查看: 2043|回复: 1
[求助] DC不能生成网表文件。。
发表于 2014-5-17 22:26:31 | 显示全部楼层 |阅读模式
#set rpt_file "/home/project/spi_syn/log/spi.rpt"
#set design   "/home/project/spi_syn/src/spi.v"
#set log_directory "/home/project/spi_syn/log/"
read_file -format verilog {/home/project/spi_syn/src/spi.v}
Loading db file '/eda/synopsys/dc2008_09/libraries/syn/gtech.db'
Loading db file '/eda/synopsys/dc2008_09/libraries/syn/standard.sldb'
  Loading link library 'gtech'
Loading verilog file '/home/project/spi_syn/src/spi.v'
Detecting input file type automatically (-rtl or -netlist).
Running DC verilog reader
Reading with Presto HDL Compiler (equivalent to -rtl option).
Running PRESTO HDLC
Compiling source file /home/project/spi_syn/src/spi.v
Statistics for case statements in always block at line 191 in file
|           Line           |  full/ parallel  |
|           192            |    auto/auto     |
Statistics for case statements in always block at line 247 in file
|           261            |    auto/auto     |
|           298            |    auto/auto     |
Inferred memory devices in process
in routine SPI_CORE line 158 in file
'/home/project/spi_syn/src/spi.v'.
|    Register Name    |   Type    | Width | Bus | MB | AR | AS | SR | SS | ST |
|    reset_d2n_reg    | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|    reset_dn_reg     | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|    reset_d3n_reg    | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|    rst_sclkp_reg    | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
in routine SPI_CORE line 173 in file
|    omux_sel_reg     | Flip-flop |   2   |  N  | N  | N  | N  | N  | N  | N  |
|    data_out_reg     | Flip-flop |  16   |  Y  | N  | N  | N  | N  | N  | N  |
in routine SPI_CORE line 227 in file
|    stat_mat_reg     | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|     clk_cnt_reg     | Flip-flop |   4   |  Y  | N  | N  | N  | N  | N  | N  |
|     spi_st_reg      | Flip-flop |   3   |  Y  | N  | N  | N  | N  | N  | N  |
|     data_in_reg     | Flip-flop |  14   |  Y  | N  | N  | N  | N  | N  | N  |
|     rd_wrn_reg      | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
in routine SPI_CORE line 166 in file
|    rst_sclkn_reg    | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
in routine SPI_CORE line 206 in file
|   pre_data_wr_reg   | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|    stat_rd_o_reg    | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|   pre_stat_rd_reg   | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
|    data_reg_reg     | Flip-flop |  12   |  Y  | N  | N  | N  | N  | N  | N  |
|    data_wr_o_reg    | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
Presto compilation completed successfully.
Current design is now '/home/project/spi_syn/src/SPI_CORE.db:SPI_CORE'
Loaded 1 design.
Current design is 'SPI_CORE'.
SPI_CORE
read_file -format verilog {/home/project/spi_syn/src/buf_i.v}
Loading verilog file '/home/project/spi_syn/src/buf_i.v'
Performing 'read' command.
Compiling source file /home/project/spi_syn/src/buf_i.v
Reading with netlist reader (equivalent to -netlist option).
Verilog netlist reader completed successfully.
Current design is now '/home/project/spi_syn/src/PS_IBUF.dbS_IBUF'
Loaded 1 design.
Current design is 'PS_IBUF'.
PS_IBUF
read_file -format verilog {/home/project/spi_syn/src/buf_o.v}
Loading verilog file '/home/project/spi_syn/src/buf_o.v'
Compiling source file /home/project/spi_syn/src/buf_o.v
Current design is now '/home/project/spi_syn/src/PS_OBUF.dbS_OBUF'
Loaded 1 design.
Current design is 'PS_OBUF'.
