查看: 10490|回复: 14
求问Sentaurus TCAD 2013在Centos安装完运行GENESISe报错hostname问题
发表于 2013-10-20 12:11:27 | 显示全部楼层 |阅读模式
刚刚在Win7-i386和centos6.4-x86_64双系统中的纯centos6.4下安装Sentaurus 2013.03,
(License是在32位Win7下生成,不知是否有影响?),完成后运行GENESISe报错如下:
[seazdsky@seazdsky bin]$ GENESISe
License lookup failed: License server machine is down or not responding.
See the system adminstrator about starting the license server system, or
make sure you're referring to the right host (see LM_LICENSE_FILE).
Feature:       swb_all
License path:  27000@seazdsky
FLEXnet Licensing error:-96,234.  System Error: 11 "Resource temporarily unavailable"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com"..
* feature is "swb_all"
* version is "2013.03"
* STROOT is "/usr/sentaurus/H_2013.03/bin/.."
* hostname is "seazdsky"
* display is "/dev/pts/0"
* user is "seazdsky"
查看/etc/sysconfig/下network内容为:
NETWORKING=yes
HOSTNAME=seazdsky
查看/etc/下hosts文件内容为:
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
请各位高手指点迷津,谢谢!
 楼主| 发表于 2013-10-20 12:54:10 | 显示全部楼层
补发一些辅助分析信息:
运行[seazdsky@seazdsky bin]$ /usr/sentaurus/SCL/11.5/amd64/bin/lmgrd -c /usr/sentaurus/license/synopsys.dat -l /usr/sentaurus/synopsys.log
在synopsys.log中看到
20:51:45 (lmgrd) -----------------------------------------------
20:51:45 (lmgrd)   Please Note:
20:51:45 (lmgrd)
20:51:45 (lmgrd)   This log is intended for debug purposes only.
20:51:45 (lmgrd)   In order to capture accurate license
20:51:45 (lmgrd)   usage data into an organized repository,
20:51:45 (lmgrd)   please enable report logging. Use Flexera Software, Inc.'s
20:51:45 (lmgrd)   software license administration  solution,
20:51:45 (lmgrd)   FLEXnet Manager, to  readily gain visibility
20:51:45 (lmgrd)   into license usage data and to create
20:51:45 (lmgrd)   insightful reports on critical information like
20:51:45 (lmgrd)   license availability and usage. FLEXnet Manager
20:51:45 (lmgrd)   can be fully automated to run these reports on
20:51:45 (lmgrd)   schedule and can be used to track license
20:51:45 (lmgrd)   servers and usage across a heterogeneous
20:51:45 (lmgrd)   network of servers including Windows NT, Linux
20:51:45 (lmgrd)   and UNIX. Contact Flexera Software, Inc. at
20:51:45 (lmgrd)   www.flexerasoftware.com for more details on how to
20:51:45 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
20:51:45 (lmgrd)   for your enterprise.
20:51:45 (lmgrd)
20:51:45 (lmgrd)
20:51:45 (lmgrd)
20:51:45 (lmgrd) Unknown host: seazdsky
20:51:45 (lmgrd) EXITING DUE TO SIGNAL 33 Exit reason 1
我的license文件中头两行为:
SERVER seazdsky BCAEC5675F4E 27000
DAEMON snpslmd /usr/sentaurus/SCL/11.5/amd64/bin/snpslmd
发表于 2013-10-20 12:56:57 | 显示全部楼层
编辑hosts文件
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4 seazdsky
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6 seazdsky
 楼主| 发表于 2013-10-20 13:17:01 | 显示全部楼层
非常感谢!问题已经解决了!
发表于 2013-11-27 16:34:45 | 显示全部楼层
回复 1# seazdsky
请问产生的license能用吗?我的一直报错
 楼主| 发表于 2013-11-29 08:17:22 | 显示全部楼层
能用,你用这个src再重新生成license试一下。 Synopsys-2013-10-18-Final.rar (12.29 KB , 下载次数: 219 )
发表于 2014-4-2 21:04:14 | 显示全部楼层
怎么解决的,亲?
能不能告诉一下!
发表于 2014-4-2 23:41:40 | 显示全部楼层
thx^^
发表于 2014-4-11 11:43:34 | 显示全部楼层
楼主,你好!我想在CENTOS6.5上安装,刚运行./setup.sh就提示/sentaurus:command not found
请问这是怎么回事啊,在线急等,谢谢了
发表于 2014-9-9 22:42:36 | 显示全部楼层
nice links
GMT+8, 2025-12-7 00:22 , Processed in 0.020154 second(s), 6 queries , Gzip On, Redis On.
