, it became realistic to integrate both complicated digital and
high performance analog circuits on a single silicon die. Therefore, there emerged a strong need for MOS data converters.
The most popular data converter architecture for bipolar integrated circuits was an R-2R ladder and its variants.
However, the lack of precision resistors and low transconductance in MOS transistors made the R-2R ladder difficult
to provide comparable accuracy in MOS technologies.
For analog circuit applications, the benefits of MOS technology included the availability of high quality capacitors,
excellent switching characteristics, and the zero gate current. The weakness were the aforementioned resistor accuracy,
low transconductance, and lower power supply voltages.  Radically different circuit architectures that exploited the
benefits while avoiding the drawbacks of MOS technology were needed. The switched-capacitor filters were a
great example of such architecture [1]. In the similar line of thoughts, James McCreary along with Profs. Paul Gray and
David Hodges, came up with an innovative ADC architecture using switched capacitors [2]. Rather than employing a separate
sample-and-hold amplifier (SHA), which was a common practice in successive approximation ADC’s, the input was
sampled directly on the binary weighted capacitor array.  Not only this eliminated the need for a separate SHA with
associated power, noise, and area, it also removed the linearity degradation due to the nonlinear parasitic capacitance
at the input of the comparator. The result was 10-bit accuracy primarily limited by the capacitor ratio matching. This
technique referred to as charge-redistribution ADC would become the most dominant successive approximation ADC
architecture for the next 4 decades.
发表于 2014-7-14 17:15:17 | 显示全部楼层
新书,不错
发表于 2014-7-14 18:01:56 | 显示全部楼层
感謝大大的分享
发表于 2014-7-14 19:00:57 | 显示全部楼层
感謝大大的分享
 楼主| 发表于 2014-7-16 12:41:13 | 显示全部楼层
是从 IEEE Solid-State Circuits Magazine 节录下来的
发表于 2014-7-17 00:51:23 | 显示全部楼层
感謝楼主的分享
发表于 2014-7-17 08:48:38 | 显示全部楼层
goodgood
发表于 2014-7-20 14:29:17 | 显示全部楼层
谢谢分享
发表于 2015-10-19 21:47:43 | 显示全部楼层
new book. great. thank you.
发表于 2015-10-20 10:21:53 | 显示全部楼层
thx~~
GMT+8, 2025-12-20 22:06 , Processed in 0.023021 second(s), 7 queries , Gzip On, Redis On.
