查看: 9193|回复: 6
[原创] WLAN的TX代码第二篇:20M信号HT-MF格式的帧头LLTF和HTLTF演示
发表于 2014-4-11 15:30:41 | 显示全部楼层 |阅读模式
这2个symbol主要是用来细频偏估计、细同步和信道估计,其频域的子载波如下
pilotPatten = [zeros(1,6) 1,1,-1,-1,1,1,-1,1,-1,1,1,1,1,1,1,-1,-1,1,1,-1,1,-1,1,1,1,1,0,
            1,-1,-1,1,1,-1,1,-1,1,-1,-1,-1,-1,-1,1,1,-1,-1,1,-1,1,-1,1,1,1,1 zeros(1,5)];
我们假定MCS=1只有一个数据流,但采用了STBC=1,这样就是2个天线的发射分集,TX=2,其主代码如下
  1. %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
  2. % description: This function is main function of 802.11n
  3. % author:
  4. % date:     2014 02 19
  5. % call function list:
  6. %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
  7. clear;clc;close all;
  8. global vecTx;
  9. vecTx.format            = 'HT_MF';
  10. vecTx.non_HT_modulation = 'OFDM';
  11. vecTx.L_length          = 4095;
  12. vecTx.L_dataRate        = 6;            %
  13. vecTx.L_sigValid        = 1;
  14. vecTx.MCS               = 1;
  15. vecTx.CH_bandWidth      = '20MHz';      % '20MHz' or '40MHz'
  16. vecTx.CH_offset         = 'CH_OFF_20';  % 'CH_OFF_20' 'CH_OFF_40' 'CH_OFF_20U'or 'CH_OFF_20L'
  17. vecTx.length            = 65535;
  18. vecTx.smoothing         = 1;
  19. vecTx.sounding          = 0;
  20. vecTx.aggregation       = 0;
  21. vecTx.STBC              = 1;
  22. vecTx.FEC_coding        = 0;        % 0:BCC or 1:LDPC
  23. vecTx.GI_type           = 0;        % 0:long GI or 1:short GI
  24. vecTx.Ness              = 0;        % Num_exten_S
  25. vecTx.Ntx               = 2;
  26. vecTx.expension_MAT     = 'COMPRESSED_SV';
  27. vecTx.expension_MAT_type= 0;            % 1:expension_MAT is present 0:not present
  28. vecTx.SPMmode           = 'DM'
  29. % system configuration
  30. vecTx = ParameterMCS(vecTx);
  31. %% LLTF
  32. LLTF    = LLTF_Gen;
  33. figure;plot(real(LLTF)');title('LLTF-real');legend('real-tx1','real-tx2');
  34. figure;plot(imag(LLTF)');title('LLTF-imag');legend('imag-tx1','imag-tx2');
  35. figure;plot(abs(fftshift(fft(LLTF(1,:),64))));title('LLTF-freWave');
  36. %% HTLTF
  37. HTLTF   = HTLTF_Gen;
  38. figure;plot(real(HTLTF)');title('HTLTF-real');legend('real-tx1','real-tx2');
  39. figure;plot(imag(HTLTF)');title('HTLTF-imag');legend('imag-tx1','imag-tx2');
  40. figure;plot(abs(fftshift(fft(HTLTF(1,:),64))));title('HTLTF-freWave');
    复制代码
其时域波形和频域波形如下图所示
其中HTLTF主要是为MIMO的信道估计提供相应的训练序列,其在频域的导频和LLTF几乎相同。
发表于 2014-10-16 00:07:26 | 显示全部楼层
感谢楼主分享
发表于 2014-11-28 15:42:28 | 显示全部楼层
谢谢共享
发表于 2015-3-9 15:23:36 | 显示全部楼层
感谢楼主分享
发表于 2015-8-4 11:21:16 | 显示全部楼层
感谢楼主分享
发表于 2015-9-16 17:28:06 | 显示全部楼层
谢谢分享~
发表于 2023-6-9 12:36:52 | 显示全部楼层
Thanks for sharing
GMT+8, 2025-10-17 04:03 , Processed in 0.020915 second(s), 6 queries , Gzip On, Redis On.
