查看: 2772|回复: 1
[活动] 每日一奖----20140526
发表于 2014-5-26 09:16:13 | 显示全部楼层 |阅读模式
悬赏200资产未解决
Q15. What is the difference between core filler cells and metal fillers?
发表于 2014-5-26 10:14:02 | 显示全部楼层
When a design is placed in a placer (such as ICC, encounter) there are gaps between these cells. Core filler cells fill in the gaps to make nwell or pwell continuous. Metal fill is usually to fill the empty space on certain metal layer to make the design meet the min metal density requirements specified by fab.
Core filler cells fill the gaps between cells while metal fill is filling the metal layers.
GMT+8, 2025-12-21 21:26 , Processed in 0.014743 second(s), 5 queries , Gzip On, Redis On.
