查看: 4484|回复: 5
matlab 2015b linux 工具箱不全,求助
发表于 2016-5-3 15:36:50 | 显示全部楼层 |阅读模式
最近安装了一个matlab2015B的linux版本,用了网上的破解,启动之后发现tools box不全,例如license里面有wlan system toolbox,可是simulink界面没有找到,而且安装目录里面没有。
是不是安装包不完全,还是破解不好使呢?
有同学遇到这种情况不?
麻烦解答一下吧,谢谢!
发表于 2016-5-4 01:10:51 | 显示全部楼层
回复 1# dongbeiboy
1, I only use win matlab .2, But you can try as below
     a, run your matlab, type ver, can you find wlan system toolbox in the list
     b, if you find wlan system toolbox,  run help -> wlan system toolbox -> examples
     c, Run a example, if it work, then you can use it already
3. wlan system toolbox  not inside of Simulink Library.
发表于 2016-5-4 01:43:47 | 显示全部楼层
发表于 2016-5-4 21:27:22 | 显示全部楼层
回复 3# ascetic
    Do You have try this Matlab2016a linux?
发表于 2016-5-5 05:12:07 | 显示全部楼层
回复 4# 飞扬紫百合
    I have not tested linux version, but I have tested windows version, whose toolboxes are complete.
发表于 2021-9-17 10:16:52 | 显示全部楼层
jitongw 发表于 2016-5-4 01:10
回复 1# dongbeiboy
     a, run your matlab, t ...
Thanks.
GMT+8, 2025-12-26 07:28 , Processed in 0.015898 second(s), 3 queries , Gzip On, Redis On.
