查看: 5312|回复: 8
[求助] 为什么同样一条路径,iCC与PT结果不同?
发表于 2013-12-12 17:50:24 | 显示全部楼层 |阅读模式
ICC: Startpoint: u_bt_ctrl_logic/u_bit_ctrl/rp_enable_d1_reg
              (rising edge-triggered flip-flop clocked by i_ps_clk)
  Endpoint: u_bt_ctrl_logic/u_bit_ctrl/rp_enable_d2_reg
  Scenario: func_wcl_c
  Path Group: i_ps_clk
  Path Type: min
  Point                                                   Incr       Path      Voltage
  clock i_ps_clk (rise edge)                              0.00       0.00
  clock network delay (ideal)                             0.00       0.00
  u_bt_ctrl_logic/u_bit_ctrl/rp_enable_d1_reg/CK (DFFRPQ_X0P5M_A9TR40)
                                                          0.00       0.00 r    0.99
  u_bit_ctrl_logic/u_bit_ctrl/rp_enable_d1_reg/Q (DFFRPQ_X0P5M_A9TR40)
                                                          0.13       0.13 f    0.99
  u_bit_ctrl_logic/u_bit_ctrl/rp_enable_d2_reg/D (DFFRPQ_X0P5M_A9TR40)
                                                          0.00 &     0.13 f    0.99
  data arrival time                                                  0.13
  clock uncertainty                                       0.05       0.05
  u_bit_ctrl_logic/u_bit_ctrl/rp_enable_d2_reg/CK (DFFRPQ_X0P5M_A9TR40)
                                                          0.00       0.05 r
  library hold time                                       0.11       0.16
  data required time                                                 0.16
  data arrival time                                                 -0.13
  slack (VIOLATED)                                                  -0.04
PT:
  Endpoint: u_bit_ctrl_logic/u_bit_ctrl/rp_enable_d2_reg
  Path Type: min
  Point                                                   Incr       Path
  clock network delay (propagated)                        0.19       0.19
  u_bit_ctrl_logic/u_bit_ctrl/rp_enable_d1_reg/CK (DFFRPQ_X0P5M_A9TR40)
                                                          0.00       0.19 r
                                                          0.10 &     0.28 f
                                                          0.00 &     0.28 f
  data arrival time                                                  0.28
  clock network delay (propagated)                        0.20       0.20
  clock uncertainty                                       0.05       0.25
        0.25 r
  library hold time                                       0.00       0.25
  data required time                                                 0.25
  data arrival time                                                 -0.28
  slack (MET)                                                        0.03
不理解的是为什么icc的clk 是ideal的,我是ICC布局布线后report_timng的。
 楼主| 发表于 2013-12-13 07:38:35 | 显示全部楼层
这个问题看来得版主出面帮忙解答了
发表于 2013-12-13 09:40:46 | 显示全部楼层
ideal vs propagated ??
check "set_ideal_network" & "set_propagated_clock" in the sdc file~
发表于 2013-12-13 10:24:55 | 显示全部楼层
你在ICC report_timing 之前 请设置 set_propagated_clock [all_clocks]
 楼主| 发表于 2013-12-13 11:08:02 | 显示全部楼层
首先感谢楼上二位的回复。当前进展如下:
1.与set_propagated_clock关系不大,因为icc 中cts后,built clock are propagateed automaticaly
2.我做了实验,原因是report_timing,我增加了-scenario [all_scenarios]选项,因为该项目工艺是40nm ,需要考虑mcmm。如果去掉该选项,则无ideal clk
3.-scenario [all_scenarios] 选项是要加上的,原因我在进一步去学习。
发表于 2013-12-13 20:04:14 | 显示全部楼层
我记得有个帖子好像说过,因为算法不一样~~
发表于 2013-12-15 23:20:23 | 显示全部楼层
那个,如果一样pt就不用卖了,不过可以人为的根据实际情况调整icc的rc抽出,让结果更好的保持一致
发表于 2013-12-16 10:00:15 | 显示全部楼层
回复 5# yl5495
    执行MCMM,某个scenario中的clock为ideal。需要在所有的scenario中执行一遍set_propagated_clock [all_clocks]
发表于 2019-7-25 16:16:37 | 显示全部楼层
学习了
GMT+8, 2025-10-30 07:33 , Processed in 0.019602 second(s), 4 queries , Gzip On, Redis On.
