查看: 1741|回复: 1
[求助] 加powerpad后不能连电源环
发表于 2014-1-20 21:11:50 | 显示全部楼层 |阅读模式
加入pad后不能连电源
icc_shell> create_cell  pad_vdd pvdf
Warning: Library cell matching constraints can not be found. Library cell from the library CSM35IO122_typ is being used (UIED-89)
Creating cell 'pad_vdd' in design 'shiftregister_pad'.
1
icc_shell> derive_pg_connection -power_net {POWER} -ground_net {GND} -power_pin {VDD} -ground_pin {VSS} -cells {pad_vdd}
Warning: Nothing implicitly matched 'pad_vdd' (SEL-003)
Warning: No valid cell(s) are specified for -cells option of derive_pg_connection. (MWUI-713)
0
请问是什么情况???
 楼主| 发表于 2014-1-20 21:12:32 | 显示全部楼层
知道的请回答下,谢了
GMT+8, 2025-12-23 16:39 , Processed in 0.019738 second(s), 6 queries , Gzip On, Redis On.
