查看: 4052|回复: 1
[讨论] DC constraint report: 这样的结果可以进行下一步了吗?
发表于 2014-4-24 10:58:23 | 显示全部楼层 |阅读模式
是否还需要修改或添加其他的约束?我现在做的这个是.13的,已经加了IOpad。很多设置都是凭感觉,望大家能给指点迷津。谢谢
Report : constraint
Design : TOP_BIST
Version: H-2013.03-SP2
Date   : Thu Apr 24 10:47:40 2014
                                                   Weighted
    Group (max_delay/setup)      Cost     Weight     Cost
    CLK_PLL                      0.00      1.00      0.00
    TC_CLKA                      0.00      1.00      0.00
    in2out                       0.00      1.00      0.00
    in2reg                       0.00      1.00      0.00
    reg2out                      0.00      1.00      0.00
    reg2reg                      0.00      1.00      0.00
    default                      0.00      1.00      0.00
    max_delay/setup                                  0.00
                              Total Neg  Critical
    Group (critical_range)      Slack    Endpoints   Cost
    CLK_PLL                      0.00         0      0.00
    TC_CLKA                      0.00         0      0.00
    in2out                       0.00         0      0.00
    in2reg                       0.00         0      0.00
    reg2out                      0.00         0      0.00
    reg2reg                      0.00         0      0.00
    default                      0.00         0      0.00
    critical_range                                   0.00
                                                   Weighted
    Group (min_delay/hold)       Cost     Weight     Cost
    CLK_PLL (no fix_hold)        0.00      1.00      0.00
    TC_CLKA (no fix_hold)        0.00      1.00      0.00
    in2out (no fix_hold)         0.00      1.00      0.00
    in2reg (no fix_hold)         0.00      1.00      0.00
    reg2out (no fix_hold)        0.00      1.00      0.00
    reg2reg (no fix_hold)        0.00      1.00      0.00
    min_delay/hold                                   0.00
    Constraint                                       Cost
    multiport_net                                    0.00 (MET)
    min_capacitance                                  0.00 (MET)
    max_transition                                 273.66 (VIOLATED)
    max_fanout                                    1244.00 (VIOLATED)
    max_capacitance                               1090.69 (VIOLATED)
    max_delay/setup                                  0.00 (MET)
    sequential_clock_pulse_width                     0.00 (MET)
    critical_range                                   0.00 (MET)
    max_area                                     1193850.88
                                                          (VIOLATED)
 楼主| 发表于 2014-4-24 12:28:10 | 显示全部楼层
自己顶。
坐等高手指教
GMT+8, 2025-12-24 19:51 , Processed in 0.019386 second(s), 6 queries , Gzip On, Redis On.
