在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 5049|回复: 2
[招聘] Trying to run spectre but license is giving problems
发表于 2014-3-9 00:35:05 | 显示全部楼层 |阅读模式
I have configured my license for CADENCE IC615 file which contains multiple features. The license is checking out the features through cdslmd for all the editors(schematic and layout) successfully but gives error and keeps on waiting for the license when i run any simulation. The problem is with license for spectre simulator. and the error is something like this
Fatal error found by spectre.
    FATAL (SPECTRE-209): No license available to run Virtuoso(R) Spectre.
        Please check your license server or use the license queuing
        feature(e.g. spectre +lqt 0).
When i look in the license file and search for features with name spectre in it i get the following features such as Virtuoso_Spectre,
Virtuoso_Spectre_Rf,
Virtuoso_Spectre_XL,
Virtuoso_Spectre_GXL,
Composer_Spectre_Sim_Solution
SpectreBasic,
SPECTREBASIC
Spectre_BTAHVMOS_Models
Spectre_BTASOI_Models
Spectre_Burst_AllegroSI
SpectreHDL
Spectre_NorTel_Models
Spectre_Parallel_Analysis
SpectreRF
Spectre_Siemens_Models
Spectre_ST_Models
The presence of such features make me think that spectre is there in the license. But the problem still persists. Can anyone point out towards what could be the cause of this error, i am running IC615 with mmsim 13.1 have tried versions 7 to 12 in the hope that the error may be version dependent but it wasnt ?... so anybody who could chalk the problem out  ?
发表于 2014-3-9 18:46:02 | 显示全部楼层
回复 1# knark
Have you check if the license server is running at all?
发表于 2016-1-22 17:33:23 | 显示全部楼层
请问楼主是如何处理这个lincense问题的! 我现在也遇到同样的问题;小弟在线等你答复 谢谢
GMT+8, 2025-6-18 14:49 , Processed in 0.020780 second(s), 11 queries , Gzip On, MemCached On.
