[求助] dll和pll的jitter仿真
发表于 2014-6-3 18:53:12 | 显示全部楼层
回复 9# 何平
    If you are doing the VCC noise transient simulation, you'd better set your time step as small as possible.  For example, set option DELMAX=1ps in HSPICE, you could get a much better accuracy on jitter number.  The bad thing is you got long CPU time.
发表于 2014-6-3 19:11:36 | 显示全部楼层
回复 10# bigbigbird
    The VCC noise transient get the jitter under the VCC perturbation.  These two jitter type are totally different.
 楼主| 发表于 2014-6-5 14:09:26 | 显示全部楼层
thanks我现在不知道我仿真的jitter是否正确?想要知道另外一种方法交叉验证
 楼主| 发表于 2014-6-5 19:50:47 | 显示全部楼层
回复 12# bigbigbird
图像 3.png 图像 2.png 图像 1.png 我这些图片的设置有什么问题没有?
原理图上没有特别的加噪声源。
发表于 2014-6-5 23:13:04 | 显示全部楼层
那个negative output node要选gnd,而且要看输出的JC和JCC
 楼主| 发表于 2014-6-6 10:04:44 | 显示全部楼层
第一张图UI的含义是什么?出来的JCC和JC很大。我现在把输出波形的数据转成csv文件,导入matlab,得到jcc的值比较小,不知道哪一个是对的
 楼主| 发表于 2014-6-6 14:12:29 | 显示全部楼层
回复 15# dfjl
发表于 2014-6-7 09:01:47 | 显示全部楼层
If you integrate the phase noise from very low frequency, the jitter number would be big.  Most often, the PLL will suppress the low frequency phase noise and then the jitter won't be large.
发表于 2014-6-7 09:04:50 | 显示全部楼层
That is, the VCO phase noise should be multipled by the PLL transfer function.
 楼主| 发表于 2014-6-7 10:24:49 | 显示全部楼层
回复 4# jinchszhl
这位兄弟,你应该做的不是pss+pnoise仿真吧?
GMT+8, 2025-12-29 12:58 , Processed in 0.020675 second(s), 4 queries , Gzip On, Redis On.