PS_OBUF
#report lib cell's information
#report_lib lsi_10k.lib -all
current_design SPI_CORE
{SPI_CORE}
link
  Linking design 'SPI_CORE'
  Using the following designs and libraries:
  * (3 designs)               /home/project/spi_syn/src/SPI_CORE.db, etc
1
reset_design
1
#check_design
set auto_wire_load_selection true
true
set_wire_load_mode enclosed
1
#this value should be consistent with target library max_fanout&fanout_load
set_fanout_load 2.0 [all_outputs]
1
set_drive       1.0 {SDIN}
1
# clock frequency is set as 10Mhz
set clk_name SCLK
SCLK
create_clock -period 100 -waveform [list 0 50] $clk_name
1
set_clock_latency 2.0 [get_clocks $clk_name]
1
set_clock_uncertainty -setup 1.0    [get_clocks $clk_name]
1
set_clock_uncertainty -hold  0.5    [get_clocks $clk_name]
1
set_clock_transition 0.5            [get_clocks $clk_name]
1
set_drive 0 $clk_name
1
set_structure -boolean true -boolean_effort high
1
set_structure -timing true
1
set_fix_multiple_port_nets -all -buffer_constants
1
# PS_ibuf does not exists in target library?
#set_driving_cell -lib_cell PS_IBUF -pin Z [all_inputs]
#set_driving_cell -lib_cell PS_IBUF  {stat_i[0]}
#set_driving_cell -lib_cell reset_n_buf -pin Z {reset_n_i}
source /home/project/spi_syn/script/timing.tcl
set_load 1.0 DATA
1
set_load 1.0 DATA_WR
1
set_load 1.0 SDOUT
1
#define design constraints
set_input_delay  60   -clock $clk_name { RESET_N }
1
set_input_delay  60   -clock $clk_name { CS_N    }
1
set_input_delay  60   -clock $clk_name { SDIN    }
1
set_input_delay  60   -clock $clk_name { ADDR    }
1
#set_input_delay  60   -clock $clk_name { ADDR[11]    }
set_input_delay  65   -clock $clk_name { SDINIT  }
1
set_input_delay  65   -clock $clk_name { BPIN    }
1
set_input_delay  65   -clock $clk_name { STATUS  }
1
set_input_delay  65   -clock $clk_name { INTRPT  }
1
set_output_delay 70   -clock $clk_name { STAT_RD DATA DATA_WR SDOUT}
1
check_timing
Information: Updating design information... (UID-85)
Information: Checking generated_clocks...
Information: Checking loops...
Information: Checking no_input_delay...
Information: Checking unconstrained_endpoints...
Information: Checking pulse_clock_cell_type...
1
#set_max_delay 75 -to {SDOUT}
set_max_area 0
1
set command_log_file  "./transcript.log"
./transcript.log
set view_command_log_file "./view_command.log"
./view_command.log
#report_timing -from SDIN -to SDOUT
#report_design
report_area
Report : area
Design : SPI_CORE
Version: B-2008.09
Date   : Tue May 20 10:00:53 2014
Library(s) Used:
    gtech (File: /eda/synopsys/dc2008_09/libraries/syn/gtech.db)
Number of ports:               53
Number of nets:               501
Number of cells:              343
Number of references:          27
Combinational area:          0.000000
Noncombinational area:       0.000000
Net Interconnect area:      undefined  (No wire load specified)
Total cell area:             0.000000
Total area:                 undefined
Information: This design contains unmapped logic. (RPT-7)
1
alias sc_on  syntax_check  true
alias sc_off syntax_check  false
alias cc_on  context_check true
alias cc_off context_check false
echo syntax_check_status
syntax_check_status
echo context_check_status
sc_off
Syntax checker off.
1
cc_on
Context checker on.
1
set_fsm_encoding_style binary
report_fsm
report_constraint
#fsm_auto_inferring true
#hdlin_reporting_level comprehensive
uniquify
#compile!
compile -exact_map -map_effort high
#generate netlist file (verilog)
write -hierarchy -output spi.db
write -format verilog -hierarchy -output /home/project/spi_syn/script/spi.sv
write_sdf -version 2.1  /home/project/spi_syn/sdf/SPI_CORE.sdf
#write_sdc                 sdc_script_file.sdc
#save design before quit dc_shell(ddc)
write -format ddc  -hierarchy -output  spi.ddc
set hdlin_report_inferred_modules verbose
verbose
#check_design
#/home/project/spi_syn/script/spi.v
dc_shell> quit
Memory usage for this session 26 Mbytes.
CPU usage for this session 1 seconds.
Thank you...
发表于 2014-5-19 09:16:55 | 显示全部楼层
不想整的花里胡哨的,就直接绝对路径加文件名呗,最简单直接了
GMT+8, 2025-8-24 13:52 , Processed in 0.023202 second(s), 6 queries , Gzip On, Redis On.
