查看: 3595|回复: 2
问:fpga底下的过孔打多了会不会有什么影响?
发表于 2007-3-21 10:52:40 | 显示全部楼层 |阅读模式
用2c20做了个两层板,底下打了40多个孔,会不会有什么影响呢?请教各位大侠,先谢过了。
发表于 2007-3-21 12:28:53 | 显示全部楼层
how fast is your design? below 50MHz, not a problem, but over 50MHz, you will need to worry about SI.
Another issue you should be aware of is that if you want to put the FPGA on a daughter board and then plug the daughter board onto a mother board for FPGA reuse, it will cause signal quality issues, especially with clock signal, reset signal.
 楼主| 发表于 2007-3-21 13:49:58 | 显示全部楼层
40MHZ and it's not used as a daughter board。Thanks very much!
GMT+8, 2025-12-29 14:35 , Processed in 0.046827 second(s), 7 queries , Gzip On, Redis On.
