查看: 10039|回复: 7
Sentaurus2013安装 license服务求助
发表于 2014-1-14 13:23:02 | 显示全部楼层 |阅读模式
按照http://bbs.eetop.cn/viewthread.php?tid=418143&extra=&page=1中方法安装
安装后出现invalid licence file fingerprint,换用了http://bbs.eetop.cn/thread-424344-1-1.html 里的src文件
但是swb和GENESISe不能运行,提示找不到license服务
[eda@rectinajh-PC bin]$ ./swb
License lookup failed: License server machine is down or not responding.
See the system adminstrator about starting the license server system, or
make sure you're referring to the right host (see LM_LICENSE_FILE).
Feature:       swb_all
License path:  27020@rectinajh-PC
FLEXnet Licensing error:-96,234.  System Error: 11 "Resource temporarily unavailable"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com"..
* feature is "swb_all"
* version is "2013.03"
* STROOT is "/home/eda/2013/1/bin/./.."
* hostname is "rectinajh-PC"
* display is "/dev/pts/0"
* user is "eda"
license前两行
SERVER rectinajh-PC 000C29FF9DD6 27020
DAEMON snpslmd  home/eda/2013/amd64/bin/snpslmd
开机lmgrd生成的log文件里有swb_all和Valid SSS feature found.
21:14:59 (lmgrd) FLEXnet Licensing (v11.10.0.3 build 96543 x64_lsb) started on rectinajh-PC (linux) (1/14/2014)
21:14:59 (lmgrd) Copyright (c) 1988-2011 Flexera Software, Inc. All Rights Reserved.
21:14:59 (lmgrd) US Patents 5,390,297 and 5,671,412.
21:14:59 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
21:14:59 (lmgrd) License file(s): /home/eda/2013/license/synopsys3.dat
21:14:59 (lmgrd) lmgrd tcp-port 27020
21:14:59 (lmgrd) Starting vendor daemons ...
21:14:59 (lmgrd) Started snpslmd (internet tcp_port 42303 pid 2861)
21:14:59 (snpslmd) FLEXnet Licensing version v11.9.1.5 build 104455 x64_lsb
21:14:59 (snpslmd) lmgrd version 11.10, snpslmd version 11.9
21:15:03 (snpslmd) sup2lig_ise
sup2lig_ise_all swb
21:15:03 (snpslmd) svisual_all
swb-advanced
swb-advanced_all
21:15:03 (snpslmd) swb-advanced_ise swb-advanced_ise_all swb_all
21:15:03 (snpslmd) swb_ise
swb_ise_all
sx_cdslink
21:15:03 (snpslmd) sx_chip
sx_daiclink
sx_drc
21:15:03 (snpslmd) sx_wva
synplify
synplifyasic
21:15:03 (snpslmd) Licenses are case sensitive for TE_CATS
21:15:03 (snpslmd)
21:15:03 (snpslmd) EXTERNAL FILTERS are OFF
21:15:03 (lmgrd) snpslmd using TCP-port 42303
21:15:03 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  archprod  avantd  CADABRA  chrysalisd  cowared  EPIC  everest  extremed  hscd  innologd  ISE-TCADd  la_dmon  leda  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  riod  saber_dmn  sandwork  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9  ssilmd  synforad  synopsysd  synplctyd  TAVEREN  TE_CATS  tmald  vastlmd  vcsd
01/14/2014 21:15:03 (snpslmd) ------------------------------------------------------------------
01/14/2014 21:15:03 (snpslmd) Checking the integrity of the license file....
01/14/2014 21:15:07 (snpslmd) Valid SSS feature found.
01/14/2014 21:15:07 (snpslmd) The feature is needed to enable the other keys in your license file.
01/14/2014 21:15:07 (snpslmd) Licensed to mammoth//ZWT 2006
01/14/2014 21:15:07 (snpslmd) Siteid: 19688, Server Hostid: 000C29FF9DD6, Issued on: 12/28/2012
01/14/2014 21:15:07 (snpslmd) ------------------------------------------------------------------
请问可能是什么方面的问题?求指点迷津
发表于 2014-1-15 12:23:02 | 显示全部楼层
好像,似乎,snpslmd用32位。。。。。。
发表于 2014-2-5 05:59:06 | 显示全部楼层
is it 32 or 64 bit?
发表于 2014-10-9 19:19:31 | 显示全部楼层
32还是64
发表于 2015-5-17 12:23:59 | 显示全部楼层
似乎还未解决,浏览中
发表于 2015-8-1 21:22:35 | 显示全部楼层
回复 1# yezishu
楼主解决这个问题了吗?
我现在也碰到了,能指点一下么?
发表于 2016-3-9 15:24:08 | 显示全部楼层
亲,你的问题解决了吗?我现在碰到的问题和你的一模一样。求大神赐教啊!!!!小弟不胜感激!!!!!
发表于 2023-12-10 16:56:56 | 显示全部楼层
帖子沉了
GMT+8, 2025-10-20 19:28 , Processed in 0.024356 second(s), 5 queries , Gzip On, Redis On.
