查看: 2371|回复: 0
[招聘] [社招全职] Marvell 急招后端工程师及软件工程师
发表于 2014-3-17 16:29:20 | 显示全部楼层 |阅读模式
If you have any interest in the position, please send your bilingual resume as
attachments to  al-china-hr@marvell.com Subject of your email should be “Your Name_University_Applied Position Title”
1\Job Title: Firmware  Engineer
Department: Datacom R&D
Job Description:
This is an entry level, firmware engineering oriented system engineer position. The engineer will be part of the vertical system engineering team composed with hardware engineering, software engineering, firmware engineering, FPGA design engineering, signal integrity engineering, and others. The IC products to work with include Ethernet PHY/NIC/Switch/SoC, high speed SerDes based PHYs, DTV front end components, PLC PHYs, and so on. System engineering team is responsible for many post silicon engineering efforts like product validation, platform development, collateral development, technical support and so on.
Job Responsibilities:
- Boot Code Development.
- BSP Development.
- API Driver Suite Development.
- Protocol Stack Firmware Development.
- Application Level Firmware Development.
- Technical Support to Customers.
Job Qualification:
- BS/MS in EE/CE/CS.
- Must have good program skill.
- Must be familiar with embedded system.
- Must have good knowledge with computer system and data network system.
- Must be willing to work in a multi-tasking, fast pace, team oriented working environment.
- Must be able to quickly absorb different kinds of knowledge and apply them in the works.
- Working experience on firmware/software development are preferred.
- Familiarity with Ethernet and network protocols are some pluses.
2\Job Title: Camera Software Engineer
Department: APSE
Job Description:
In this position, you will be involved in the Camera related software development for Tablet platform. Responsibilities include Camera driver/middleware/application development, performance optimization and system integration, etc.
Qualification:
- 3 years+ camera related development/support experience.
- Familiar with camera sensor, ISP knowledge.
- Solid experience on Windows mobile and/or Android platform driver development.
- Strong in C and/or C++ coding expertise.
- Solid communications skills, Good team work spirit.
- Camera sub-system architecture knowledge, middleware and application development experiences on Windows and/or Android.
- Good knowledge base in Image Processing, e.g. Auto White-Balance, Auto Exposure, Auto Focus, Digital Image Stabilization and Face Detection/Recognition, etc.
3\Job Title: Physical Design Engineer
Department: COT PD-SH -MTSL
Job Description:
Physical Design Engineer will support physical design requirement of different business unit of Mavell, the main responsibility is:
physical implementation, including floorplan, power routing, placement, clock tree synthesis, timing closure, routing, si fixing, drc fixing, dfm ...etc
physical verification: including low power check, timing analysis, timing eco, xtalk analysis, power analysis, ESD analysis, EM analysis, drc check, lvs check, ant check, erc check ...etc
tapeout: timing signoff, power signoff, design tapeout... etc
Qualification:
BS/MS in EE/CS required.
Some knowledge and some experience on process, parameters, synthesis, timing analysis, placement, routing, CTS, SI, power calculation, custom layout, timing analysis and DRC/LVS.
Familiar with Cadence, Synopsys, Mentor, Magma, Apache… EDA tools and design flow;
Familiar with Verilog HDL, Spice
Good programming skill. Capable of writing Tcl or Perl.
Self-motivated team worker, good verbal and written communication skills in English
4\Job Title: Engineer, Senior ASIC Design
Department: Central Engineering
Job Description:
As a Digital design engineer, he/she will contribute to the overall SoC development and IP development for the micron-controller oriented SoC Product line, which includes block level micron-architecture design, RTL coding, Simulation, SoC top level integration, verification and chip bring-up.
Qualification:
oBS degree in Electrical Engineering +5 years experience (or MS + 3 years) or equivalent in hardware development and system architecture.
o Familiar with ASIC design methodologies and flows.
o Experience in the usage of state-of-the-art design tools.
o Proficient in behavioral and RTL coding, Verification. Verilog is preferred
o Experience in logic synthesis, timing closure.
o Experience in Design For Test.
o Knowledge of Low Power architecture and design practice is desirable.
o Strong verbal and written communication skills and proactive team-work spirit.
o Working understanding of various system interconnect protocols such as: AHB, AXI, OCP, APB, and their impact on IP development.
QQ:1552937745
MSN: domiliu0801@hotmail.com
更多Marvell招聘职位,请访问
http://marvell.cnstaff.com/
GMT+8, 2025-12-25 16:28 , Processed in 0.017503 second(s), 5 queries , Gzip On, Redis On.
