查看: 8077|回复: 6
[求助] 关于DC的一些warning,求帮助,谢谢!
发表于 2014-4-21 22:02:36 | 显示全部楼层 |阅读模式
Warning: Verilog writer has added 2 nets to module triangle_0 using SYNOPSYS_UNCONNECTED_ as prefix.  Please use the change_names command to make the correct changes before invoking the verilog writer.  (VO-11)
Warning: Verilog writer has added 1 nets to module fir15_0 using SYNOPSYS_UNCONNECTED_ as prefix.  Please use the change_names command to make the correct changes before invoking the verilog writer.  (VO-11)
Warning: Verilog writer has added 1 nets to module fir31 using SYNOPSYS_UNCONNECTED_ as prefix.  Please use the change_names command to make the correct changes before invoking the verilog writer.  (VO-11)
Warning: Verilog writer has added 2 nets to module triangle_1 using SYNOPSYS_UNCONNECTED_ as prefix.  Please use the change_names command to make the correct changes before invoking the verilog writer.  (VO-11)
Warning: Verilog writer has added 11 nets to module ram using SYNOPSYS_UNCONNECTED_ as prefix.  Please use the change_names command to make the correct changes before invoking the verilog writer.  (VO-11)
Warning: Verilog writer has added 1 nets to module fir15_1 using SYNOPSYS_UNCONNECTED_ as prefix.  Please use the change_names command to make the correct changes before invoking the verilog writer.  (VO-11)
在做一个项目的时候遇见了这些警告,不知道这些警告该怎么处理?谢谢了!!
 楼主| 发表于 2014-4-22 09:52:17 | 显示全部楼层
自己顶一个,求大侠帮助,谢谢!!
发表于 2014-4-22 10:13:49 | 显示全部楼层
应该是module有输出的port 没接,DC自动添加了net。可以用change_names 命令将DC自动添加的net更改一下名字。不改也没事。最好在例化时将不用的输出port也写上一个信号。
发表于 2014-4-22 11:11:42 | 显示全部楼层
waived
 楼主| 发表于 2014-4-22 11:16:16 | 显示全部楼层
回复 3# muylor
        我看了一下代码,发现这些warning应该是由于一些端口没有用到,空置了一些端口,所以这样警告,假设不处理的话会有什么影响呢?还有您说不用的端口加上信号,这个具体怎么加信号呢?麻烦您了!谢谢!谢谢!
发表于 2014-4-24 15:52:35 | 显示全部楼层
回复 5# cjy383554
   不用管也没关系。
如果改,自己定义一个信号wire  xxx_nc;  接到输出悬空port上就可。
点评
请问自己定义一个信号 wire xxx_nc;接到输出悬空port上,这些步骤是在verilog代码中加,还是在dc中加呢?  发表于 2020-7-15 10:04
GMT+8, 2025-12-16 09:10 , Processed in 0.026115 second(s), 11 queries , Gzip On, Redis On.
