查看: 2304|回复: 2
Intel Quark SOC 和ATOM 差異多大??
发表于 2014-4-1 21:58:15 | 显示全部楼层 |阅读模式
Today Intel is announcing a microcontroller board based on the Quark X1000 SoC called Galileo. The Quark implementation on the board is a single-core running at 400MHz (single speed, there’s no speedstep equivalent here). There’s a 16KB L1 cache and 512KB on-die embedded SRAM.
=> 那如使用 以前 80288   embedded_486 SOC 比
或是 MEDIA GX SOC 比會差異多少?
发表于 2014-4-13 09:57:12 | 显示全部楼层
How to compare at both processor? What directions do you want to compare?
 楼主| 发表于 2014-4-13 15:35:50 | 显示全部楼层
1. quark CPU 是否還 x86 base ?
2. quark 性能
ATOM 都可以和 core I5 I7  比, 也可以和 Android ARM CPU .
應該說想知道當 Intel 把x86 e931 quark . 耗電變低
但是 性能
GMT+8, 2025-12-14 13:04 , Processed in 0.016804 second(s), 6 queries , Gzip On, Redis On.
