Job Title: Firmware Engineer
Job Description:
This is an entry level, firmware engineering oriented system engineer position. The engineer will be part of the vertical system engineering team composed with hardware engineering, software engineering, firmware engineering, FPGA design engineering, signal integrity engineering, and others. The IC products to work with include Ethernet PHY/NIC/Switch/SoC, high speed SerDes based PHYs, DTV front end components, PLC PHYs, and so on. System engineering team is responsible for many post silicon engineering efforts like product validation, platform development, collateral development, technical support and so on.
Job Responsibilities:
- Boot Code Development.
- BSP Development.
- API Driver Suite Development.
- Protocol Stack Firmware Development.
- Application Level Firmware Development.
- Technical Support to Customers.
Job Qualification:
- BS/MS in EE/CE/CS.
- Must have good program skill.
- Must be familiar with embedded system.
- Must have good knowledge with computer system and data network system.
- Must be willing to work in a multi-tasking, fast pace, team oriented working environment.
- Must be able to quickly absorb different kinds of knowledge and apply them in the works.
- Working experience on firmware/software development are preferred.
- Familiarity with Ethernet and network protocols are some pluses.
If you have any interest in the position, please send your bilingual resume as attachments to al-china-hr@marvell.com
Subject of your email should be “YourName_University_Applied Position Title” For example:张三_硕士_东南大学_3yrs_Platform_南京 |
