查看: 2774|回复: 3
[求助] encounter library character ,求交流
发表于 2014-7-10 15:11:18 | 显示全部楼层 |阅读模式
大家好啊,为什么我的鄂伦春 db_prepare 后,db_gate ,读不出来输入和输出呢,是什么FEEDTHRU  ,不是 INPUT
 楼主| 发表于 2014-7-10 15:25:34 | 显示全部楼层
hi,thanks for you attention!
I use ELC in my work ,when i type the "db_prepare -force" there goes the warning:
elc>  db_prepare -force
==== Simplify Mode ====
MODEL FILE: amic5n.scs ( #size = 4486 )
Reading MODEL: AMI06N
Reading MODEL: AMI06P
SUBCKT FILE: amic5n.scs ( #size = 4486 )
SUBCKT FILE: dut_sub.scs ( #size = 287 )
Reading SUBCKT:INV
Expanding SUBCKT:INV
Writing : foo.ipdb/INV.design
Writing : foo.ipdb/INV.design/body/path
Writing : foo.ipdb/INV.design/body/instance
Writing : foo.ipdb/INV.design/body/net
Writing : foo.ipdb/INV.design/boundary/port
Reading : foo.ipdb/INV.design
       DESIGN : INV
D0000: : POWER
=> 1 vectors generated
Writing : foo.ipdb/INV.design/simulate/spec
Writing : foo.ipdb/INV.design/simulate/subckt
[WARNING(db_prepare)]alone net : A is found. => [reset to ground]
[WARNING(db_prepare)]Please check whether supply nodes are marked global in the netlist, if not specify them with .global statements
[WARNING(db_prepare)]alone net : Y is found. => [reset to ground]
[WARNING(db_prepare)]alone net : VDD is found. => [reset to ground]
[WARNING(db_prepare)]alone net : GND is found. => [reset to ground]
Writing : foo.ipdb/INV.design/body/type
   stimulus generation  summary
Name            #MOS    #DVEC   #RVEC
INV             0       1       0
                         1       0
Reading setup file : setup.ss
-          INV (CELL) -      typical - 2011-02-25 15:11:06 (2011-02-25 07:11:06 GMT)
then i type "db_date" ,it can not recognize the NOT gate
elc>  db_gate
       DESIGN : INV
DESIGN ( INV );
//       PORT DEFINITION
         SUPPLY0 GND ( GND );
         SUPPLY1 VDD ( VDD );
         FEEDTHRU A ( A );
         FEEDTHRU Y ( Y );
//       INSTANCES
END_OF_DESIGN;
- feed-through ( A ) is found
- feed-through ( Y ) is found
can you help me to deal with it ?thanks very much
发表于 2014-7-28 15:49:39 | 显示全部楼层
学习了
 楼主| 发表于 2014-7-29 20:48:21 | 显示全部楼层
回复 3# lggod24697
ha ,I have solved my problem
   i should have used  vi to edit setup.ss ,if didn't, there will be a lot error .
and when I use the spectre ,I still have not pass .
but using hspice ,it passed .
GMT+8, 2025-12-15 06:52 , Processed in 0.015387 second(s), 5 queries , Gzip On, Redis On.
